Page 24 of 27 FirstFirst ... 14 21 22 23 24 25 26 27 LastLast
Results 576 to 600 of 665
Thread: Building a dual 1.6GHz LV Xeon cruncher.
  1. #576
    Apr 2005
    Athens, Greece
    0
    Quote Originally Posted by wire
    I have tried the 20 multiplier with lower FSB. I have booted with 150 FSB and I raised it to 160. It runs for two hours at 3200MHz. I have just raised it to 165 at 3300MHz. I am curious if it makes it through the night.
    Also the ambient temperature was about 26C today. It is used to be around 30C the previous days.
    It did make it through the night at 3300MHz (165 bus) !
    Temperatures were about 46C in the morning. At this point I am happy with the u-wire mod and the Coolermaster heatpipe lapping.
    I have to troubleshoot what thing doesn’t like the high FSB.
    I have raised it to 3400MHz (170 bus) and went off to work. In the afternoon I will see if it survived the heat. Athens is still pretty warm.
    Home DataCenter
    -Workstation:Dual Xeon 2.0GHz LV SL6XL D1@ 3.4GHz (170x20) 1.6volt u-wire mod, lapped Coolermaster E3W-NPTXS-04 with fans in push configuration , Asus NCCH-DL, 4 x OCZ 512MB EL rev.1 @ 2-2-2-5@2.7volt, ATI 9600 128MB, Fortron 550 EPS, Thermaltake V2000 Lanfire case
    -File Server:AMD 2600XP+ Zalman Copper cooler, Asus A7N Deluxe, Kingston 2 x 256MB ram, Asus Nvidia MX2, HDs: WD 2 x 200GB IDE, Seagate 2 x 120GB SATA
    -Laptop:IBM T41 Banias 1.5GHz, 1GB ram, Seagate 120GB@5400 HD, WiFi, Bluetooth, Secondary slim battery, PCMCIA cards: Firewire, Cisco LMC352 extra WiFi - external: Bluetooth GPS, 80GB@5400 2.5'' HD
    -Infrastructure: Switches: Gateway 24port GigaLan , 3Com 5port GigaLan, Compex 8port 10/100, DSL modem: USR 9105, WiFi Metropolitan routers & interfaces:2 x PCEngines WRAP.2C (CM9 cards), PCEngines WRAP.1E-2, Cisco 340AP
    -Building: New File & Terminal Server Dual Xeon 2.0GHz LV SL6XL D1@ 2.66GHz, Coolermaster E3W-NPTXS-01, Tyan Thunder i7501 Xtreme 2726, 2 x 512MB REG ram, Adaptec SCSI Zero Channel RAID card, 5 x 36GB 10krpm Hitachi HD in dual channel SCSI U320 RAID5 , Fortron 550 EPS, Thermaltake Armor case
    -Building: New Virtualization Server Dual Xeon 1.6GHz LV SL6XK D1@ 2.128GHz, Coolermaster E3W-NPTXS-01, Tyan Thunder i7501 Xtreme 2726, 2 x 512MB REG ram, Fortron 550 EPS, Thermaltake Armor case
  2. #577
    Apr 2005
    Athens, Greece
    0
    It is still going on at full load at 3402.11GHz (170.1MHz bus)
    Home DataCenter
  3. #578
    XS_THE_MACHINE gearhead's Avatar
    Mar 2005
    Victoria BC Canada
    0
    are you monitoring m/b and cpu temps? I thought for sure it would be fried with the ambient temps there.
    Lower fsb, higher multi hmmm less stress on vrms?
    i5 2500k @ 4.6 Ghz
    Asus P8P67 Pro rev 3.1
    2x4 Gb G-Skill DDR3-1600 ram
    Asus Geforce 560 448 cores
    128 Gb SSD, WD 1Tb black Gb storage
    Corsair 950TX watt
  4. #579
    Apr 2005
    Athens, Greece
    0
    For a couple of hours it runs at 3450 (172.5 x 20) at full load.
    I got one "Generic Hosts" error window but the system keeps running.
    Ambient tempeture was about 31C.
    From the thermal probe of the case I read 45.1C for cpu 1.
    MBM 5 doesn't work. Any suggestions about MBM 5 ?
    Home DataCenter
  5. #580
    Xtreme Cruncher RocKer's Avatar
    Aug 2004
    Belgium
    0
    That looks a nice block ,its possible that i gone buy those for my 1.6ghz LV ES rig,its 78€ for one,but i think that it will do a good job on cooling those baby's .
