if anyone has seen any of these in stock on any website can you let me know.
aandross
I assume thats in the USA?
Originally Posted by Bloody_Sorcerer
Originally Posted by MaxxxRacer
nope was looking for one myself.
assumption correct*Originally Posted by creidiki
aandross
Your best bet would be to PM Marci, he will know who has stock and whos getting it when.
alright thanks alot!
aandross
just got 1 from dangerden
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
u prolly got the last one.
LOLOriginally Posted by mikenam
alright now i just found out that thermochill doesn't ship to Illinois /cry. How are the black ice rads?
aandross
A viable alternative. U can also check swiftech's rads.Originally Posted by N!ckFas
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
And the cooling works 22-T
Id take that or the MCR-220QP over the BIP II, tbh.
Same here.Originally Posted by creidiki
actually i just found one at voyuer mods that they just got off of back order so if anyone is looking for them that might be ur best bet. When i was last on the website it said they were on backorder but i called just to be safe and sure enough they just got them in.
aandross
wow I didn't know PA120.2 getting so popular and hard to find one now, I guess the best bet is to wait another shipment from Thermochill
MCR-200QP is your second best choice, followed by bip2. Low CFM fans for both, just like the PA series.
performance-cpus.com or something like that has them. Got my PA120.3 there this week.
Intel i7 3770K 4.4Ghz
Asus P8Z77-V Pro
XFX HD 6950 --> 6970 Flashed
8GB Gskill DDR3-2133
Sound Blaster Z
Corsair AX850
2X Crucial C300 RAID0
if you can't find them, just wait for new shipment with better paint job cuz currently the paint on those Thermochill are scratch too easy
well im not sure how much of a difference paint makes on the radiator...unless you are really into looks
aandross
I have read that painting the fins hinders performance a degree or 2. But this is what I read, don't mean it's true.
Paint on the PAs fins is a joke anyway, theyre only painted for the 1st like 1-2mm. That rad is so thick, htey might as well not be painted.
I dont care though, they rule, crappy paintjob and all![]()
