How Can I Overclock X1900cf..both Card's???
Hy men,
please help me ! i have an X1900CF,with MSIX1900XT mastercard and MSI X1900XTX slave. i don't know how can i overclock both cards more than 690 gpu /800 mem , in Catalyst Contol Center.....!?!?
P3
..........and other stuff like this !
Wait, you have an X1900CF version AND an X1900XTX or an X1900XT and an X1900XTX?
If the latter, it won't work in CF..
Muslim Overclocker
Check my sig
There is more info in the conclusion for overclocking your mastercard as well.
My watercooling experience
Water
Scythe Gentle Typhoons 120mm 1850RPM
Thermochill PA120.3 Radiator
Enzotech Sapphire Rev.A CPU Block
Laing DDC 3.2
XSPC Dual Pump Reservoir
Primochill Pro LRT Red 1/2"
Bitspower fittings + water temp sensor
Rig
E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
- You may not post replies
- You may not edit your posts
Forum Rules
