+ Reply to Thread
Results 1 to 17 of 17
Thread: AN832 Sli Deluxe & Vcore issues.
    Xtreme Member Chr0n1c's Avatar
    Jan 2003
    Cumming, GA
    0
    A8N32 Sli Deluxe & Vcore issues.
    Just got this board and having a big issue with vcore and my X2 4800+. On bios 1103, it shipped with those.
    Up to 1.45v works fine, anything after will not work. If I use the CPU over volt and set the vcore @ 1.3v I will get 1.5v however once I reboot the system will not post. Just black screens. wtf?
    Any info about this??? I cannot find anything at all. All I want is 1.5v...
    i7 860 @ 4Ghz - eVGA P55 FTW - 4GB DomGT 1600C7 - TorqX 64GB SSD - eVGA GTX280 @ 700/2440 - 850W Corsair PSU - CM HAF 932
    Xtreme Enthusiast Ic3man's Avatar
    Nov 2005
    Peak District - UK
    0
    You did the right thing in enabling the cpu overvolt option as this adds 0.2v to the vcore. The 'standard' vcore is limited depending on your cpu (single cores seem to get higher vcore than dualies). The max you will get is 1.62 afaik.
    Why you are getting black screens (no post??) I cannot explain. Have you tried turning the pc off when you get black screens rather than reset when you have 1.5 set in the bios? This will tell you if its an overclocking problem when it reboots, just leave it 15 seconds or so when powered off then restart. It will either boot fine with 1.5 or inform you that 'overclocking failed...press f1 to setup' etc.
    Nov 2005
    London UK
    0
    I've gone right off this mobo, because I've now had the second inexplicable CPU failure with it. With the rig on the bench (no case) my x2 3800 was running SuperPi at 2600 / 1.508v on stock HSF, temps about 49C - 51C, nothing dramatic and then BSOD and RIP. Just like that. I was using the overvolt, more for stability than anything else (it would do 1.5v without it).
    It seems mad, but I'm going to rebuild on my spare DFI Expert because I haven't had a chip death on one (yet).
    Jan 2003
    S.W. Florida
    0
    I still like this board but it's had problems with reboot since the beginging. I've tried all the bios and none cure the problem. Problems goes away when at stock settings but it doesn't seem to be exclusive to the Vcore voltage or ovrvoltage. Once you raise the fsb the problem will kick in also. Seems to happen in relation to stability. Anything short of 100% rock hard stability can cause the problem.
    Xtreme Member Barracuda's Avatar
    Oct 2002
    Greece-Xanthi
    0
    flash back to 1009 bios cz the 1103 it is not good i had several problems using it and i finally got back to 1009 and all is fine now.
    Q6600 G0
    ASUS P5E3 DELUXE/WIFI
    2GB Corsair DDR3 TWIN3X2048-1800C7DF
    2x Sapphire HD3870 512MB CF
    2 x wd raptors 74g raid 0
    2X320g wd sata2
    ENERMAX GALAXY 1KW
    PHILIPS 200 w6cs
    Xtreme Member Veedo's Avatar
    Feb 2005
    0
    i just started having boot issues with mine too, it all started when i put a new opty 146 in. prime stable for 12 hours at the settings im at, but sometimes it wont post on reboot. shut it off and turn it back on and it posts, very odd. im running a couple hundred mhz faster with this new chip, so maybe theres an issue with the clock speed being over a certain mhz? i never had a problem with my 144 running at 2.7, but now this 146 at 2.9 is showing boot issues. i think its related to vcore. i wonder if the board is booting with the voltage settings set in the bios, or maybe it is undervolting during post?
    m3a79-t | 2 sets of 4gbpq | phenom II 720be cooled by TRUE | hd4850
    corsair 550vx | 6400aaks raid 0 5000aaks raid 0 | Lian Li 1100B
    Dec 2005
    0
    Quote Originally Posted by Barracuda
    ...i had several problems using it and i finally got back to 1009 and all is fine now.
    Like what? I'm asking coz i recently upgrade to 1103 and i'm still getting warm boot. Did u noticed any stability problems with 1103?
    Jan 2003
    Cumming, GA
    0
    thank you all for the great replies. going to try everything now and get back to all of you.
    Jan 2003
    Cumming, GA
    0
    Update:
    Aha! Here we go, I think I may have sorted my problems. I flashed the bios, but it was still giving me the problems. However I did as ic3man suggested:
    And it booted right up fine and I was able to do the bench below. I have not rebooted since tho LOL so I am not sure if this will stick. I'll keep this thread updated.
    Not a spectacular run, mem was @ 263Mhz 3448, can do a lot better.
    Big thanks to stevehat1 for the chip.
    Jan 2003
    Cumming, GA
    0
    Ok well after a reboot it will still black screen instead of post. If I shut the power down wait then power on it will go straight into windows. This is in bios 1009. Only happens with vcore over 1.45v.
    Odd. Gonna try bios 703 later today.
    Jan 2003
    Cumming, GA
    0
    Quote Originally Posted by Chr0n1c
    Well 703 bis still gives me the "warm boot bug"
    Feb 2005
    0
    i went out of town for a few days, so i let my rig run sp2004 priority 10 blend for 52 hours. no errors. i am pretty sure this chip is stable, but i still get the warm boot issues, very weird and annoying!
    Dec 2005
    New York City
    0
    newbie question--->what exactly is this "warm boot bug" that I keep hearing about?...what does it mean?
    ASUS P6X58D Premium/BIOS 1501 ***** MSI GTX 580 Lightning 1.5GB/280.26
    Intel i7 980X (Gulftown) ***** Noctua NH-U12P SE2
    G.Skill PI Series 6GB (3 X 2GB) DDR3 1600 7-8-7-24 ***** G.Skill Falcon I 256GB SSD
    Lian Li PC-A70B ***** Corsair HX850W
    Auzentech Auzen X-Fi Prelude 7.1 ***** Windows 7 Home Premium SP1 64-bit
    Feb 2005
    0
    Quote Originally Posted by Titus
    when you restart the system, and it wont post. you have to cut the power and turn it back on for the system to post and boot again.
    Xtreme News Addict Pinnacle's Avatar
    May 2005
    Winnipeg, Manitoba, Canada
    0
    Yup, count me in Im having the exact same problems. Anyone email ASUS about the problem?
    "There's no chance that the iPhone is going to get any significant market share. No chance." -- Microsoft CEO Steve Ballmer
    Mar 2006
    0
    I would HIGHLY recommend ya'll run CnQ with the Asus boards. Works exceptionally well with the overvolt option enabled. I even wrote a guide on it because of the A8N32-SLI Deluxe :
    http://www.xtremesystems.org/forums/...ad.php?t=95856
    After doing this, never had issues with soft reboots again!
    Sep 2005
    0
    This isn't really an 'issue' exclusive to this board. Rather, it's ASUS's incompetence. With every single board from ASUS there are Vcore issues. Against my prior experiences, I still bought this board thanks to Wesley's wonderful review @AT as well as the *8-phase* power design for CPU. Well, ASUS will need 8,000,000-phase power design before they learn how to supply accurate, not-fluctuating Vcores.
    Nice board overall, and I like its layout as well as somewhat lower CPU temps compared to DFIs', (yes, I measured with a thermo-gun). Regardless, this will be my last ASUS board. That's for sure.
    Another thing I'd like to comment on: anybody close to AT's motherboard review team? I wish they realized the seriousness of their articles and learned not to be biased. Every single board they review break some kind of record, every time. Yah right.
    I don't check my PMs very often.
+ Reply to Thread
