+ Reply to Thread
Results 1 to 18 of 18
Thread: Aluminum or Copper?
    Xtreme Member PoL's Avatar
    Mar 2005
    Barcelona
    0
    Aluminum or Copper?
    Is there a great difference in temps between a solid copper container and an aluminum one?
    Intel Core 2 Quad Q6600
    GSkill F2-8000CL DDR2-1000 2x2GB
    Abit IP35 Pro
    XFX NVidia GeForce 6800GT @ 435/1210Mhz
    2x WD Raptor 36GB RAID 0
    Antec TruePower Quattro 1000w
    Windows Vista Ultimate x64
    Jan 2003
    Manchester, Uk
    0
    The difference is mainly when dealing with loaded temps and with the X2 kicking out a fair bit of heat then i'd go for copper if you get the chance
    Pentium M database:
    http://www.wwwwwoc.net/db1.htm
    Mar 2005
    Barcelona
    0
    Quote Originally Posted by marvt74
    Well, the chance is all money... So we'll see.
    Abit IP35 Pro
    I am Xtreme afireinside's Avatar
    Aug 2003
    Cherry Hill, NJ
    0
    Aluminum is good if you can't afford copper but it kind of sucks at high loads. A properly designed solid alumi unit will hold a load fine, my units hold -61c and -66c but a copper would hold the load closer to the idle. My units idle -70 and -73c. The 2.25" and 3" mousepots that is.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Xtreme Addict blind_ripper's Avatar
    Jan 2005
    belgium
    2
    thate is nice to know , thane i will go for copper has well
    Wanna look under my kilt? K404's Avatar
    Jun 2005
    Glasgow-ish U.K.
    3
    are the temperatures overall that much lower with copper, or is the main benefit in the idle-load variation?
    Cheers,
    Kenny
    you sigged that?
    why?
    ______
    ln2nl Waus-mod's Avatar
    Jun 2004
    The Netherlands
    0
    Some people say that with cryo temps you achieve more load then copper.. to bad this isnt tested "on our oc world"
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Jun 2005
    Glasgow-ish U.K.
    3
    so theres a series of decisions based on common sense and probability, but no real testing done? Surely someones had a fun day of checking the differences??
    Kenny
    you sigged that?
    why?
    ______
    Jun 2004
    The Netherlands
    0
    Well if you could make solid units to test Its allmost a no job to do that and test every unit we make.
    *EDITed by IFMU*
    Forum Policies
    Jun 2005
    Glasgow-ish U.K.
    3
    LOL I cant afford both, so buying a tube of any kind will be an achievement.
    My wallet says alu tube, but if the temperature differences are that big, my head says copper. May as well buy quality if it`ll benefit the clocks.
    you sigged that?
    why?
    ______
    Apr 2004
    Cornwall/Leeds UK
    0
    Quote Originally Posted by K404
    YGPM
    .:. X2 @ 2.9 .:. E6600 L628 @ 4.73 .:. AB9 @ 512 FSB .:. E6300 @ 100% OC Stable
    U.K. overclockers: Represent your country, bench for EP-UK! Unite and show the world there IS a U.K. scene!
    Jan 2003
    Manchester, Uk
    0
    Kenny you could use the Team UK tube if you want for cheapness aslong as its ok with SoddemFX
    Pentium M database:
    Jun 2005
    Glasgow-ish U.K.
    3
    Doh! yea I forgot about that! LOL Highlander has a similar idea, wont say any more its up to him to say as much as he wants. Might ask Soddem for a loan an see how I get on. Been thinking of moving to DI over my Mach for lower temps so would prob wanna buy one eventually. Will ask him. Cheers!
    K
    you sigged that?
    why?
    ______
    Jan 2003
    Manchester, Uk
    0
    Ok i've got the Team UK one atm but can easily send it you.
    You could use my gpu tube aswell if you wanted to use that
    Pentium M database:
    Jun 2005
    Glasgow-ish U.K.
    3
    ok. I`ll see about sourcing DI for a couple weekends time and let ya know? Is that ok?
    Cheers!
    K
    you sigged that?
    why?
    ______
    Jan 2003
    Manchester, Uk
    0
    Aye if you want to add me to MSN or something it might be in my profile i might be able to give you a few numbers
    Pentium M database:
    Registered User drcooling.cl's Avatar
    Sep 2005
    0
    Quote Originally Posted by Willis
    * diamant: 1000 - 2600 W/mK
    * silver : 429 W/mK
    * Copper : 385 W/mK
    * gold: 320 W/mK
    * aluminium: 229 W/mK (205?)
    * platina: 70 W/mK
    * steell: 42,9 W/mK
    * lood: 34,7 W/mK
    * kwik: 8,3 W/mK
    * kwarts: 8 W/mK
    * ice: 1,6 W/mK
    * glas: 0,8 W/mK
    * wood: 0,04 ÃÂ:banana: 0,12 W/mK
    * asbest: 0,09 W/mK
    * aërogel: ca 0.017 W/mK
    higher is better in our case and the difference is big
    Esto es correcto a 25°C. Cuando baja la temperatura la conductividad termica de los materiales sube.
    Revisen este enlace por favor (pagina 4): http://personales.ya.com/universal/T...DFs/Tablas.pdf
    Es importante destacar ademas que no solo el material interviene en la temperatura final del sistema, pues importa mucho el diseño termico y la superficie de contacto entre el fluido y el tubo. La superficie de contacto es lo que mas ayuda a transferir el calor, y es por esto que los disipadores tienen aletas unidas a una base.
    Estas aletas ademas deben tener una relacion entre el espesor y la altura que dependera de la capacidad del fluido para absorber el calor y de las condiciones de agitacion (turbulencia) de este mismo. Tambien tiene que ver con la cantidad de refrigerante que viaje a travez de las aletas.
    De este modo, el material es solo un factor secundario en la construccion de un tubo para hielo seco o para nitrogeno liquido. Importa mucho mas su superficie de contacto, la forma de las aletas, el espesor de la base y la distancia maxima entre aletas y foco de calor. Esto se puede lograr conmayor exito en un tubo de 2 piezas. Hay buenas tecnicas para soldar cobre y aluminio sin que la soldadura quede debil o que se pueda quebrar con el frio
    Saludos
  18. #18
    Registered User OnDaS's Avatar
    Apr 2006
    PORTUGAL - Nazare
    0
    Now, I' m Projected my first Container in ALUMINIU to DRY ICE.
+ Reply to Thread
