+ Reply to Thread
Results 1 to 6 of 6
Thread: opty 146 cab2e o548 under phase need help
    Xtreme Member pocketbikeuk's Avatar
    Nov 2005
    Dorset
    0
    it has a major cold bug and jusy wont boot into windows or run in windows with my ss on if i turn it off it boots into windows at 3300mhz fine no probs but then as soon as i turn my ss back on and the temps drop towards 0 it hangs up is there anyway of getting around this ive been told to install the acp multiprocessor driver anyone here tried this? im going to update the bios on my dfi nf4 ultra d try increasing the drive strength and lowering the ht to 2x ive tried core v up to 1.9 briefly is it safe to go to 2? and also if anyone has a opty that has no cold bug i have cash here waiting so please pm me or just post in here and il pm you about it. any info much appriciated
    Xtreme Mentor Absolute_0's Avatar
    May 2005
    San Diego, California
    0
    You're gonna kill the chip if you're messing with 2 volts and turning the single stage on and off. I have a CAB2E chip as well, the cold bug is terrible, i have ACPI multiprocessor installed but it just makes load temps slightly hotter. Basically these chips don't work on single stage.
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
    Xtreme Enthusiast Mongoose420's Avatar
    Jun 2004
    0
    the acpi multiprocessor driver forced my 148 to 100% load temps while idle. so it would be worth a shot. as for the high vcore
    I5 2500k@4.7ghz--Asus P8Z68-VGen3--4x4gb Gskill Ripsaw 1600 --EVGA GTX570--Crucial m4 128gb SSD--Corsair TX950w--Corsair H100--Corsair 800D
    Scores are all 4+years old. updates soon.
    All scores are outdated
    24/7 3dmark06 6841
    24/7 3dmark05 13357
    24/7 3dmark03 22979
    Very Mild 3dmark01se 55225
    24/7 Aquamark 3 136020
    Xtreme Member Ozan Baseski's Avatar
    Jun 2005
    Istanbul - Turkey
    0
    You should do the multiprocessor tweak and other than that you can run super pi 32m or prime test at the background to heat up the cpu rather than giving it 2 volts. You would burn it up quickly otherwise
    Asus Rampage II Extreme - Intel Core i7 920 - 3x2 GB Corsair Dominator 1600MHz -1792MB Zotac GTX 295 - 500 GB Seagate 7200.12 - 1 TB Seagate 7200.11 - 500 GB WD Hdd - 16x Nec Sata DVD-RW - 26" Samsung T260 - Logitech Pro Keyboard - G5 Mouse - Razermat Control Pad - Lian-Li V2000 Case - Tagan 700Watt BZ Psu - Logitech Z5500 Speakers
    Xtreme Addict Eldonko's Avatar
    Apr 2005
    Calgary, AB
    9
    I tried my cab2e 148 under phase too, couldnt boot at any speed. acpi multiprocessor might help a little bit if you are just benching but prob is not good enough for 24/7 op.
    MB Reviewer for HWC
    Team OCX Bench Team
    May 2005
    0
    I dont think ACPI multiprocessor will help enough. Even with ACPI on, full loading, and 1.6 volts, my temps only got to 0C and i can't even clockgen to 3.0 Ghz before it locks up.
    Bottom line: most of these CAB2Es need very positive temps. I think the SS is a waste of time on them. Someone in a different thread said his CAB2E bugged out at +14C core (started locking up prematurely). So these aren't good for much more than watercooling /crappy waterchilling.
    Intel Rig
+ Reply to Thread
