Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Mushkin 2GB XP4000 Black Series – Test Results
    Apr 2005
    Calgary, AB
    This mem is not exactly new (been out since Aug/Sept 05) but it seems a lot of people have been expressing interest in it lately. I was given a kit to test and am going to share my results, suggested timings/tweeks, and my overall impression of the RAM.
    Test bed:
    DFI LP NF4 Expert SLI (BIOS E-1207)
    FX-57
    eVGA GeForce 6800GT
    OCZ PowerStream 520W
    Cooling - Custom H20
    The mem was very easy to set up, I just popped it in and it booted up right away @ DDR500, 3-4-3 and 2.65v. After that I went up in increments of 5Mhz testing w. memtest until I started getting errors then it was time for tweeking
    XP4000 uses Samsung UCCC chips, week 52 in this set. UCCC isn’t like UTT or TCCD where it scales to some extent with voltage. The optimal voltage is actually less than 2.7v, about 2.67-2.69v. Higher than that the voltage causes instability. Just tweek and run memtest until you find optimal.
    Secondary timings are also very important w/ this RAM, 1 setting off and you can have stability issues. See the settings below or my tweeker screenie to see what settings worked for me. *Note these settings are the TIGHTEST possible that still maintain stability at the speeds I am running the RAM. Some can be relaxed a bit, YRMV. Also what settings work for me may differ slightly for you because of system differences.*
    Command Per Clock Enable
    TCL-3.0
    TRCD-4
    TRAS-08
    TRP-3
    TRC-7
    tRFC-16
    TRRD-02
    tWR-03
    tWTR-02
    TRWT-04
    tREF-0780
    tWCL-01
    DRAM Bank Interleave-enabled
    DQS Skew Control - auto
    DQS Skew Value- auto
    DRAM Drive Strength - Level 7
    DRAM Data Drive Strength - Level 3
    Max Async Latency- 8ns
    DRAM Response Time - Fast
    Read preamble Time- 5ns
    Idle Cycle Limit- 32clks
    Dyanamic Counter - Enable
    r/w Queue bypass: 16X
    Bypass Max - 07X
    32 Byte Granularity - Disable (4 bursts)
    Vdimm-2.67v, 2.71v in BIOS (Expert undervolts)
    For the top end of the RAM, I managed to squeeze 280Mhz 3-4-3-8 2.67v:
    How about some 3d action:
    290Mhz 1M:
    Same settings, SP2004 large FFT still running:
    Your results will depend your system, OCing abilitys/skills, and a little luck. Overall I think this mem is great bang for the buck. A 2 gig kit that has a potential to hit these kind of speeds for ~$200 speaks for itself.
    XP4000 UCCC (#991483) is in stock and avail at these places:
    Canada:
    Memory Express
    NCIX
    Kit-tronics
    USA:
    Newegg
    Monarch
    Fry's / Outpost
    MB Reviewer for HWC
    Team OCX Bench Team
    Jul 2004
    china-shanghai
    Oh Man Nice Ram Great !
    CPU PII 940 oc to 3.85G
    MB ASUS M4A79 DLX
    VGA ZOTAC 295
    RAM Mushkin REDLINE 4096M
    LCD EIZO 24 LED
    HD WD 320G 640G ST 500G
    DVD-RW PIONEER 218 115
    SOUND CARD A2ZS with cambridge soundworks 4.1
    MOUSE MX300 MX1000 WITH ICEMAT2
    POWER CORSAIR TX850W
    Xtreme Cruncher
    Mar 2005
    I like it! Time for me to start tweaking my RAM again (now that somone else is doing the heavy lifting). Thanks Eldonko!
    Bloodrage || 920 @ 3.2Ghz || TRUE Black
    3x 2GB HyperX 2000 || @ 2000Mhz 7.7.7
    2x 300GB WD VR Raid 0 || 2x 2TB Samsung F3 Raid 0
    LG 10x BD-R || LG 22x DVD/RW
    MSI GE 470 || LG 246WP
    Sonar X-Fi || Klipsch 5.1
    Lycosa || Mamba || Exact Mat
    CM ATCS 840 || Seasonic M12D
    Server 2008 R2 x64
    Dec 2004
    Seattle
    Looking good Eldonko. Highest 3-4-3-8 I have seen outside of Gigi77's 290mhz action. Keep up the great work and hopefully your SS is fixed son for ya.
    Tim
    P.S. mind posting over at OCX?
    Apr 2005
    Calgary, AB
    Quote Originally Posted by Cpt Twitchy
    Tim
    Thanks guys. Sure I'll post @ ocx.
    MB Reviewer for HWC
    Team OCX Bench Team
    Dec 2004
    Seattle
    Quote Originally Posted by Eldonko
    Thanks Man, Just saw it over there and well its almost time to go to my next class.
    Oct 2002
    IL
    better than my kit
    I can get 275 or so at 3-4-3-8
    but I did clear 295 at 32m super pi but it was only semi stable otherwise. IE would fail back to back runs, 3d was fine though.
    I think for 24/7 I'd stay at 280 3-4-3-8 vs 290 at 3-4-4-8 which is where I think my kit would top 24/7
    nice kit though. Seems UCCC is very dependent on batch week codes. I know I played with a certain week batcht that toppped at like 265 or so . Others just fly though!
    it's never fast enough!