    Will there be much diffferens between the MCW6002(52€) blocks and the SwiftTech Storm(78€) to cool those xeon's.
    Asus P5K<*>OCZ 450w<*>E6600@4.0ghz@9x445@1.450v<*>TeamXtreem DDR2-800 cl3 2x1gb<*>Sapphire 3870 512mb DDR4
    Asus P5E X48 DeLuxe<*>OCZ 700w<*>E8600 E0@4.6ghz@1.350v wc<*>Corsair Titanium DDR2-800 4x2gb<*>Sapphire 2x3870 2x512mb DDR4 CF
  6. #581
    Mar 2005
    Victoria BC Canada
    0
    Question
    tried to boot machine at 16 x 200, went thru post then hung on os load. I have two u wires per cpu, might I need the three for 1.6v to boot at 16x200? or maybe memory prob or ???
    i5 2500k @ 4.6 Ghz
    Corsair 950TX watt
  7. #582
    Aug 2004
    Belgium
    0
    What memory do you have?
    My 1.6ghz can boot and run at 16x200,but now it run's at 15x210 becaus it's a bit to warm overhere i had to lower them.
    But normal it run's at 15x214=3210mhz 24/7,or 16x200 thats to see how my mood is.
    All of this with the IWT offcourse,for the moment that is.
  8. #583
    Mar 2005
    Victoria BC Canada
    0
    My memory is regular infineon ddr 400, runs fine at 15x200 Mhz and ddr 400 speed with no vdimm mod. temps arent a problem with the cpus (~50C) case temp stays below 55C. And with a/c on they are about 5C lower.
    i5 2500k @ 4.6 Ghz
    Corsair 950TX watt
  9. #584
    Aug 2004
    Belgium
    0
    Quote Originally Posted by Jeff
    Yeah, I've heard 1.7 to 1.75v is about tops after all is said and done. Personally I'm not going to see because I don't have any kind of cooling except IWTs.
    Here's a picture btw...
    It's a blank pad so no risk of knocking a SM component off of hurting a chip.
    And the mod is basically putting a 100KOhm VR across this pad and ground. Start off with the VR set to 100K and then work your way down to increase Vcore. Works pretty smooth.
    Jeff can you make a wide shot of that vcore mod,i dont find it on my pc-dl,it is for pc-dl,yes.
    Here something weird going on with my next 1.6ghz LV,i can boot at 120x16 ,stock that is,if i want to make the next step(jumper jump ) it does'nt wont to boot,can't even go in the bios,i have the wiremod to 1.6v and on the memory sits 3.45v with ocz520w rising the 3.3v line,or is it better to do the vdimm mod also,i thought it was ok this way.
    it's the originel bios still,i had a go at updating the bios but i think it did'nt work ok,i do that again.
  10. #585
    Xtreme X.I.P.
    Dec 2003
    Ohio
    0
    Quote Originally Posted by RocKer
  11. #586
    Aug 2004
    Belgium
    0
    Thanks .
  12. #587
    Registered User Rabid_Dog's Avatar
    Aug 2005
    0
    gr8 guide jeff, hope to get mine up and running soon
    3200+ Barton
    512 HyperX
    9800pro
    320gb SATA Raid
  13. #588
    Mar 2005
    Victoria BC Canada
    0
    how do you get a pc-dl @ 3.2 Ghz to run 24/7 without frying itself?
    2 d2ols and my case is at 55-58C
    i5 2500k @ 4.6 Ghz
    Corsair 950TX watt
  14. #589
    XS_THE_MACHINE [XC] moddolicous's Avatar
    Nov 2004
    Long Island
    1
    I think that is actually the vrm, not the case itself. I think thats been said before. Not positive though.
    "Victory is always possible for the person who refuses to stop fighting"
    clicks to save kids
  15. #590
    Mar 2005
    Victoria BC Canada
    0
    yes, I know its the vrm
    can I water cool the vrm?
    i5 2500k @ 4.6 Ghz
    Corsair 950TX watt
  16. #591
    Apr 2005
    Athens, Greece
    0
    After 5 days the 2GHz LV Xeons are stable at 3402.11GHz.
    The memory timings are now very aggressive at 2-2-2-5. They do make a difference in application switching.
    Home DataCenter
  17. #592
    Xtreme D²OL Watch Dog
    Feb 2005
    Canada
    0
    Ya has anyone seen a waterblock for the vrm?
