Well guys, it's been a while since I did the 3 gig redline review for everyone, so... I thought I would bring another great look at perhaps the most underrated ram on this forum.. Gskill HX. That's right folks, HX, not ZX or that other junk, this is gskills top of the line sticks. Is it worth it? we'll see.... hehehehe. This is what happens when u get bored and curious... U do things on a simple whim,...PIX WILL BE BELOW AT THE BOTTOM OF THE POST IF U WANNA GO THERE FIRST TO LOOK AT THEM
What we are going to answer here is :
1. Are they worth it over the cheaper ZX?
2. What are these since nobody has them?
3. What timings can these do? (prepare yourselves )
4. What will I get if I buy a pair for max fsb??
5. Is running 4 gigs really better than 2 gigs as far as gaming/apps goes?
6. Of course, this wouldn't be XtremeSystems without a max volts/mhz test!
7. What are you going to do with the rest u don't keep? (this I can answer right away too, like last time, they will be matched into pairs and put up in the FS section and sold locally)
8. Do you work for Gskill? (well this one, right away, I can say no, just like last time, I didn't work for mushkin either, just simply bored....)
This is the setup :
CBBWE 0550 TPMW opty 165 on stock opty cooling
4 gigs/2gigs/1gig of HX pc3200
DFI Ultra-D (ADO revison) bios 6-23
Gigabyte 6600 128mb PCI-E card @ stock
75 gig raptor
PCP&C PSU
XP pro corp Ed. SP2 (NO TWEAKS, fresh install)
Testing Methodology : 10 1 gig sticks of HX pc3200
-We will be using bios 6-23 (this is the stock one that came with the ADO board btw). LDT/FSB ratio will be set at x3, CPU multi = x9,
-All ram timings will be set to auto except for the main settings, ie: cas/ras to cas/ras precharge/Tras, better known as 2 3 2 5 for this particular ram at stock
-we will test tightest timings, loosest timings, highest FSB achievable memtest stable.
-We'll also be using a timeless classic 3dmark2001 to measure gaming performance and stability.
-We'll also be using Sandra memory bandwith benchmark to measure performance.
-We'll also be using super pi, 1 full run of all the tests at max fsb possible for 4 gigs 2t & 2 gigs 1t/2t (3x12 runs I believe that will be)
-Lastly, we'll use warcraft3 frozen throne, set on god mode with cheats enabled in a large map 12 group battle royal to see what is actually playable, IE doesn't crash,
-this will also enable us to directly see if 4 gigs vs 2 gigs vs 1 gig is any different.
-4 gigs will be ran in dual channel at 2T
-2 gigs will be ran in dual channel at 2T & 1T
-1 gig will be ran in single channel at 1T
Well, enuff of the details, lets get to the good stuff.
Here's what 10 sticks did right out of the box with 2.6 stock volts. this is MAX FSB MEMTEST 5 AND 8 stable.
1 ...280... (282 after 24 hour burn in with test 5)
2 ...274...(276 after 24 hour burn in with test 5)
3 ...272
4 ...271
5 ...269
6 ...268
7 ...263
8 ...263
9 ...262
10 ...254
Needless to say, this makes for some very nice matched pairs, with the exception of the last stick, they all hit 260+ fsb, realitively speaking when compared to other ram, 254 isn't too shabby either though. Also looks like burn in works on these sticks judging from the initial burn in with the 2 best sticks, looks like they are good for at least 2-5 mhz more, I would say an avg of 3 mhz gain if I were to make a guess at this point, time will tell...What does this equate to for you?? Pretty damned good 4/5th's chance that the pair u buy will clock 265 or over, 3/5ths chance that they will do 270 or over and a 1/10th chance that you will get an exceptionally good stick 280+!!!!
Here's data on 4gig dual channel 2T performance.
