Just bought 3 KD7-Gs from newegg along with 3 XP1700s and happened to get a trio of nice little JIUHB step codes, so we might clock the servers up a bit : )
But that's not the problem. The problem is that with all three boards, the 2nd Serial ATA port will not recognize the hard disk in the BIOS.
I switched the jumpers around and tired every combo possible on the hard drives. Both drives are seen in Port 1 when run separately. Neither drive is seen by port 2, whether I boot with both plugged in or neither. I've switched serial ATA cables, the Serillel adapters, everything. What are the odds I got three bad boards in the same shipment? Probably 0.
The drives are WD SE 80GB 8MB cache drives - brand new. Bought six of those. Serial ATA is enabled in the BIOS etc.
Not sure what to do. Anything I am missing here that has been discussed elsewhere. Been searching for solutions for 2 hours now and come up with little.
Thanks.
RB