    Quote Originally Posted by gearhead
  18. #593
    XS D2OL & RAM News jjcom's Avatar
    Aug 2004
    Somewhere, USA
    0
    The VRM temp can be that high and you don't need to worry about it
  19. #594
    XS_THE_MACHINE [KoG]^weaZel's Avatar
    Aug 2005
    0
    It's taken me all day (at work) to read thru this entire thread. But I did it! And it has given me enough to think on. I must say that I am going to build one of these. I have been thinking about building a dual cpu machine for sometime but the price has driven me off. And this gives me the info I have been looking for.
    Kaptain, that case you have is a kingwin. I have that model in black with clear windows. It came in three flavors silver/clear, silver/blue, and black/clear.
    PEE 840@3.7hz 1.4v
    P5WD2 Premium
    Corsair 8000UL @ DDR833 4-3-2-9 2.1v
    2- XFX 6800GT
    PC Power and Cooling 1k
    heater918;InSanCen;mad mikee;moddolicous;perkam;[KoG]^weaZel;charlie;
    WesM63;DAK1640;Daved+;AlGore;wjd0724;Icy;MrBigShot ;mag|c;Gearhead
    >>> Brave words. I've heard them before, from thousands of species across thousands of worlds, but now, they are all assimilated. <<<
  20. #595
    Xtreme Cruncher
    May 2005
    Belgium
    0
    For the Belgian guys... just received a mail from my regular hardwareshop and they told me that my Swiftech MCX-603V coolers can be delivered in about a weeks time... since I know Rocker was looking for some WC gear from Swiftech, maybe mail them and ask for prices?
  21. #596
    Administrator Jupiler's Avatar
    Jun 2002
    Belgium
    0
    Got my Coolermaster E3W-NPTXC-01 last week (shipment came earlier as expected) and installed them on my 1.6Ghz. Hooked up 2 quiet 80mm blue fans to them.
    Oh man, the quietness. I just love it, after almost 6 months with the IWT.
    Temps are ok too, at least 10° better than the IWT. It also depends on the room temp (some days, it's wamer/colder, what a climat !!!).
    Here are some pics :
    Rig #1
    Gigabyte P67A-UD4 trying to figure out this POS board
    2600k @ ?????
    2x2Gb GSkill RipJaws-X 1333 (7-7-7-21)
    ATI 5850
    Coba Nitrox 750W
    Watercooled with HK 3.0 CU, Watercool GPU-X³ 5870 Nickel, PA120.3, Laing Ultra with XSPC top
    Rig #2
    DFI UT P35-T2R (0317 bios)
    E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
    2x2Gb Chaintech Apogee GT PC2-8500
    Powercolor 4870
    Corsair 520HX
    Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
    Quote Originally Posted by Movieman View Post
    I've got Supermicro boards that lasted longer than one of my marriages!
  22. #597
    Xtreme Member AKURA's Avatar
    Jan 2005
    0
    Jupiler, what psu are you using to power that beast Btw, thats some beautiful machinery you just built there..
  23. #598
    Jun 2002
    Belgium
    0
    Thx.
    PSU is a Fortron 460W, which are hard to find over here, but I managed to snap a brand new one at ebay a couple of months ago for a fair price. Rock solid PSU.
    Board is the ASUS PCH-DL.
    Rig #1
    2600k @ ?????
    ATI 5850
    Coba Nitrox 750W
    Rig #2
    Powercolor 4870
    Corsair 520HX
  24. #599
    Jan 2005
    0
    Quote Originally Posted by Jupiler
    Thx.
    Are you planning on vmodding/clocking that board? or let it crunch at stock....One of these days I'll built me some dual setup just for crunching puposes. Do those m/b uses regular ram or registered?
  25. #600
    Jun 2002
    Belgium
    0
    No, i've no plans on modding the board.
    Board uses regular ram, just like the PC-DL.
    My 1.6'ers run at 3Ghz, 24/7, for over several months now.
    They ran at 3.1Ghz for some time, but probably due to the heat (summer was around the corner and only using the stock IWT), it became unstable after a while. Temps were high too (around 60°C).
    Will try tomorrow to see if can get them back at 3.1Ghz (or even more).
    Rig #1
    2600k @ ?????
    ATI 5850
    Coba Nitrox 750W
    Rig #2
    Powercolor 4870
    Corsair 520HX
