+ Reply to Thread
Results 1 to 6 of 6
Thread: XP, 754 and 939 CPU benchmark comparisons
    Jan 2003
    Los Alamos, NM
    0
    Have been accumulating testing results for my rigs over the last few years and put together a comparison just for the fun of it. Plus I was curious.
    For those that are curious about such a comparison too, here is a link to the html page containing the results summary. I realize that this isn't a perfect study but hopefully provides a flavor of the differences.
    ASUS Rampage II Extreme @195Mhz, Intel i7 920 D0 @4.1Ghz using 1.25V
    Corsair DDR3 1600 (6*2Gb) 8-8-8-24
    Iwaki MD-20RLZT -> EK Sup. Univ. -> Chiller -> Resev
    SB Audigy2ZS + Klipsch Promedia 4.1, HIS 4890, Areca RAID 5, 4 80G SATAII HDDs
    PC P&C Silencer 750 QUAD in Lian-Li PC-V1200
    Win7 64-bit, Ubuntu
    Xtreme Guru largon's Avatar
    Jan 2005
    Tre, Suomi Finland
    0
    What OS' were used?
    You were not supposed to see this.
    Jan 2003
    Los Alamos, NM
    0
    WinXP
    Win7 64-bit, Ubuntu
    Jan 2005
    Tre, Suomi Finland
    0
    The performance gain that is practically possible with a change from a 32-bit system to a 64-bit system can be reasonably significant.
    This may lead to a misinterpretation:
    One might think A64 acts always as a 64 bit processor just because it's capable of 64 bit calculations. But ofcourse, a 64 bit OS (which normal WinXP isn't) is needed to take advantage of 64 bit a proc.
    Xtreme Addict don_vercetti's Avatar
    Jan 2005
    Oxford, UK
    0
    hmm might i suggest you clock them all at the same speed? That would highlight architectural differences, at least. If they could all have the same RAM timings as well, that would also be good.
    Comparing a 2.2ghz 1mb cpu to a 1.8ghz 512k cpu (3700 vs. 2500) is never going to be totally conclusive, really. But a 1.8ghz barton vs. 1.8ghz sandy vs. 1.8ghz newcastle would be far more interesting.
    Conroe E6300 ES
    2x1gb Ballistix PC8000
    Asus P5W DH Deluxe (1705)
    Manli Geforce 7950GT 512mb
    Hiper Type-R 480w
    Samsung SP250
    "What did the quantam duck say?" "Quark Quark"
    Jan 2003
    Los Alamos, NM
    0
    Quote Originally Posted by largon
    No debate there. However the objective was to test within as similar conditions as possible and I can't test using 64-bit OS/benchmark on a 32-bit processor. Thus I ran WinXP on all platforms. I would also content that this is also a common OS for many folks today and a good configuration to test. As more 64-bit software becomes available in the future that will of course change.
    You do raise an interest point and while I have only very preliminary results to date using the 64-bit version of Prime95 on Win64Pro I find that that benchmark produces the same results (within the uncertainty of both sets of results). This conclusion will be application dependent and a result of the talent of the programers and needs of the particular calculations. For example, highly nonlinear scientific calculations typically needing double precision on a 32-bit OS will benefit significantly from the 64-bit hardware and software.
    Thanks for your comment.
    Quote Originally Posted by don_vercetti
    I'm sorry but you completely lost me there don_vercetti. The abscissa (x-axis) of the plots allows you to do just what you asked I think. Pick a fixed CPU speed and read the corresponding values for the respect CPU above and off the y-axis.
    If this isn't the case maybe you can clarify.
    Win7 64-bit, Ubuntu
+ Reply to Thread
