Anyone seen any reviews on the Swiftech MCW60 where they put it up against the Maze4?
I haven't been able to find one...
Intel i7 3770K @4.7GHz (1.224v) | Gigabyte Z77X-UD5H | 8GB Samsung DDR3-1866 | EVGA GTX 780 Classified
Corsair HX850 | X-Fi Titanium HD | ATCS 840 Black
Apogee XT | DDC-2 w/ XSPC Top | XSPC RX360
Nope - too new a block (MCW60) for anyone of any merit to have done such...
Best bet is to wait till Maxxx gets round to doing it in a week or 2, but seeing as its not v different from the MCW55, chances are its just as good or better... which would make it a pretty good block, and those ramsinks make it a winner, imo
Originally Posted by Bloody_SorcererOriginally Posted by MaxxxRacer
after OCIA's review of the Apogee, i wont even click on that link.
FWIW, i'll be reviewing the MCW60 vs Maze4 vs MP-1. Probably won't be as in depth as what Maxx or a site like Procooling, but my intentions are to test the blocks by themselves in the loop(no cpu block) and against the 5 different pump settings of the D5. It's the best I can give ya folks for what I have. But I think it'll provide more information than just "this block gave me 1C better temps than this block at full load"
~MadMikeSS~
Intel Q6600 G0 @ 3.2GHz 1.31v - AX MP-05 SP LE cooled
P5B Deluxe 1236 BIOS
HIS HD4850@750/1100 - AX MP-1 cooled
Mushkin 4GB(1GBx4) DDR2-800 5-4-4-15 1.9v
FSP 700W PSU
Lian-Li PC-V2000B
I would to see that. IF if its that much better I might have to give up my maze 4
3000+ Venice E6 Apogee|Maze4||Heatercore|Hydor L35
DFI UT Lanparty NF3 250GB
2x512 G.Skill DDR550
ATI X850XT PE
2x40Gb Maxtor Raid 0|250GB WD Sata150
Audigy 2
Lian Li PC-6077
OCZ Powerstream 520
Im thE CsS player that pWns you!
I dont think it will be very different, its just that its tall enough for those ramsinks, which are sooo nice if you dont have a fan blowing on the card.
Yeah, plus the MCW60-Ramsinks combo price when compared to the Maze4 makes it very attractive.
creidiki, why not to buy those ramsinks separately?
http://www.frozencpu.com/vid-54.html
Because theyre too high to fit with a Maze 4. I dont really feel like shaving them off to fit, cause ill be left with about half the sinks.
Also, i canna get them in the uk, captain. *looks pointedly @ marci*
And as Makubex pointed out, the price of the MCW60 + Ramsinks vs the similarly-performing (probably) maze 4...
I just happen to have a maze 4 and an mcw60 sitting right in front of me here, the barbs for both of these blocks sit at the same exact height. I will take pictures later to show. So if the ramsinks work with the MCW60, they should be fine for the maze4, unless of course you are talking about the low profile maze 4 in which case they won't work. Matter of fact you'll have issues with the copper OCZ ramsinks that DD sells also, I did with my 7800 GTX and my low profile maze 4 and the OCZ ramsinks, had to modify one of them that was under the barb to fit.Originally Posted by creidiki
~MadMikeSS~
FSP 700W PSU
Lian-Li PC-V2000B
Hmm, really? I always thought the MCW60 was higher. Seems I was wrong, good! ^^
In that case, if someone in the UK gets some ill have to order a set, the OCZ ones arent that good with the unfocused airflow in my case.
any updates?
| NZXT H630 (White) | ASUS Maximus VI Hero | Intel i5 4760K | CORSAIR Dominator GT 8GB @2000MHz Memory | MSI Gaming Twin Force GTX 770 2GB @ Power Limit + %185 | ASUS Xonar HDAV 1.3 Deluxe Audio Card | Philips amBX Premium Kit | Nvidia 3D Vision 2 |
Originally Posted by Bad213Boy
MadMikeSS's review is here -
DangerDen Maze 4, AquaXtreme MP-1 and Swiftech MCW60 Performance Comparison
http://www.3dxtreme.net/index.php?id...ockcomparison1
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
i have the mcw60 with the sinks. on my x1900 (bought it like that) And 2 of the sinks are cut down. havent checked if it could be worked around...
nice review of alle the blocks. but a theoretical test on a diesim would have been more interesting as differences are better to sort out there. the differences can easily turn the opposite with a second mount. in a theoretical plattform, you could simulate more watts (r580 or even R600) and sort these issues out with multiple mounts.
I am impressed with how little these blocks scale with flowrates. That makes one thing clear again: Laminar flow blocks or blocks without nozzles or jets or other turbulence creating devices do not scale with flowrate in a normal watercooling setup in a measureable way.
ahh so they rate the MP-1 with a slight .5 degree better.
MC14 are very tall heatsinks and can't be mount underneath the barbs on both Maze4 and MCW60. I have a Maze4 with MC14 and they need to be cut down to fit.Originally Posted by MadMikeSS
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
Screw the die sim. I think pulling a block for a working loop and replacing it - keeping ambient and everything else the same would be much more indicitive of real world performance that using a die sim. Simulation and real world are much different, i prefer real world.Originally Posted by davidzo
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
I bent mine octopus style, (have to find my camera, grr).Originally Posted by creidiki
