+ Reply to Thread
Results 1 to 11 of 11
Thread: Need help with a new pc.
    Aug 2003
    New Jersey
    0
    2nd pc will go into a custom built wood case.
    Main pc will be a new one. I haven't paid much attention to new cpus and motherboards and video cards for a year and a half, so I don't know what to get but did come up with a idea for a new pc.
    New pc:
    a64 x2 4400
    dfi lp ut sli-dr expert
    1 or 2 7900 gtx
    g.skill 2x1gb hx pc3200
    pc p&c 510w
    xmystique 7.1
    80gig maxtor sata
    2x250gig maxtor sata
    plextor px-716sa/sw sata
    42" westinghouse 1080p lcd tv/monitor
    I'm also looking for a OTA hdtv tuner/capture card. No ati please.
    And also, do they make bluetooth mouse and keyboard anymore? I have the logitech mx900 bluetooth mouse but can't find anyplace that sells it anymore.
    Also, I am already starting on getting the drivers for the new hardware. For the nf4 motherboard that I want, what drivers should I get from nvidia's site? There are about 6 different sets of nf4 drivers. I don't know what to download.
    And finally, I want to try the x64 edition of XP. Is it worth it? I'll have all the drivers ready for it. If I use it, will I still be able to play most older games?
    tia.
    Aug 2003
    New Jersey
    0
    anyone?
    It is Frisch's Avatar
    Feb 2005
    Copenhagen Denmark
    0
    Hauppauge Tuner card, it's the best.
    There is a delay on the signal, very little (ms), to take some of the work from the CPU, giving less noise (signal).
    Clear picture, of course depending on the quality of what you recieve.
    There are several models, I have the 250, with one tuner. The 500 has two tuners, so you can record and watch TV at the same time.
    Tunercards from Hauppauge
    ~Opinion about Dogs~~~~~~~Hug~~~~~~~~
    ________________________________________________
    Feb 2005
    Copenhagen Denmark
    0
    Xtreme Member blazin-asian's Avatar
    Feb 2006
    Toronto, Ontario and USA
    0
    i found an mx900 on ebay. only 1 though and its ending in 3 days.
    Intel Q6600 G0
    DFI LANPARTY DK P35-T2RS
    4gb GSkill PC8000 PQ
    XFX 7800GT 256mb
    320gb Seagate SATA
    2x 750gb WD SATA
    NEC 3550a DVD-RW
    Toshiba DVD-ROM
    Dell 2005fpw Ultrasharp
    TT Big Typhoon + Silverstone FM121 120mm
    Antec Super Lan Boy
    Aug 2003
    New Jersey
    0
    For the tuner card, I want a hdtv tuner.
    So I was wondering if anyone here has used one and could tell me what they think of it.
    Xtreme CCIE Serra's Avatar
    Dec 2004
    St. Louis, MO
    0
    I've seen a lot of 3rd party-grade ones and a few high-quality ones... definitely a difference. That being said, IMO they all still have output that looks like ... but that being said, I have only seen them tested on really large, expensive TV's that are usually run off $500 cabling and $2000 receivers. For regular home use, a higher-end one would probably look just fine.
    Serra
    Aug 2003
    New Jersey
    0
    Well I'll have a 42" 1080p tv/monitor. DVI connection.
    I thought someone here would have a hdtv tuner and could recommend one, other than the ati one.
    What about the pc? Would a 510 watt power supply be enough for 2 7900s, 3 hard drives and a dvdrw?
    Xtreme Member mgleason007's Avatar
    Jan 2006
    0
    Quote Originally Posted by Frisch
    These are not HDTV cards. Check out http://www.avsforum.com/avs-vb/showthread.php?t=641191
    Opteron 144 @ 9 x 280
    EVGA 133-K8-NF41 nForce 4 Skt939 Mobo
    Seasonic S12 600W
    EVGA Geforce 7800 GT
    PQI Turbo DUAL 1GB(2X512) PC3200 2.5-3-3-7
    2x WD 80GB SATA
    NEC 3540a black
    Antec Solution SLK3000-B
    Samsung Syncmaster 900NF
    Klipsch 4.1 speakers
    Kensington Slim Type Keyboard
    Logitech mx518
    New water setup: D5, MCR220, 6002, Maze4GPU, 2 Yate Loon D12SM
    Dec 2004
    St. Louis, MO
    0
    Quote Originally Posted by eddy
    I sincerely hope you don't plan on using that as a 24/7 computer monitor and just mean television monitor.
    Aug 2003
    New Jersey
    0
    it will be both a tv and a pc monitor.
    and I don't sit in front of my pc 24 hours a day, 7 days a week. Maybe 3 or 4 hours a day, not all in a row.
    "Once you have that large display area, you'll never go back, because it has a direct impact on productivity." - quote from that Bill Gates article.
    Of course I won't be sitting 3 feet away from the monitor. I'll be 10-15 feet back
+ Reply to Thread
