hi guys
can you tell me something about this CPU....
I bought it yesterday and I hope its a good Stepping for overclocking...
AXDA1700DUT3C
JIUCB 0251SPMW
sorry for this short thread and bad english, I come from germany
thx for your replys
hi guys
AXDA1700DUT3C
JIUCB 0251SPMW
thx for your replys
hmm well it's a week 51, so i recon it would do something like 2.2ghz on air with the right components etc...
XP1700+ Watercooled @ 1660 mhz max
Abit KD7-Raid
Kingston HyperX PC3200 (512mb)
Leadtek GF3 Ti200 TDH @ 215/530
That's a good one! Congrats.
Abit AV8 - AMD64 3000+ 1Ghz@1.025V - 512MB Hynix D43 - R9200SE 128MB - Liteon IDE burner - WD 250GB IDE
Ive got a friend right now at a fair with 3 chips exactly like the one above in front of him
i need to make a decision NOW
So what do u guys think should i get one????
Quick responses if possible!!
Seasonic Prime TX-850 Platinum | MSI X570 MEG Unify | Ryzen 5 5800X 2048SUS, TechN AM4 1/2" ID
32GB Viper Steel 4400, EK Monarch @3733/1866, 1.64v - 13-14-14-14-28-42-224-16-1T-56-0-0
WD SN850 1TB | Zotac Twin Edge 3070 @2055/1905, Alphacool Eisblock
2 x Aquacomputer D5 | Eisbecher Helix 250
EK-CoolStream XE 360 | Thermochill PA120.3 | 6 x Arctic P12
my experience with this cpu isn't very good...
I have tried to OC this CPU on a 8RDA+ and an Alpha Pal 8045, but I doesn't get over 1.9ghz with this CPU
I can't understand that
AMD Athlon 1700+ JIUHB
Abit NF7-S Rev 2.0
2x 256MB PC333 Infineon @ CL2 2-2-5
GeForce4 Ti 4200 64MB @ 300/600
Sorry to hear that
What voltages are u giving the processor?
max. 1,9V ... but it isn't stable on 2ghz
Abit NF7-S Rev 2.0
Ok i decided to give it a miss.
Hope i dont regret it.
Wish there were JIUHB or JIUGB chips there, but no such luck.
Lets c when the 0301 chips start showing up hopefully soon.
:p
I dont' understand your english... can you write sentences, which are easier for me??
thx for your help
what would you say with your post #4 ??
Abit NF7-S Rev 2.0
lol
Ok this is what i mean
I will wait for the cpu stepping to change to
AIU.......0301 etc.
Hope you understand.
L8rs
the "J" stepping 1700+ TBred B i got is week 51, and currently i have run at 1964mhz at 1.7v on MSI KT3 Ultra2 (11x178)
very stable, but too bad the max vcore on this board is only 1.7
@ mongoled... ok, I think I understand what you say...
where do you get these informations about good steppings and series ??
Abit NF7-S Rev 2.0
Maybe you should try some other memory, or increase your memory voltage and lower your timings ?
Abit KD7-Raid
I have used FSBs from 166-190 with CL 2,5 3-3-7 @ 2,77V but the CPU doesnt go stable over 1.9ghz
now i running my 2000+ palomino @ 10.5x166 with CL2 2-2-5 ... rock - stable
My Tbred B is a bad one and I can change it by the shop, which sold me the CPU
Can you give me some good Steppings and series for 1700+, 1800+ and 2400+ ??
Abit NF7-S Rev 2.0
nowbody who knows some good steppings??
I take a look in the "Tbred B OC information thread"... but there are many 2400+ and I'm searching for 1700+ oder 1800+, primary
Abit NF7-S Rev 2.0
Jiuhb's are running pretty good, but you can only find them in Slovenia or South America.
your jiucb seems to be the exception rather than the rule.Originally posted by jmke
JIUCB XP1700+ here @ 2260 with 2v vcore
chr!s, the best 1700+ and 2100+ steppings seem to be jiuhb with week 0252 best for 1700+ and week 0248 being best for 2100+. Avoid jiucb steppings and avoid week 0301 even for jiuhb.
Sorry, but I haven't seen much about 1800+ t-bred B's.
Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
Me and my bro have 6 JIUCB week 51's and all of them will do 2.2ghz at ~1.9v on air. We have 1 JIUCB week 50 that does 2.2ghz at 2v on air.
Interesting, perhaps the week matters more than the stepping. I would still look for an early 0250 or earlier jiuhb if possible, though.Originally posted by twiggy
What sort of cooling are you and your bro using twiggy?
Im using this but mine is copper but with the same fan. My bro is using a slk 800 and a 92mm tornado at 2800 rpm's.
Most of them topped out ~2.4ghz but a couple did 2.5-2.6ghz, stable too. 24/7 folders.
I agree tho if you can find a JIUHB then grab that for sure.
hmm.... I can't believe that... my processor doesn't reach these high frequencies
perhaps I make something wrong, but I used voltages between 1.6V - 1.9V and the temperatur was with 50°C 'cool' for my air-cooling
normally the 8rda+ is a good board for overclockers and my RAM is rock stable @ 180mhz and CL2
It seems to be a very bad CPU I've bought
Now, I use a 2000+ palomino with AGOIA Y stepping... can you give some advices to OC this CPU... which voltages are "healthy" for this CPU... ??
@twiggy... can you say me the settings of your JIUCB @ 2.2ghz (multiplier and FSB)
Abit NF7-S Rev 2.0
At 2.2ghz I have it at 133x16.5.
how can I apply these high multipliers...??
I can increase the multi only to 12,5... all higher multis aren't accepted by the system... all lower multis are accepted...
I have closed all L1 bridges on the palomino....
Probably I have the chance to get a 1700+ JIUGB... is it much better?... I don't know the week... is it more important than the stepping?
Abit NF7-S Rev 2.0
i have jiucb 1700+ 0251 too. 2300mhz @2v with watercooling,
2150mhz on air (old coolermaster aluminium) and 1.85v
