Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: XStress - A CPU burn-in/stress testing tool
    Quote Originally Posted by ReadMe - XStress.txt
    XStress Readme file
    Version 1.0
    Homepage: http://www.ultimate-filez.com
    Type: freeware
    Author: AgentGOD
    How it works:
    It stresses your PC's CPU to maximum by having it calculate a very high factorial. This has proven to be more stressful than Prime95.
    Remember, monitor your system temperatures wisely, and don't let your CPU fry!
    Requirement(s):
    Microsoft® Windows 98SE/ME/2000/XP/2003/Vista/XP x64
    AMD Athlon(tm) Class CPU (or higher) / Intel® Pentium(tm) Class CPU (or higher)
    64 MB System RAM
    Microsoft .NET Framework 1.1 (or higher)
    Standard Usage:
    Type in the amount of threads to use, and type in the digits (in trillions).
    Ex: 2, 14 would give you 2 threads, and 14 trillion factorial calcuations.
    This program was based on Prime2006 (an older version of the stress testing program).
    Download Link:
    Here
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
    Small Update:
    Shows time elapsed after calculating (cancel or completed)
    Da Goose
    Oct 2005
    Chicago
    nice find
    i7-860 Farm with nVidia GPU's
    Not to offend you or anything, but I think you missed out the author name...
    Another update!
    Now supports any amount of threads (as long as you have sufficient system memory, and your CPU can take the heat)
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    i like the multi thread.
    but im skeptic of wether it can stress more than SNM.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Before burn-in: Stable at 2721 MHz @ 1.57v
    After burn-in: Stable at 2732 MHz @ 1.55v
    May 2005
    Camping your spawn :)
    how long of a burn have you used, and im sure this is gonna come up, so ill go ahead and throw it in first
    A64 cpu's cannot be burned in, whats actually happening is that the thermal compound between the IHS and the core takes at or around 200 hours to get up to operating thickness to be able to make good enough contact with the core to make someone think they've actually burned in their cpu to a higher lever when actually all youve done is break in the thermal compount..
    Im in no means downing your proggie or ur overclock in anyway dude, I have actually downloaded it myself, I just knew this would eventually come from someone here because this has been a hot topic here for a long time, I just wanted to beat someone else to the punch
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
    Xtreme Gentoo User
    Mar 2004
    England
    Will this put as much stress on the system as dual Prime95 at priority 9 with 1024-4096 in-place FFT's? Not gonna switch until I know, since that's my primary method of stability testing right now.
    EDIT: Still gonna try it out anyway though
    Mar 2006
    I don't like Prime95. I've managed to run it for 16 hours without an error, but then ran Aquamark 3 and my PC crashed just 30 seconds into it.
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by pete5990
    maybe psu couldnt handle the extra load your gfx card was putting on it
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    To prove this ain't usless:
    (Higher the better, in this case, the purpose is to: Stress the CPU as much as possible)
    XS News
    May 2005
    FL
    Quote Originally Posted by Philosophy
    Thank you for explaining and settling this claim, was getting bothered of not finding an answer.
    i7-3820
    SB Z
    16GB 2200
    GTX690
    1KW Lazer
    May 2005
    will give it a try though, if it heats better than prime its definately a good way to break in the thermal crap amd uses..
    Currently rosetta does its best to try and acheive the same efforts for me :P.. Alas to no avail, still @ 2.7
    -Emo Philips
    I am Xtreme
    Apr 2005
    Upstate, NY
    I'm running this on the School Dell ATM, see how loud I can get it to be
    Nick
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Aug 2005
    @ Philosophy
    Now what if I tell you I ran my cpu for a month without thermal compound (laziness), and I still got a voltage drop and mhz increase burning in? (going from 1.62v to 1.56v and from 2450mhz to 2520mhz).
    Jochenp
    Patriotism is the conviction that this country is superior
    to all other countries because you were born in it.
    -- George B. Shaw
    Aug 2005
    Oh, and the "you've broken the TIM under you IHS"-argument won't work either : I have my chips naked
    Jochenp
    -- George B. Shaw
    May 2005
    Small changes in thermal conductance don't account for the large changes in overclocking stability.
  18. #18
    I am Xtreme
    Apr 2005
    Upstate, NY
    Prime 95 heats my CPU up 2*C more than this?
    Nick
  19. #19
    For best effect... use 4 threads for each core of your CPU. If it only has 1 core, use 4 threads, if it has 2, use 8.
  20. #20
    May 2005
    I get a "this program failed to initialize properly" error every time I try to run it.
  21. #21
    You need Microsoft .NET Framework.
    Get it here.
  22. #22
    May 2005
    I tried it with 8 threads. It gives off about the same heat as Prime95. Nothing compares to CPU Burn which gives off 6C more than Prime95.
  23. #23
    Aug 2005
    try toast or k7burn, it's 4c higher than cpu burn for me
    -- George B. Shaw
  24. #24
    Nov 2005
    Quote Originally Posted by AgentGOD
    Download Link:
    Here
    Compared to StressCPU this is a joke! OTOH, since StressCPU uses SSE and the Gromacs scientific engine, it can potentially crash any pre-revision E Athlon so this is more AMD compatible.
    On a positive note, running 2 threads of X-Stress on my HT P4C lowered my cpu temp by 4C compared to running a single thread of F@H! Maybe you should market this as an alternative to system idle process?
  25. #25
    Aug 2005
    Hey, don't bash other people's software
    He did a very good job IMO
    -- George B. Shaw
