Anything from missing icons to stuff that needs attention.
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
Putting stuff in place, a few more reboots may be needed.
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Insert Hyperlink does not give the option to enter the text you want displayed
Just curious, are you on a whole new server now? MySql or MSSQL?
crossing my fingers that this puppy stays up!!!
Gigabyte GA-EP45-UD3P v1.6 bios FC
Q9650 @ 4.3ghz
8GB HyperX 5-5-5-15
Win7 x64 RTM
We are on an alternate server,
3.73EE ES on Asus P5WD2-E Premium 4GB PQI
Same hard drives, hoping this will be more stable.
I am moving OS to Centos, variations in Mysql and having a 4.2GB .sql dump makes it very time consuming transfer. I have to do small chunks at a time.
Once I get Centos working correctly I will copy this database in place.
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Clock is way off....minutes and hours.
Seconded I KNOW i'm not posting @ 7AM on Friday againOriginally Posted by Vapor
And can we have the default on msg receipts back to defaulting to 'ON' Plllleeeeaaaasssseeee
Thanks MikeE
What happened? Did the sever crash or is this a upgrade?
Is it just me or this forum server? AM and PM seems to be backward
Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
You have ruined 2 days of mine, I couldn't get to XS
Good job, keep up the good work
Main rig:
CPU: I7 920C0 @ 3.6Ghz (180*20)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
Intel X25-M G2 80GB, 12TB storage
PSU/Case: Corsair AX850, Silverstone TJ07
Clock problems here as well
The rig
CPUs: E6300 ES B0 @ 3220 MHz w/1.35v orthos stable | E6600 B2 @ 3400 MHz w/1.43v --> Sold | Xeon 3050 L2 @ 3304 MHz w/1.45v orthos stable
MoBo: Asus P5K-E WiFi-AP @ 520 x * orthos stable
Graphics: 256 MB Connect 3D Radeon X1900XT @ 661/828 (core/mem)
RAM: 2 x 1 GB Team Xtreem PC2 5300 @ DDR1010 4-4-4-8 / DDR1100 5-5-5-12 w/2.25v orthos stable
HDDs: 300 GB (16 MB Cache) and 80 GB Maxtor Diamondmax 10 drives
Optical: NEC ND3500AG DVD +/- RW
PSU: Antec True Power 2.0 550W
H2O
Swiftech MCR220-QP | Laing D5 | AquaXtreme MP-05 Pro LE | DangerDen Maze 4 LP | 2 x 120mm NoiseBlocker SX1 fans
Lappy
MSI MS1022 14.1" Widescreen Barebone | Celeron-M 360 1.4 GHz @ 1.86 GHz / Pentium M 715A | GeForce 6200 Go | 80 GB Fujitsu HDD | Sony DVD +/- RW
Waiting for
Nehalem
i have another strange problem....
emails from the board are now coming from:
this is being blocked at the ISP-level so I am not getting any email notifications. I had to switch my email address to a hotmail address temporarily and even then all messages are being dumped into the junk box. can we get the emails to come from a less evil-sounding address?Code:root@localhost.localdomain
Q9650 @ 4.3ghz
8GB HyperX 5-5-5-15
Win7 x64 RTM
I was just posting a quick reply and it posted at the top of the thread for some reason. It also tripple posted very weird...
It just happened again and I didnt use the quick reply. Stephens post was way before mine and mine went above his... Whats up with this?
Pm's arent going through right now either.....
Things are just getting better and better for me, eh?
I've got it! I think the weight of the attachments in my posts are pulling them to the bottom of the thread!Originally Posted by njkid32
EDIT: OK Scratch that theory....lol
Well sh?t always falls down I really dont know what its doing cuz I tried a quick reply and the regular post reply and they are doing the same thing. But I am sure once Charles sees this he will fix it...
http://www.xtremesystems.org/forums/...=1#post1259143
This issue needs to be addressed.
Edit: should have been post #19, XS is messed up. s7e9h3n posted hours before me, and after i reply i get moved to 18.... Strange!
another time error: http://xtremesystems.org/forums/showthread.php?t=87900
EDIT: whoa, this post itself is a time error. My post should be after S7e9h3n's.
ebay under aws983s, heatware under Mr. Tinker.
weird, I just got this email notification that someone had replied to one of my subbed threads, But when I clicked on the link, that post is nowhere to be found. Database corruption again?
see below:
Dear LuckMan212,
CrashOv3r1De has just replied to a thread you have subscribed to entitled - Chipset on DFI Expert reaching 62c ,,, is this a problem? - in the AMD forum of XtremeSystems Forums.
This thread is located at:
http://www.xtremesystems.org/forums/...5&goto=newpost
Here is the message that has just been posted:
My chipset was reaching those temps too. Just put a 80mm fan directly on top of my vidoecard so it stands near pwmic andcb lows on it and temps are in the 40s loaded
There may be other replies also, but you will not receive any more notifications until you visit the forum again.
All the best,
Q9650 @ 4.3ghz
8GB HyperX 5-5-5-15
Win7 x64 RTM
weird.. I just posted mine and it wound up above s7e9h3n's. Guess the clock finally got set to the right time!
is FUGGER reading this thread?
Q9650 @ 4.3ghz
8GB HyperX 5-5-5-15
Win7 x64 RTM
This was a "problem" even before we had all these server issues, but I really don't mind it since it makes me feel popular I'm just curious what caused it....no need to fix it.....it makes me feel.........like saaya LOL.......
He probably deleted his thread before you saw it...I've seen that happenOriginally Posted by LuckMan212
Not really urgent, but I just started a thread, and some guy posted like 10 posts to check the time, in my thread, and they all showed up before my post, and mine was the thread starter!
maybe it's a timing issue. it's not important, but it's kinda interesting
here's a link:
http://www.xtremesystems.org/forums/...ad.php?t=87924
The server is actaully in the bermuda triangle, and not Vegas. This might explain things better.
