DFI LP UT P35-T2R | E8400 Q743A748 - IHS removed
Team Xtreme PC2 9600 2x1GB | Auzentech XPlosion
PCP+C Silencer 750W | 2x36GB Raptors RAID-0 | XFX 7800GT
Iwaki MD20-RZT | FuZion - 4.4mm - modified ProMount | PA120.3
Wow man, that is wicked! Especially cool with two completely different sets of memory. Happen to have a SANDRA Bandwidth, buffered or unbuffered?
Intel C2E QX6850 @ 3.33GHz, ASUS P5K Premium, OCZ 8GB PC2-6400, eVGA 8800GT, OCZ ModXStream 720W, Thermalright Ultra-120
Seagate 500GB, 750GB & 1TB, Samsung 20x DVD-RW, ASUS Xonar D2X, Antec P182, Ultrasone PRO 750, Dell 2408WFP, Gentoo 2008.0
"Life without knowledge is death in disguise." - H.P. Baxxter
Techgage.com Editor in Chief | Profiles: Last.fm | Xbox Live | Steam
Awesome work there. What spd's are on those TeamGroup? I assume the Mush's are 2-2-2-6?
I had problems running 4x512 with a 2x512 Mush L2 because they wouldn't play with certain sets of sticks with differing spds. The bios and windows would only show 1gig whilst cpu-z and other programs showed 2gig.
Just wondering if you found this problem, and if so, did you find a workaround.
Congrats on the run!
No rig right now.
Nice!
MB Reviewer for HWC
Team OCX Bench Team
can we have bios screen shots, i have still problems to get my 4 sticks of bh5 stable :S
3x FX8150, 1250w Enermax, Fractal Desing , HD6870, Asus Crossahair V and some ln2 stuff
http://hwbot.org/submission/935260_s...be_10sec_300ms <- Lets try agen.
nice results, high oc using two diferents sets of memory
double post
DFI nF4 Ultra-D R.AD0 ~ Bios 510-2FIX | DFI nF4 Expert R.A02 ~ Bios 704-2BT
Opteron 148 + TR XP-120 ~ 2900MHz@1.52v | Venice 3200+ ~ 2500MHz@1.376v
GSkill GBFX 2x512MB trcd=3 trcd=4
GSkill GBGH 2x512MB 244MHz 2-2-2-5 1T@3.22v (windows)
GeIL ONE-S TCCD 2x512MB ~ 264MHz 2.5-3-3-7@2.54v (windows) ~ 303MHz 2.5-4-3-7@2.76v (windows)
GeIL ONE-S BH-5 2x512MB ~ 244MHz 2-2-2-5@3.22v (windows)
Leadtek PX6600GT TDH 128MB | ViewSonic VX724 | 1x74GB WD Raptor SATA | 2x250GB Hitachi Desktar T7K250 SATA II - Raid0 | TDK CyClone CD-R/RW DVD Combo 52/32/52/16 | BenQ 1640 | CM Stacker STC-T01-UWK | Enermax Coolergiant EG-701AX-VH | WindowsXP SP2
Impressive work there, especially 2 diff sets..
If it was expert and 1t itd be out of this world, id like to see some BW shots, and super pi 1M @ 2t
Join the XS WCG team and do your part to help save the world..
^^^Click here to start folding for the soon to be number one team in the world..^^^
Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
"A computer beat me in chess, but it was no match when it came to kickboxing"
-Emo Philips
how max your ram can do, if cpc=enable (1T) ?
Not really gonna happen above 200mhz. Great result though, especially for a mix of old school bh-5 and utt.Originally Posted by zungkono
"Bloody hell, im gonna die to Boney M"
Great work i just wish you could buy them in the UK
You ever get the feeling your being watched!!
@Deathspawner: don't know about buffered vs. unbuffered, but here's a standard shot. Sorry it's hard to read.
@szukalski: SPD's sure seem different; don't know why I have no problems.
@sponge bob: sorry mate, no digicam. Use A64 shot? D/DS are at 8/auto.
@philosophy: 1M maxes around 273MHz. I get CPU limited at those speeds. Oddly, my best results are here with x11. Lower multipliers hurt my results. I suppose I could drop it just for a 1M run though.
@zungkono: UTT max at 275MHz 1T, BH5 around 270MHz at 1T.
I mean when you run 4x512MB 1T, max ?Originally Posted by ixtapalapaquetl
nice result ixtapalapaquetl
Could you please tell me how do you run 2 dif.set of BH and UTT ? I've tried with Mushkin Redline UTT and OCZ UTT but it showed only@ 1 GB. Thanks
200-210mhzOriginally Posted by zungkono
Nop: some brands dont work well togheter...
Can you do some blend Prime ? I'm running 4x BH-5 512MB stable 100%
Headshot ! those who can, do, those who can't, complain.
Thanks Lastviking.Originally Posted by Lastviking
my GEIL BH5 and GSkill BH5 4x512MB can run 2-2-2-5 2T 247MHz 3.23v on ultra-dOriginally Posted by Lastviking
but nogo for 1T on Ultra-D
now I try it on expert, no result yet
Shouldn't you use 2x superpi ? BTW it's a bit too late for that, when DDR2 is soo near...
Good job BTW
Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
I assume his UTT is UTT- BH, so its 4 of the same chips. A solution to "working together" is to burn the 4 DIMMs to the same SPD. Use the spd tool to re-burn the SPD to have the slower sticks match the faster.
I have 4 KHX3000 that I burned to be 4 Mushkin 3500 lvl II's, cleared up some issues due to Kingston having lousy SPD timings. The sticks weren't as good as Mushkins, but did improve over stock simply by using the Mushkin SPD.
GA-MA790GP-D4SH, 965BE, 3.8Ghz
Ultra120E, 4x2G Gskill 1066
2x 150G VRaptor raid, WD640AALS
8800GT 735/940/1685, LG-BluRay
Very nice, ixtapalapaquetl
SPi32M time is kind of slow for those clocks, but 4 DIMMs at 270Mhz is a pretty sight for sure
Congrats, man I will update my list soon enough...
@Revv23: 1:1 did not do as well (IIRC, I got up to 266MHz). It sounds odd (even to me) - I will reinvestigate this later this afternoon.
@zungkono: Sorry I misunderstood you. I tried 206MHz @ 1T and got nowhere, so I gave it up. I reasoned that a ~70MHz increase in frequency would more than make up for the difference in command rate.
@ValkyrieLenneth: I don't plan on running prime for hours at this speed. It was a benching run.
@^don.k's^: That seems like a fair critique, and one that I had considered. My reasoning was that I was trying to establish the stability of my memory, not my CPU (which would certainly require dual instances). Thus, allowing two cores to act simultaneously on a single instance of SPi seemed reasonable insofar as the stress on the memory is unchanged. I suppose another alternative would be to dedicate a run to a single core, thus guaranteeing validity. If I need to do so to prevent an asterisk next to my result, let me know.
How high can you go on super pi1m? this is mine with hot hot air.
4x512 Old bh5 2xkhx +1 corsair +1 muskin
