I think 45C on the expert is way above 50C on the non-expert so that may be kinda high.
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
Everybody should read FAQ on CBId to uderstand the Thermal Offset.
A linky would have been useful!Originally Posted by VVJ
http://cbid.amdclub.ru/pdf/cbidfaq.pdf
From experience of 2 Expert boards, I can say they report 8C to 12C too low. e.g x2 3800 dual primed 2500 stock HSF 43C in Expert, 54C (max) in A8N32 (assuming the Asus is near the mark, it's about the same as an Asrock Dual). I should say that the thermal offset is 5C, so 49C is closest figure to reality.
So does that mean what I said originally was correct? Is that calculated before your temp is displayed in MBM5/whatever or do you have to add/subtract yourself?Originally Posted by VVJ
Rig #1 | Opteron 165 (2898 @ 1.35v) | DFI nF4 Ultra-D | GSkill ZX 2x1GB | HIS X1900XT 512MB | Seasonic S12 550w in Antec P160
http://www.last.fm/user/repoman0/
@ VVJ and Repoman. I am confused as well.
Not familiar with the program and it doesn't load driver in x64 (primary OS)
This is a screenshot of CBID (latest) in XP Pro on an Ultra-D.
Are you saying my Opti is reporting 9 degrees too high?
http://premium1.uploadit.org/soundx98//CBID1.JPG
An external temperature sensor, for example any Winbond or ITE super I/O chip, uses processor’s on-die thermal diode to measure its temperature. Diode offset should be always subtracted from the temperature sensor reading. I suspect software doesn’t use the thermal offset at all. MBM is too old and doesn’t know about this parameter. Authors of Everest and Sandra don’t know an actual purpose of it at all. The best way to check whether the thermal offset should be subtracted or not is to make a comparison of the room temperature with the processor’s one on start.
Yeah, I'm doubtful now you say that. My s754 Venice @ 2550 / 1.44v running 100% on rosetta@home is hitting maybe 35C indicated on water, room about 20C. The offset is 13C. Is it really running at 22C then? I'd like to think so, but I have serious doubts. I need an independent method, like a water temp thermometer.
I have read a lot of technical documents and each define the same statement: “diode offset should be subtracted from the temperature sensor reading”.Originally Posted by stone_cold_Jimi
OK, I must check the water temp. It's cooler than ambient for sure, so it might just be true. Dual BlackIce Extreme rad, 2x 120mm fans, maybe, just maybe.
This is my other Opty 146 CAB2E 0540FPMW.
A 20 degree temp offset? One has a 9 degree and the other 20 degrees in virtually identical rigs. Just doesn't seem right
http://premium1.uploadit.org/soundx98//CBID.JPG
I agree, it seems unlikely - unless it's added on. Look at this (13C offset):Originally Posted by soundx98
http://xtremesystems.org/forums/show...&postcount=350
It's far more likely, given the voltage, that the 34C indicated figure is 47C true rather than 21C (ambient was about 20C). I really don't know what to believe, tbh.
Just an FYI: CBI offsets are completely useless in determining your actual temperatures... My CBI offset reads -8C when my chip actually reads 16C low! (which would mean CBI should say -16C instead)Originally Posted by Repoman
trust me, if there was an end-all software solution to solve all of the Expert mobo's temperature reading problems, I'd hopefully know about it, and give the person who wrote it my first born! (lol, i kinda helped lead the charge over at DFI street to get temperature readings fixed...for awhile...but, needless to say, i dont think DFI cares anymore... )
Sooo, using some mathematics AND proper testing with a thermal probe, I came up with my real offset that i set manually in MBM5... and even THAT is probably off by 1-2C!
I said it over at DFI, and I'll say it again: I sometimes think it's hillarious when you imagine all of the things your computer is capable of, such as searching for ET, rendering billions of polygons, and calculating 32M PI in minutes; BUT, the damn thing cant even tell you the temperature of its main component within 1/2C!!?! How long ago was the digital thermometer invented?! lol... oh the irony!
- palehorse -
CASE: Antec Three Hundred Two
CPU: Intel Ivy Bridge i5-3570K (OC'd to 4.2)
GPU: (2) Powercoler HD7870 Myst 2GB (Tahiti) in Crossfire! (OC'd to 1100/1550)
SSD: Samsung 840 Series 250GB
MOBO: Asrock Z77 Extreme4 ATX
RAM: Crucial 2x8GB Ballistix Sport (OC'd to 1866)
PSU: Corsair TX750M
COOLING: Cooler Master Hyper212 EVO
Thermal offset is a specific parameter for any processor and is programmed at the factory while technological testing. A correction to the offset may be needed for some temperature sensors. Contact the temperature sensor vendor or motherboard vendor to determine whether an offset correction is needed.Originally Posted by palehorse
It's a shame that nextsensor program doesn't support any of the latest boards that use the ITE8712F sensors. Is anyone doing any work on that?
Thanks for the information and keep us informed of any updates.
You’re mistaken! There is no any shame. NextSensor supports IT8705F, IT8707F, IT8708F, IT8710F, IT8711F, IT8712F and the latest IT8716F. It will be released in a day or two. I just need more time to test it completely.Originally Posted by soundx98
Fantastic news. I'm very excited to try the latest version as well.
Will the program automatically compensate for the Thermal Offset or is there a plug-in you can help us through?
Thank you for all your efforts. I'm willing to test an alpha/beta if I can help in any way.
@VVJ - thank you. You have PMs and some comments.
Respect
I run 24/7 1.65v on a opty and its fine. Also did on my 3800X2.
Temps ok then 1.6-1.65v is fine
this might sound like a dumb question...under brain identifier..pstates...says....-7 for thermal offset...is this -7C or F?...nevermind I see -7C...DOH
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
just did some quick math...if pstate says offset is -7C that would equal 19.4F now in motherboard monitor when I select to compensate cpu temp under celcius to -7 in the farenheit portion it changes to -12 instead of like -19 ....understand what I am saying?
DFI UT X58-T3eH8
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
16 X NEC DVD Burner
Watercooling Loop:
1 X PA120.3
1 X PA120.2
1 X Swiftech GTZ
You need to add no take awayOriginally Posted by Grinch
Originally Posted by hlonipha
so you are saying that negative 7 means....add? is this just for expert boards or all boards?
DFI UT X58-T3eH8
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
16 X NEC DVD Burner
Watercooling Loop:
1 X PA120.3
1 X PA120.2
1 X Swiftech GTZ
-7 means ur board reads temps 7c lower than real.
anyone know why my fx-51 reads 22c? not negative
Originally Posted by Call me Ugly
I think it is all wrong and I will go by a thermal probe...
DFI UT X58-T3eH8
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
16 X NEC DVD Burner
Watercooling Loop:
1 X PA120.3
1 X PA120.2
1 X Swiftech GTZ
