Does anybody know off hand what core voltage Macci runs his 1.6 chip at??
Thanks,
OPP
Thanks,
OPP
I think it was 1.8v... i guess... at least i remember he didn't made any Vcore mod in the P4T-e, only Vrimm, so, he's using the NW pins, and i guess it's 1.8v...
Raptor AMD Opteron 148 Cabne || Asus A8N32-SLI Deluxe || XFX Geforce 7800 GTX 512Mb XXX Edition
Wow, 1.8 is low, he must have some great cooling. well I know he has Great Cooling but thats incredible, must be one hella chip.
I want to try one.
OPP
it is a great cpu...
But there's one thing that you need to know, is that the limiting factor in the NW cpu's is not temperature or voltage, but the motherboard it self!!!
For example, his NW is exactly the same, with the exact same voltage and exact same cooling!!!
So, why did he won about +100MHz overclock over the TH7-2... you don't need extra voltage, because it's the board that's limiting the cpu Overclock... and probably the same is hapening right now with the P4T-E, since DJ told me that the Iwill i850E is great because it's, until know, the board that makes his NW go more than 3.3GHz, and in the P4T-E and TH7-2, they couln'd pass over 3.150!!!
Wow,
I wonder if the BD7II is holding back the 2.26 chip I have.
OPP
Maybe...
Hey Doc, good to see you here.
How's the dark side?
Just kidding.
Glad you came by.
DDTUNG
I dont think so, the BD7 is a very very good overclocker... the TH7-II however is one of the worst boards around when it comes to CPU overclocking. I tested the Abit IT7 and it allowed me to load Windows at 3300 MHz, while on the TH7-II I have trouble with 3200. I could do 3255 stable, on the TH7 i'm limited to 3160. The TH7 is a LOT faster in 3Dmark than that IT7 though. The IT7 only has an option to run your memory at 3/4 your FSB, not 4/3... go figureOriginally posted by OPPAINTER
Wow,
OPP
the biggest problem is that most RDRAM boards max out around 150 FSB because of the PLL they use. And if they use a PLL that wouldnt mind 200, then you can bet they strapped on some DRCG's that arent worth :banana::banana::banana::banana:. Abit better hurry with the sucessor for the TH7
I've done the Vcore mod too and Its at 1.86-1.88V under full load at 3.2G. Haven't tested higher yet
my bad, I thought i remebered you saying 1.9 a while back.
Tanks buddy!
I'm sure you'll see me around here quite a bit.
Just kidding.
Glad you came by.
DDTUNG
this dude thought me and jc were bluffing that we got our 1.6a's over 170 fsb.
who did?
Dr. good to see ya
Glad you made by
OPP
his name was MospeadasDark
and he said that it was highly unlikely anyone would hit 170 fsb.
Hawkeye,
Is that you from Icronics?? How you Been??
OPP
yeah but you all dont like me so i am gonna be on and off as i am posting this as i am at work at the pentagon, called back to do a overhaul on some servers there. also i heard what happend at icrontic as i wont go there no more cause of that.
Told'ya!Originally posted by macci
what's happened at icrontic?Originally posted by CSHawkeye81
fx-53@210*14@1.7V, asus x800xt-PE peltier cooled-Vapochill ls
The maddest in hardware!!
I read about it a while back, I hope it gets resolved soon.Originally posted by CSHawkeye81
its between me and some other guys here.
Originally posted by Dr. GoodenHigh
Tanks buddy!
Geez...every man and his damn dog on these forums now..:p
G'day mates...
FT.
..'if it ain't frozen, you ain't really tryin'...
VAPOCHILL Folding Team #32427
Hey Macci,Originally posted by macci
Glad to see you around my friend
Sam
P4 3.2
P4C800-E
Xtreme Tek Werkz Typhoon waterblock
Maze4 GPU Waterblock
Mcx159-P w/10,500rpm counter-rotating 50mm JMC fan
Mushin BH-5 Promo build 2-2-2
9800 pro with silversink ramsinks
WD Raptors
My Heatware
Cant you make a big thread writing everything about your latest rigs, at www.muropaketti.com (Finland) there was some pics earlierOriginally posted by macci
At last a fan pic
