And here's the 32M :
Previous system:
DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
BH-5 is nice but TCCD is as good for SuperPi:
If only this ram would allow me to run trcd@3...
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Nope they aint..Originally Posted by Zeus
EDIT:
Is that a WinXP 64bit?? - Looks like the std. background - If it is, thats why, 64bit XP gives a slightly better time..
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
Spectating;
2010; GOOC 2010 Many thanks to Gigabyte!
They aint?
Care to elaborate?
It's just plane XP pro w/ SP2, background is one of those apple wallpapers.
U can touch BH5 in SPi, if u have a 27Mhz plus with the TCCD, but only with 2.5-3-3-5 and really tight subtimings.
Edit: Sure with 2.5-4-3-7 too, but u need much higher clocks.
PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
And IMO BH-5 is easier to handle - tight the timings and bump the voltage, that's all.
TCCD is a bit more tricky and takes more time to find perfect settings.
Previous system:
Amd Nvidia/Ati -3dmark06 scorebord revisted
asus L1N64-ws or /b depending on bios chip
4x1gig 8500 gkill bpk
2x opteron 8224 @ 3.8ghz
http://www.xtremesystems.org/forums/...&postcount=236
vga= 8800gt
winxp pro
custom chiller -31 water
2x dtek fuzions
bix3-with x3panaflo hi output
antec 850 quattro
heat under msimax abitmax and dfimax
+Originally Posted by msimax
Previous system:
I have an extremely dumb question. What did you do to get that font?Originally Posted by afireinside
For some reason my daily XP install has the same weird font, and scores unnaturally well in SuperPi.
Neways some rippin clocks and times in here, nice job all of you.
Haha I have no idea. I just set windows appearance to best performance and off I went.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
Originally Posted by HARDCORECLOCKER
I donĀ“t think so, i have much more problems with my BH6 because the 166 diver worked only with 1 of some CPUs. I had never troubles with my Tccd they allways worked fine with 308 2,5-3-3
Maybe it's the same old question like the one if INTEL or AMD is the better chip..........
Previous system:
great
the same time as my little 30$ Pentium M ...
