Hi,
I can buy a R404 cooling unit, but the guy I'm buying it from doesn't knwo any specs of it, and nothing on the internet
Here's a pic, maybe someone overhere can help us out?
Thx
Hi,
Thx
fredperry,
Good of you to come my man, Welcome to Xtreme. Hows the cooling rig of yours?? Did you get better seating on the CPU??
Sorry, Can't help with the ID of the Compressor, no clue myself.
OPP
No, haven't found the time (yet)
I'm in the middle in exams and allready got a bad one due to my prometeia
But, a friend of mine got his one working fine, giving him temps of -7°C idle and 0°C under full load with a XP1900+@1817@1.85v
(just prelimary results)
He used four spacers, whereas I only use one (received only three, so I'll have to find me some).
Also I'm using AA instead of ASIII, which should gave me a slight gain also.
His results give me hope
AMD XP1600+ @ 1894MHz (10.5x180) (Vcore: 1.85v (need Vmod)) | ABIT KX7 | samsung PC2700 | Cooled by MachI
AMD64 3200+ (stock cooled) | 512mb Kingston HyperX | R9800Pro
phase-change.com
I'll bet you any amount that after you slap on some more spacers you get a much greater Clock, night and day probably.
OPP
anyway you can get a more clear shot of that ID
I'll ask him. this was taking with his wbcam i believe...Originally posted by Kurupt
//edit: Damn, that was the best he could do
but if you tell me what to look for he'll write them down and give'm to me...
phase-change.com
Fredperry,
That label is not from a compressor, is from a display-freezer. In Italian display=expositore. Ask if the guy can send you the compressor label, with that would be easier to find the compressor data on the web
Send him an email,I hope he finds something, 'cause he's studying for cooltechnician, so normally he would have found something, maybe this was the only thing he could find?
Anyway, he's going to make a heatexchanger for it, give it a quick test en pr0lly sell it (hopefully to me )
But I've got some backup: R134a compressor
(should be enough for the vidcard ASHRAE: -10°C@226w)
Originally posted by Petrus
Fredperry,
phase-change.com
LOLOriginally posted by fredperry
It's a Danfoss it will do the job.
Hey petrus,
Could u check you Hotmail or your netvisao mail...?
U know who M I
Aspera T12168gk-906da24
embraco
capacity: 462 - 964w
temps: -40°C to -10°C
looks nice...anyone got experience with these compressors?
phase-change.com
I have two freezers using Embraco compressors, they are made In Brazil and no problems so far
hehe, good newsOriginally posted by Petrus
Think I'll pay the guy a visit and have a look how its working...
phase-change.com
Hi Fredperry
Check these temps this is on an XP 1600+ @ 2008 Mhz Prometeia cooled -7 under full load after 4 hours - 15 idle. I have 4 spacers on each screw.
Menty
A64 3800+ 2.6, DFI NF4 Sli-dr, 2gig Ballistix, 600 giga hd, X850XT PE, Aureon, IBM T860 18.1, Watercooled by DD RBX
A friend of mine gets about the same temps you do. calantak send me some extra spacers and tommorrow I'll rebuild the prometeia with 4 spacers on each screw and some ASIII... I'll let you know how it goes
phase-change.com
