Does anyone know of a reason I should not mount a 120mm fan in the door of my chieftec.
Because Kurupt would be jealous. :p
Well i won,t post pics after i,m done ! That way he won,t know. By the way new mobo came today.Originally posted by DaGoochMeister
Noooooooo! You must post pictures! I am sure you will be very happy with the motherboard. A lot of options to tweak and no modificiations required to the voltage controller chips for Vcore and Vmem.
I will be asking lots of questions when i,m ready to start install.Originally posted by DaGoochMeister
[beavis]
DOOOO IT
[/beavis]
Alllllrighty then!Originally posted by JBELL
[beavis]
DOOOO IT
[/beavis]
One more question, how do you tansfer the template to the door.
NOOOOOOOOOO!!!!!Originally posted by Hardass
Alllllrighty then!
I can't stand fans on the side of cases. They suck ( )
But really, I think it looks tacky myself. But if you can get ingenious with it, go ahead. Good luck!
That,s why I am doing it, Because they suck.Originally posted by Smizack
NOOOOOOOOOO!!!!!
HAHAA!Originally posted by Hardass
I just didn't like my first one at all after I did it. But then, I felt the same way about the blowhole.
I don't know... I just like a clean look, and having fans hanging all over the case just turns me off.
But i need air!!!Originally posted by Smizack
HAHAA!
If you like it, do it!Originally posted by Hardass
But i need air!!!
I just never liked it, soooo...
I hid everything. If you look at the top bottom front or sides, you can't tell it's got any extra fans. Most of my air flow goes in the middle-back and all of it goes out the top-back.
Remember smiz you have yours sitting in front of a A/C duct. I don,t have ac in the comp room, i have to put a fan by the door and draw ac in. It,s always around 78 to 80 fOriginally posted by Smizack
Right, but I haven't had it on for the last couple of days and it's at 37.5c right now, and full load would bump it to 41c.Originally posted by Hardass
I got that same case except I have a 120 in the front (but you wouldnt know this unless you opened her up.
P4 3.2
P4C800-E
Xtreme Tek Werkz Typhoon waterblock
Maze4 GPU Waterblock
Mcx159-P w/10,500rpm counter-rotating 50mm JMC fan
Mushin BH-5 Promo build 2-2-2
9800 pro with silversink ramsinks
WD Raptors
My Heatware
ANTEC soho towers are AWESOME for modding!! the template carry over is simple but do some measuring as placement of the fan will affect inside temp probes and air flow!
and make sure your tails are long enough to keep attached while opening door
I thought about mounting in front, but i like air blowing direct to hs the way my A-top case does.Originally posted by Silversink
You are not going to have sex with it now are you?Originally posted by Smizack
HAHAA!
beuaty is only a power switch away....
AHHH!!!Originally posted by DaGoochMeister
j00 know what I meanz!!!:p
That's what I'm saying!Originally posted by Silversink
Just got this case from a guy cheap, i have never seen a case like this here are pics of door.
Inside of door, the inside is like jbells case 4 in front- 2 rear-it has 1-top-2 on opp side.
Seems as if you got a "shweet" case there.
