    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 12 of 12
Thread: Enermax 550w Vmods
    Jan 2003
    Leicester UK
    Enermax 550w Vmods
    Anyone know anywhere I can get info on volt modding my Enermax 550w?
    I'm looking to do a 3.3v and 5v mod.
    Jan 2003
    Leicester UK
    BUMP
    Jan 2003
    Nottingham, England
    I noticed your sig, how did you get 1.8v on an xp1700 TBred B with the msi 745, did you V pin the cpu? My bios only goes up to 1.7v with that chip, and it undervolts, so like 1.65v actual
    Jan 2003
    Leicester UK
    I did a VCore mod on the 745 Ultra to get 0.15 to 0.175 more volts than what's set in the BIOS.
    Nov 2002
    Bangkok, Thailand
    try searching at www.amdforum.com
    1. A7V8X, 1800+ AIUGA0241 @ 1.66Ghz @ 1.5V air-cooled, 256MB Samsung PC2700
    2. 8RDA+, 1700+ JIUHB0308 @ 2.7GHz @ 2.1V, Vapochill PE R-22), 2x256MB OCZ PC3500
    May 2003
    Greece---->Edessa
    Hipro5 please reply here.....
    Walrusbonzo hipro5 has a enermax 550 full modded
    P4 3.0C |Asus P4C800-E dlx |1GB Mushkin 3500 Level II I Antec TruePower 550
    WD Raptor 74G +160GB Seagate | ATi radeon 9800pro Club 3D@440/820
    Watercooled Pc. Cpu/Vga block by 11 | Eheim 1048 |LG Flatron 1730s
    3D Mark 2k1SE = 20949Marks
    Apr 2003
    Denmark
    Here you go but be careful it is a long tread!!
    http://www.amdforums.com/showthread....threadid=54084
    The man with the littel Barebone!
    And proud Crew of!!!
    Octeamdenmark.com
    Shuttle SX38P2Pro Barebone E8600cpu and HD4870X2 gfx and 2gig Crusial Ballistix PC8500 Cl5 and 2x150gig Raptor in raid 0 and 1x750 gig seagate
    Msi 790FX-GD70 Mobo Amd 955-965 PHII cpus and 2gig Crucial value PC10600@800mhz 7-5-5-15 1T
    And 4x500GB Seagate 7200.12 in raid0
    4xHD5770 in CFQ.
    [SIGPIC][/SIGPIC]
    May 2003
    Tx
    I HAD TO mod mine after all that reading. I left it off for about 6 hours and used a milti-meter to make sure I wasn't going to get deadly. Took about 20 minutes in all.
    GF4 MX440 - <8,629> 3Dmark01
    Radeon9500Pro -<16,871> 3Dmark01 | <39,167> AquaMark3
    5900Ultra - <21,127> 3DMark01 | <57,320> AquaMark3 | <7,444> 3DMark03
    Radeon9800Pro - <23,791> 3DMark01
    P4 3C @ 3.9Ghz | 256MB XMS3200 x2 | P4C800-Deluxe |
    2100+ @ 2.35Ghz | 512MB PC3200 | A7N8X-Deluxe |
    www.Badasscomputer.com Folding since 7/20/03 (Not Folding = User Error )
    I am Xtreme
    Dec 2002
    Interesting read, I'll try it out as soon as i get a mobo with pci/agp lock.
    Kin Hell
    Guest
    Enermax V Mods
    This is some info I got for the Enrmax 350W PSU. I am led to believe the same can be done to the 550W.
    You decide at your own risk, but I can confirm it works on the 350W PSU:
    Enermax_5v_mod_instructions
    read ALL of my instructions first, so you know what to expect.
    turn off your computer and take out your Enermax power supply, making sure to
    disconnect the AC input (the power cord).
    open up your Enermax power supply by removing the 4 screws in the cover.
    before continuing, make sure the capacitors have been discharged. to do this,
    either wait a while for them to discharge on their own,
    or discharge them with an insulated screwdriver.
    CAUTION: if you don't know what I am talking about, or what you are doing,
    please STOP RIGHT NOW!, as serious injury, up to and including death could
    occur. (power supply mods aren't for wimps, ya know...)
    remove the 4 pcb screws at the corners in order to be able to get to the
    underside of the pcb.
    find resistor # 82.
    In my Enermax EG365P-VE 350 watt power supply, R82 is
    located on the pcb just in front of the outlet fan (8x8 cm), with "R82"
    printed to the board next to the resistor. the resistor has a value of 7.15K
    Ohm .
    desolder the R82 resistor from pcb and replace with 7.5k resistor.
    note: monitor your +12v readings too,
    as adjusting your +5v line directly affects your +12v line as well.
    Results:
    Since I added the resistor. The +5 volt supply now averages
    4.85v under full load, normal load 4.98v ....
    Before the mod it averaged about 4.70v under load, normal load was 4.88v
    ps. 12v line is now 12.4v .. before mod it was 11.95v.
    Hope this will help some overclocking fans with Enermax PSU's ...
    Hope some of you find this usefull.
    Feb 2003
    Re: Enermax V Mods
    Originally posted by Kin Hell
    Results:
    Hope this will help some overclocking fans with Enermax PSU's ... [/I]
    Hope some of you find this usefull. [/B]
    Isn't there a mod where you can just use a variable resistor so both the 5V and 12V can go even higher (thinking about 5.5V and 13V)
    Any trick for upping the 3.3V also? (if possible inside the psu, and not on the outside like most of them and preferably also with a variable resistor)
    Kin Hell
    Guest
    Re: Re: Enermax V Mods
    If there is m8, I havn't heard of it. The info I posted here about the 350W PSU Mod is something I picked up off the Web nearly 2 years ago, so It's old news really. I backed up the Info file as I thought it was a Gem of a Mod for O/C'ing on Enermax PSU's.
    The original URL for the Info I pasted in Italic text is no longer available.
    Sorry I cant be of any more help.