    Apr 2005
    Calgary, AB
    Yeah it seems like some of the later batches clock very well.
    MB Reviewer for HWC
    Team OCX Bench Team
    Corsair Components, Inc.
    Dec 2003
    San Francisco, CA
    Very nice results, Eldonko Another great set of UCCC at a very attractive price
    I work for Corsair Components, Inc.
    Xtreme Legend
    Dec 2003
    Northern California
    Looks like nice RAM. Good job with the testing, Eldonko.
    Xtreme Cruncher
    Mar 2005
    Haven't seen you in a while Sierra - how's it going!
    Server 2008 R2 x64
    Xtreme Legend
    Dec 2003
    Northern California
    Hi. I'm fine. I mainly lurk these days. Nothing to brag about.
    Xtreme Guru
    May 2004
    the cold place Temp: 5C
    I want high speed 2GB memory sticks. Stop exciting me with these titles, clearly label it as 4x512MB or 2x1GB.
    For those of you about to post:
    Feb 2006
    Paris (France)
    ok, I did just crack ans order one pair of this jewels
    Mar 2006
    Great Post Eldonko.
    I have a few questions if you please! I am a NOOB in OC, so I do apologize.
    I tried those exact settings with no overclocking (except 2 exceptions)..... I have this memory.
    My pc would not even boot?!
    2 exceptions:dqs skew value: says auto, but mine does not have that options, it wants a value 0-250?
    Do you set the dram frequency?
    My ram says ddr 400 3-4-8-3 on boot up, no matter what I put?
    I think not setting my memory is the only reason I cant get a stable overclock, so any help would be appreciated.
    I can get into windows with all kinds of settings (12x240) (13x 228) but the second I run benchmark its hard locks. Here is my set up. thx in advance!
    DFI Lanparty UT NF4 Expert
    AMD Athlon 64 FX-60 @ 2.88
    Mushkin XP4000 2GB
    2 x 7800GTX 512 in SLI
    Creative XFI
    Raptor X
    Pioneer 109
    Seasonic 600w
    Coolmaster stacker 830 with 2 120mm fans
    Running latest Bios.
    Cpu throttling disabled
    Fsb 240
    LDT 3.0X
    Cpu FSB 12X
    pci freq 100
    cpu vid start up 1.525
    hit 2.88 on air stable. Ram is stock timings - not sure what to set with this mushkin xp4000.
    Apr 2005
    Calgary, AB
    Don't worry about skew, leave it at 0. Dram freq is @ 200 for me (RAM/FSB 1:1) but you want to set that according to your OC.
    For example, ff your CPU does 2880Mhz, set 11x 260, mem clock @ 1:1. This will give you 2860Mhz and 260 on the mem. Keep LDT @ 3x.
    Welcome to XS by the way.
    MB Reviewer for HWC
    Team OCX Bench Team
    Mar 2006
    When I go higher, my proc locks... is that just the limit of my cpu?
    Why cant I set ram timings and boot?
    Thank you very much! I am new to all of this, and would be happy with 3 gig dual core
    Just dont know how to get there, heh.
    Also: IF I set the above settings and it works stable... what adjustments do I make to see if I can go higher? Upping the fsb? thx again
    GO FLAMES! Will be seeing them play Anaheim in San Diego (April)
  18. #18
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    Quote Originally Posted by Mr.Kakarot
    Ahhh... ALthough you have the same sticks as him, but YMMV due to many reasons.
  19. #19
    Mar 2006
    Quote Originally Posted by Bail_w
    Well I just thought it was the manual timing for this ram... so I thought it would work.
    Would changing to that bios help anything? thx
    On my old ram, I could hit 2.98 stable.... so I hoped to hit 3 gig...
    now even 2.98 would be nice!
  20. #20
    Apr 2005
    Calgary, AB
    Mr.Kakarot, to make OCing easier, you should find the limit of the CPU and RAM separately. After you have that, you can set the optimal freq for both. You find the RAM max by using a low multi and increasing FSB until you start getting errors in memtest. Test the CPU by using a divider for the mem and test in windows with prime or PI.
    eva2000 wrote a great guide explaining everything you need to know for A64 OCing, find it here.
    MB Reviewer for HWC
    Team OCX Bench Team
  21. #21
    Mar 2006
    Sorry for being such a noob!
    Just with my old ram and the timings, I hit 2.98 no problem.
    Now with this "better" ram I cant hit 2.9?!
    Also if I set the Dram freq to 1:01 my ram reads as ddr400 (that normal)?
    thx
  22. #22
    Apr 2005
    Calgary, AB
    thx
    What program are you using to show RAM speed?
    MB Reviewer for HWC
    Team OCX Bench Team
  23. #23
    Mar 2006
    bios boot up screen.
  24. #24
    Apr 2005
    Calgary, AB
    Use CPU-Z to check your mem speed. Its always going to say that in BIOS.
    MB Reviewer for HWC
    Team OCX Bench Team
  25. #25
    Mar 2006
    Finally got the settings to stick! Thx alot man, great thread and help!!
