Results 1 to 4 of 4
Thread: LCD dark spot
    Steak for Breakfast
    Dec 2005
    N.Vancouver, BC, Canada
    LCD dark spot
    How do you fix dark spots on your LCD?
    I got something similar to this, not my own pic:
    I know when you press on your LCD it gets darker, so if I were to disassemble and reassemble the LCD will it work again? I tried using that flashy unstick pixle trick, didn't work.
    Mar 2005
    Houston, TX
    This phenomenom is called a "Mura effect"
    Check out this BeHardware article to know more about it:
    http://www.behardware.com/articles/5...ad-pixels.html
    I dont know how to fix it :P
    You could probably try using a suction cup to pull the plastic film outwards.
    A system that works like a suction cup, but that can remove air afther you place it could be a effective tool to secure the cup without applying too much pressure.
    Be careful not to apply too much pressure on the screen or use any cleaning chemicals or anything like that.
    DO NOT open your LCD bezel (caseing). The construction may be fragile and difficult to put back together without the help of special machines.
    Steak for Breakfast
    Dec 2005
    mmm it says I can probably push it to the side :P I'll give it a try tomorrow see what happens.
    XS News
    May 2005
    FL
    Good article link turok, thx!
    i7-3820
    SB Z
    16GB 2200
    GTX690
    1KW Lazer