\ = test wasn't ran
n/a = was ran, not sucesssful
n/a with stats = was ran, not considered stable
Red = max fsb at tightest timings 3dmark/sandra stable
CPU Mhz---MULTIxFSB---Timings---3D MarK-----Sandra----Volts--Gigs
1.8--------9x200--------2 3 2 5----14,261-----4471/4484---2.6---4
1.953------9x217--------2 3 2 5----14882-----4818/4838----2.6---4
1.953------9x217------2.5 3 2 5----14823-----4786/4799----2.6---4
1.953------9x217--------3 3 2 5----14741-----4768/4783----2.6---4
2070-------9x230------2.5 3 2 5----15357-----5104/5097----2.6---4
2070-------9x230--------3 3 2 5----15177-----5057/5058----2.6---4
2160-------9x240------2.5 3 2 5----15637-----5306/5307----2.6---4
2160-------9x240--------3 3 2 5----15554-----5268/5272----2.6---4
2205-------9x245------2.5 3 2 5----15789-----5430/5433----2.6---4
2205-------9x245--------3 3 2 5----15704-----5388/5381----2.6---4
2295-------9x255--------3 3 2 5----15941-----5602/5622----2.6---4
2304-------9x256--------3 3 2 5----15998-----5617/5620----2.6---4
2313-------9x257--------3 3 2 5----16012-----5643/5629----2.6---4
2322-------9x258--------3 3 2 5----15469-----5653/5675----2.6---4
2322-------9x258--------3 3 3 5----16051-----5674/5668----2.6---4
2340-------9x260--------3 3 2 5------n/a------5712/5719----2.6---4
2430-------9x270--------3 3 2 5------n/a------5914/5926----2.6---4
2430-------9x270--------3 3 3 5------n/a----------n/a-------2.6---4
Here's data on 2gig dual channel 2T performance.
\ = test wasn't ran
Purple = best of previous set of data
1.8--------9x200--------2 3 2 5----14,259 ----4480/4495---2.6----2
1.953------9x217--------2 3 2 5----14823-----4835/4847---2.6----2
1.953------9x217------2.5 3 2 5-------\-----------\--------2.6----2
1.953------9x217--------3 3 2 5-------\-----------\--------2.6----2
2070------9x230-------2.5 3 2 5----15270-----5103/5105---2.6----2
2070------9x230---------3 3 2 5-------\-----------\--------2.6----2
2160------9x240-------2.5 3 2 5----15554-----5310/5338---2.6----2
2160------9x240---------3 3 2 5-------\-----------\--------2.6----2
2205------9x245-------2.5 3 2 5----15695-----5442/5440---2.6----2
2205------9x245---------3 3 2 5-------\-----------\--------2.6----2
2295------9x255---------3 3 2 5 ----16018----5594/5595---2.6----2
2304------9x256---------3 3 2 5-------\-----------\--------2.6----2
2313------9x257---------3 3 2 5-------\------------\-------2.6----2
2322------9x258---------3 3 2 5-----16068----5642/5644---2.6----2
2322------9x258---------3 3 3 5-------\-----------\--------2.6----2
2340------9x260---------3 3 2 5----14940-----5709/5702---2.6----2
2340------9x260---------3 3 3 5-------\-----------\--------2.6----2
2385------9x265---------3 3 2 5----16216----5801/5808----2.6----2
2421------9x269---------3 3 2 5----16294----5888/5874----2.6----2
2430------9x270---------3 3 2 5--16352*n/a--5897/5913----2.6---2
2430------9x270---------3 3 3 5--16062*n/a------\---------2.6---2
2466------9x274---------3 3 3 5------n/a----------\--------2.6---2
2475------9x275---------3 3 2 5------n/a-----6042/6016----2.6---2
2484------9x276---------3 3 2 5------n/a-----6054/6076----2.6---2
2493------9x277---------3 3 2 5------n/a-----6081/6097----2.6---2
Here's data on 2gig dual channel 1T performance.
