Results 1 to 3 of 3
Thread: Viable Thermosyphon?
    Apr 2005
    Wales, UK
    Is it possible to set up a pumpless watercooling system for a cpu, gpu and northbridge on a single radiator?
    Also does such a system absolutely need TEC's to work or do they just improve performance?
    I was thinking of doing a piecemeal watercooling build, and the pump is the most expensive component, so if i could make do with a thermosyphon it may be a cheap way to start.
    Attached Images Attached Images
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    No
    Read TEC stickies
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    TEC is neccesary.. CPU will overheat before enough heat is generated to start a good flow of heat from the WB to the rad and back.
    Im far from an expert on this subject, but from what I have seen of the thermosphyns, only one waterblock at a time will really work. Probably a mixture of flow restriction, tubing issues, and heat buildup.
