Turbo pll for msi k7t 266 pro2 & Vcore troubles
Hiya,
as some of you may have read on shrimp, I first couldn't let a Tbred work on my motherboard. Finally after using an unofficial bios, and having removed a condensator, it all worked.
Now I have 3 other problems.
1) The vcore. I sucessfully did this mod and with al palomino I could reach up to 2 Vcore. Nice, but now with te Tbed I can get maximum 1.7 Vcore. What resistance or pot should I use to raise that ?
2) The fsb. The fsb is limited to 164. I know what a turbo pll is, and I understand the principe, but,
Can I Use any turbo pll for my motherboard ? And where should I find a guide to make it / Or where can I buy it?
The motherboard I have
3) The Vmem can be set to maximally 2.7. Does somebody know where to find a Vmem mod ?
- You may not post replies
- You may not edit your posts
Forum Rules