\ = test wasn't ran
CPU Mhz---MULTIxFSB---Timings-----3D MarK-----Sandra----Volts--Gigs
1.8---------9x200 --------2 3 2 5----14,457------4888/4832--2.6---2
1.953------9x217---------2 3 2 5----15056-------5264/5206--2.6---2
1.953------9x217-------2.5 3 2 5-------\-------------\-------2.6---2
1.953------9x217---------3 3 2 5----15010-----------\-------2.6---2
2070------9x230--------2.5 3 2 5----15483-------5553/5488--2.6---2
2070------9x230----------3 3 2 5-------\-------------\-------2.6---2
2160------9x240--------2.5 3 2 5----15807-------5799/5749--2.6---2
2160------9x240----------3 3 2 5-------\-------------\-------2.6---2
2205------9x245--------2.5 3 2 5----15985-------5938/5858--2.6---2
2205------9x245----------3 3 2 5-------\-------------\-------2.6---2
2295------9x255----------3 3 2 5----16132-------6108/6036--2.6---2
2304------9x256----------3 3 2 5------\--------------\-------2.6---2
2313------9x257----------3 3 2 5-------\-------------\-------2.6---2
2322------9x258----------3 3 2 5----16160-------6168/6101--2.6---2
2322------9x259----------3 3 3 5-------\-------------\-------2.6---2
2340------9x260----------3 3 2 5-------\-------------\-------2.6---2
2340------9x260----------3 3 3 5----16256-----------\-------2.6---2
2385------9x265----------3 3 2 5----16424-------6346/6270--2.6---2
2394------9x266----------3 3 2 5----16313-------6352/6271--2.6---2
2403------9x267----------3 3 2 5----16436-------6365/6300--2.6---2
2412------9x268----------3 3 2 5----16401-------6411/6356--2.6---2
2421------9x269----------3 3 2 5----16409-------6426/6359--2.6---2
2430------9x270----------3 3 2 5----14621-------6551/6485--2.6---2
2430------9x270----------3 3 3 5----13544-----------\-------2.6---2
2466------9x274----------3 3 3 5------n/a------------\-------2.6---2
2475------9x275----------3 3 2 5------n/a-------6576/6517--2.6---2
2484------9x276----------3 3 2 5------n/a-------6605/6511--2.6---2
2493------9x277----------3 3 2 5------n/a-------6633/6553--2.6---2
Here's data on 1gig SINGLE channel 1T performance.
\ = test wasn't ran
1.8--------9x200----------2 3 2 5-----14,110----3084/3088---2.6----1
1.953------9x217----------2 3 2 5-----14630--------\---------2.6----1
1.953------9x217--------2.5 3 2 5--------\----------\---------2.6 ---1
1.953------9x217----------3 3 2 5-----14596-----3340/3338---2.6----1
2070-------9x230--------2.5 3 2 5-----15090---------\--------2.6----1
2070-------9x230----------3 3 2 5-------\------------\--------2.6 ----1
2160-------9x240--------2.5 3 2 5-----15499----------\--------2.6----1
2160-------9x240----------3 3 2 5-------\-------------\--------2.6----1
2205-------9x245--------2.5 3 2 5-----15603-----3758/3761----2.6----1
2205-------9x245----------3 3 2 5-------\-------------\--------2.6----1
2295-------9x255----------3 3 2 5-----15789----------\--------2.6----1
2304-------9x256----------3 3 2 5--------\------------\--------2.6----1
2313-------9x257----------3 3 2 5--------\------------\--------2.6----1
2322-------9x258----------3 3 2 5-----15949-----3954/3962----2.6----1
2322-------9x258----------3 3 3 5--------\------------\--------2.6----1
2340-------9x260----------3 3 2 5--------\------------\--------2.6----1
2340-------9x260----------3 3 3 5--------\------------\--------2.6----1
2385-------9x265----------3 3 2 5-----16110----------\--------2.6----1
2394-------9x266----------3 3 2 5-----16070----------\--------2.6----1
2403-------9x267----------3 3 2 5-----16026----------\--------2.6----1
2412-------9x268----------3 3 2 5-----16065----------\--------2.6----1
2421-------9x269----------3 3 2 5-----16128----------\--------2.6----1
2430-------9x270----------3 3 2 5-----16242-----4150/4150----2.6----1
2430-------9x270----------3 3 3 5--------\-----------\---------2.6----1
