+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 58
Thread: have i discovered something for 754 users?
    Xtreme Guru i found nemo's Avatar
    Jan 2005
    waukegan
    0
    okay this is strange ( http://www.xtremesystems.org/forums/...ad.php?t=84445 )
    in this thread you will find that i cannot get my ram with both modules in at the same time to a very high clock ... but for some reason when i drop the multi to 8.5* 276 i can get my ram at 260 mhz with NO PROBLEM but with "1:1" i cannot even attempt to touch it .. nothing at all ... does the drop in the multiplier have any thing to do with this? i dunno why cuz before with both ram modules in it would go all sorts of wonkers and what not.
    what would change with me dropping the multi??? or i should say why would it change?
    edit, mind you this was just cuz i was soooooo bored ... now onto test 7.5*320 that should get my ram to 300 and a decent cpu speed of 2400 right? ... who says half multi's can't be useful
    Quote Originally Posted by ToTTenTranz View Post
    "ATI/nVidia drivers suckz0rs!!! I had two gazillion driver BUGZZ per second with ATI/nVidia cards and when I changed to nVidia/ATI everything got PEEERFECT! Zero BUGZ! And performance went up 2000%, the weather got better, my car suddenly has 200hp more than before and my girlfriend likes my sexual performance again!!!"
    May 2005
    Rye, Ny
    0
    dont use half multis....chips usualy dont like them
    Xtreme 3DTeam Member
    Aug 2005
    0
    Well running the half multi's means you are running a ram divider, so it could just mean your chip doesnt like running 1:1. This isnt that uncommon, however, it tends to happen more with dual-cores than single-cores, but maybe the 754's just dont have that great of memory controllers comparatively.
    New Build Under Way...
    Server:
    X2 3800+ 0601 UPMW 2.95ghz w/ 1.48v cooled by zalman 7700 Cu
    EVGA 7900gt CO Superclocked (725/875) cooled by modded AMD64 hsf
    DFI NF4 Ultra-D
    2 x 512mb TeamGroup pc4000 UTT BH-5
    OCZ 520W Powerstream
    Jan 2005
    waukegan
    0
    iyp, my chip LOVES IT lol well this old clawhammer needs all the help it can get so i'm gunna memtest is in windows ... it still might fail but before the ram couln't go over 240 "1:1" and boot into windows with both modules installed
    Sep 2004
    0
    I'm pretty sure you're running a bad divider. Try running some Pi runs with equal mhz values to see if your ram is really running @ that speed.
    Jan 2005
    waukegan
    0
    no it's running a devidor just like it should, ask anybody 8.5 multi will default ram to /9 trust me ... trust them btw i highly doubt cpu-z would misreport that and that issue was fixed a LONG time ago
    well can't get it stable .... but it's an improvement ... so it's ... something
    Xtreme Member steelballzz's Avatar
    May 2005
    earth......among the the others
    0
    man
    i have a similar issue
    my ocz pl lmtd edition bh6 will run 265 on nf4.....
    on nf3 i can run 1 stick at the time....265......if i use both sticks 220 is the max i can get....and as i feed more than 31, vdim i will get erros
    i will try that right away
    i hope it works
    STEELBALLZZ - N3RO - MARTAKIS
    ZÉ DO BENCH TEAM
    add a volt or two.....
    Jan 2005
    waukegan
    0
    hey bro, i hope it helps you a lil bit report back, let me know
    May 2005
    0
    nope
    same thing
    i really dont know what else can i do
    but thxs anyway for sharing
    ZÉ DO BENCH TEAM
    Jan 2005
    waukegan
    0
    eh, sorry to hear bro ... unless you wanna solder all the chips ontop of eachother to 1 stick ... lol that might not even work
    btw try you level settings i increased my skew to 255 and data strength to 1 on my tccd and got me to 41.1 percent pass on memtest ....
    Aint No Real Gangster WeStSiDePLaYa's Avatar
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    0
    try upping the MAL to 11.0ns. works wonders for me.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale
    2x2GB OCZ Platinum
    MSI 5850
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Western Digital WD500AAKS
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    May 2005
    0
    thnxs
    later i will try to do something about
    i just got 17k in 3dmark 2k1 with my gf4 ti 4200
    ZÉ DO BENCH TEAM
    May 2005
    0
    well
    mal 11 is a no go...so as 8.......
    but with drive strength at 2 i could manage this
    its not the 265 that this mems can do.....but its better than 512...
    ZÉ DO BENCH TEAM
    Jan 2005
    waukegan
    0
    glad i could help a lil ... wdf is a mal, i neva seen that timing or i've over looked it
    SSD faster than your HDD
    Feb 2005
    Kalamazoo, MI
    0
    Quote Originally Posted by i found nemo
    Max Async Latency.
    Jan 2005
    waukegan
    0
    ahhhhhhhhhh i c
    Jan 2005
    waukegan
    0
    anything over 7 and my sata drive says "detecting array" and i've tried it on all 4 sata plugins
  18. #18
    OC Jedi (on stand-by) Fr3ak's Avatar
    Jan 2005
    Berlin, Germany
    8
    Using 2 sticks of ram is in most cases a no go on s754 boards. I remember S754 having trouble with more than 1 double sided ram module as well...
    Playing around with mal and preamble made me boot up at 381mhz htt, whereas I was maxed out at 311 before that.
    I am now running 350x9 stable at 1.65v (1.61v according to cpu-z), so playing around with dividers and mal made it for me.
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
  19. #19
    Jan 2005
    waukegan
    0
    hmm but won't that lower the performance of the ram too?
  20. #20
    Xtreme Enthusiast high5's Avatar
    Jun 2005
    0
    Quote Originally Posted by Fr3ak
    that was the fault of memory controller on older CPUs. C0 Clawhammers were the ones who had trouble running more than 1 stick of RAM.
    there are no such problems today with Venice based A64s & Semprons.
    but even better CG rev Clawhammers managed to run 2×512MB TCCD over 270MHz.
  21. #21
    Jan 2005
    waukegan
    0
    not my cg
  22. #22
    Jun 2005
    0
    if it makes you feel better, i had the ultimate POS Newcastle 3000+ before this Sempy.
    i couldn't OC that NC past 2.35GHz, and running RAM over 230MHz required 2T. also, when OCing with 2 sticks, i even had trouble reaching 2.25GHz.
  23. #23
    May 2005
    0
    i guess it has something to do with 512 modules....
    i just slapped 2x256 bh5 old school and i went straight to superpi 32m
    the other 2x256 kit that i have...ch5 can do 250 easy
    maybe a limitation of the mobo
    ZÉ DO BENCH TEAM
  24. #24
    Jan 2005
    waukegan
    0
    well, i can hit 250 on ram
  25. #25
    Jun 2005
    0
    steelballzz, you mobo are you running?
    i have the same CPU like you (BTW what's your stepping?), and i have no problems running 2×512MB upto 250MHz.
    did you give it a shot without the divider?
+ Reply to Thread
