+ Reply to Thread
Results 1 to 8 of 8
Thread: Photoshop
    revlimiter9000
    Guest
    Photoshop
    I have more than 40 wallpapers that are in 1024x768 and I wanted to know how I can increase the size to 1900x1200 since my new monitor's recommended res is 1900x1200. It's been year since I've used photoshop. Can anyone help?
    Xtreme X.I.P. Cooper's Avatar
    Apr 2005
    0
    You just go to Image -> Image Size and put whaever size you want. But increasing the size will result in more blury picture. You shoud make it look better
    revlimiter9000
    Guest
    Can I use a program like IrfanView aside from using Photshop?
    Apr 2005
    0
    Don`t think that IrfanView has the options to correct image quality. Increasing size will drasticly decrease it`s look
    revlimiter9000
    Guest
    Ok. Thanks for the reply Cooper.
    Admin Vapor's Avatar
    Feb 2005
    Ann Arbor, MI
    1
    Also, when you resize, since it's not the same aspect ratio, set the width to 1920 and have the height be automatically set based on the ratio. Also, play around with the Bicubic vs. Bicubic sharper vs. Bicubic smoother. I like to oversample (go too high) with Bicubic sharper and then sampledown with Bicubic smoother (think of it as anti-aliasing). If that's all over your head, ignore it.
    revlimiter9000
    Guest
    Vapor it's not over my head. Now it's starting to come back to me since I just started to fool around with the Photoshop.
    pepsi fiend einCe's Avatar
    Jun 2005
    La Verne, ca
    0
    thats a big jump in resolution, if its a jpeg it is never going to look as good as the origional albeit you mey come close
    Lanparty Ultra-D DEAD|REVIVED
    X2 3800+ LDBHE 0606 EPMW 2950 @ 1.55v DEAD|STILL DEAD
    Powercolor X1900XT 725/873
    dell 2005fpw 20.1''
    Quote Originally Posted by afireinside
    "uh yeah is this DFI RMA dpt? yeah I was setting up your ultra-d motherboard last night and the pwm shot a flame at me... can you give me a new one?"
    Quote Originally Posted by Mr. Popo
    if you wont eat all of your vegetables einCe will come and get you!
+ Reply to Thread