2439-------9x271----------3 3 2 5-----16273-----4161/4160 ----2.6----1
2448-------9x272----------3 3 2 5-----15739-----4180/4177----2.6----1
2457-------9x273----------3 3 2 5---14240*n/a---4191/4191----2.6----1
2466-------9x274----------3 3 3 5-----n/a--------4213/4207----2.6----1
2475-------9x275----------3 3 2 5--------\-------4217/4223----2.6----1
2484-------9x276----------3 3 2 5--------\-------4236/4238----2.6----1
2493-------9x277----------3 3 2 5--------\-------4260/4256----2.6----1
2502-------9x278----------3 3 2 5-------- \-------4268/4271----2.6----1
2511-------9x279----------3 3 2 5--------\-------4287/4288 ----2.6----1
2520-------9x280----------3 3 2 5--------\-------4301/4300----2.6----1
2529-------9x281----------3 3 2 5-------- \-------4312/4315----2.6----1
2538-------9x282----------3 3 2 5--------\-----------n/a-------2.6----1
Super Pi Runs @ 9x200mhz (2 3 2 5)
--------4 gig 2t------2gig 2t--------2gig 1t
32m----40m14.297----38m58.594----38m10.312
16m----18m37.188----18m38.442----18m17.078
8m-----08m21.406----08m23.203----08m12.031
4m-----03m50.032----03m50.172----03m45.390
2m-----01m45.078----01m45.125----01m43.110
1m-----00m45.609----00m45.641----00m44.718
512k---00m19.860----00m19.890----00m19.625
256k---00m08.296----00m08.282----00m08.250
128k---00m03.531----00m03.516----00m03.515
64k----00m01.578----00m01.563----00m01.562
32k----00m00.688----00m00.718----00m00.687
16k----00m00.297----00m00.297----00m00.281
Super Pi Runs @ MAX FSB @ 2.6 Volts
9x264 (2 3 2 5) 2T/4G----9x277 (2 3 2 5) 1T/2G----9x277 (2 3 2 5) 1T/1G
32m----30m15.312-----------------28m28.016----------------(coming)
16m----14m27.312-----------------13m32.172----------------(coming)
8m-----06m29.140-----------------06m04.000----------------(coming)
4m-----02m58.297-----------------02m46.891----------------(coming)
2m-----01m21.484-----------------01m16.344----------------(coming)
1m-----00m35.313-----------------00m33.109----------------(coming)
512k---00m15.359-----------------00m14.438----------------(coming)
256k---00m06.375-----------------00m06.063----------------(coming)
128k---00m02.703-----------------00m02.563----------------(coming)
64k----00m01.203 -----------------00m01.141----------------(coming)
32k----00m00.531-----------------00m00.500----------------(coming)
16k----00m00.218-----------------00m00.219----------------(coming)
Super Pi Runs @ MAX FSB @ 2.72 Volts
-----2T/4G (above was max fsb)---9x277 (2 3 2 5) 1T/1G---9x278 (2 3 2 5) 1T/1G
32m----------N/A--------------------28m17.37------------------- (coming)
16m----------N/A--------------------13m30.750-------------------(coming)
8m-----------N/A--------------------06m02.453-------------------(coming)
4m-----------N/A--------------------02m46.000-------------------(coming)
2m-----------N/A--------------------01m16.125-------------------(coming)
1m-----------N/A--------------------00m33.016--------------------(coming)
512k---------N/A--------------------00m14.468--------------------(coming)
256k---------N/A--------------------00m06.032--------------------(coming)
128k---------N/A--------------------00m02.562--------------------(coming)
64k----------N/A--------------------00m01.141--------------------(coming)
32k----------N/A--------------------00m00.515--------------------(coming)
16k----------N/A--------------------00m00.219--------------------(coming)
Super Pi Runs @ MAX FSB using 2.7v
maxed cpu mhz possible for that fsb 9/10 divider
9x308 (2 3 2 5) 2T/4G (277fsb)
32m---------(coming)
16m---------(coming)
8m----------(coming)
4m----------(coming)
2m----------(coming)
1m----------(coming)
512k--------(coming)
256k--------(coming)
128k--------(coming)
64k---------(coming)
32k---------(coming)
16k---------(coming)
