hey guys
i just bought 2 semprons and a dfi nf3
i gathered an S3 virge pci....300w oem psu......256 twinmos ch5
prometeia mach I
my friend martakis.....and this
validation
very nice for a 110 € chip
hey guys
prometeia mach I
validation
not that great, this has been beaten on air with a chip 200mhz less stock speed
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
Look at a users OCs named Fl@me. You been beaten. Trust us. Its more impressive when done on air like most here do. Low FSB just hurts your OC score even more. Your really running slower because most who get 3200mhz are doing 400+ Fsb with lower model semprons. The super locked multiplyer is really killing you. You would have been better off with a 2800.Originally Posted by steelballzz
really
i dont see the point of this comments.....
per cpu-z search database this is the 3100 palermo with the great validation so far
maybe i choose the wrong place to put the score.....why theres different categorys....?
if theres a 3100 with more than 3144 is not validated on the cpu-z database
can u link me to it....
nicely done!
would this be the same palermo core like the old athlon XP's
Allendale 15sec pi
x800gto 42k2001
Coolermaster ATC 310
1.5Tera
its not impressive because its on sub zero cooling, and still a couple mhz off the record for E6 semprons even though your chip has higher stock speed.
so, even though it has way better cooling, it still doesnt even match slower stock speed chips.
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
Nice oc, but I also doubt that its a wr.
And why do most ppl place their hdds upsite down? According to Hitachi/ibm you can place them 90° and 0°,but 180° stillhurts the heads...
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
do u compare all the amd cpus....or there is a category for each one?
grumpf
since when subzero cooling on extreme systems is not good....cause u dont have one...?
u dont like my score....i saw that...enough said...
dont need to diminishe other ppl....after all its my 1sr WR.....cause its a WR no matter what u said......and the only smart thing for u to do is try to overtake my score
Its still a nice oc and that is what I said, but to be honest its not that great, because there are ppl with a 2800+ hitting 3280Mhz on air. So anything above 3.3ghz would be really awesome in my eyes.
オタク
what he said.^^^
its not that sub zero cooling is bad. its just the fact that it IS sub zero cooling, and still not beating slower stock chips on air.
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
No-Coldbug
Maybe I have to go back to the budget overclocking and try to get my Palermo 2800+ WR back .
Steelballzz up the volts and go on OC,ing, My old 2800+ Palermo reached 3047Mhz @ 1.93V with boxed cooling with room temps around 20c , The chip still works great.
Congratz Portuguese mate..
Keep on.
Originally Posted by WeStSiDePLaYa
not to be a prude, but it's a known fact that 754 chips don't o/c as well. silicon is not as good in other words. it could have been better, yes. but i say good job for you & ur lil' chip
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
I wouldn't say that. 1,400MHz (air) on my 2800+ is pretty good.Originally Posted by i found nemo
“I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.” - Stephen Roberts
???? 1,400 mhz is actually slower than a 2800+ is rated ..... right?
mobo: strix b350f
psu: coarsair 1kw
An overclock of 1,400MHz...Check my link validation file. Most 64-bit Semprons will overclock at least 1GHz easily,given the right mobo. I've had five now,all but one did over 1GHz stable,and that one was not a 64-bit Sempron.Originally Posted by i found nemo
yeah, i got 2.84ghz STABLE on water with a chip with a 8x superlocked mutli. no up or down.
he got 3.14ghz suicide with sub zero cooling with a chip 4-9x multi. and 200mhz faster stock speed.
also, people have gotten higher than his with a 2800 on AIR. this is a faster chip stock and on sub zero.
see what im saying.
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
no man
i dont see your point
i didnt made the WR chart.....someone did....and they divided into categories....see.....
so your 2800 has the WR for semprom 2800 and the semprons overall.....my chip has the WR for 3100 palermo and the 2nd best score overall the categorys of semprons
if u cant understand this......
stop hijacking my thread...and stop the talking about your 2800....this is not about 2800+....its about a 3100 palermo
if u have a validation for a 3100 higher than mine plz post....if not....well...enough said
That's great result man, and it is WR
That was a great effort.
You just need a 4000+ Newark underneath your cooling and these boys would be getting out of your way...
Just like you want a 4000+ Newark, I want some sub-zero cooling like yours...NOW!
HURRY UP OCZ!!!
Before the Newarks I would agree with you but the 3700 last year and now the 4000+. These chips are running conservatively on air 3100MHz and 3200MHz on a good water setup. That little screenie I had at 3388MHz was just at 80F. With this guy’s cooling, lidless and a 13 multiplier...look out!Originally Posted by i found nemo
So, a lucky clocking chip on air is more impressive than normal clocking on subzero? You can't always get the best clocking hardware out there, sometimes the only way to fight it is to freeze it n juice it. IMHO its more impressive that way...Originally Posted by WeStSiDePLaYa
Originally Posted by Gautam
i dont get excited about average clocking.
yeah, dude, you can have your victory, doesnt change the fact it cant keep up with slower chips even though its under phase.
i could say i have the WR for 2800+ 35W newcastle mobiles too, just because nobody else spent the time to bench it. doesnt change the fact it could be beat by a regular newcastle chip.
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
steelballzz,I forgot to mention,nice OC and congrats. I think its a great OC considering its a 99.00$ chip.
