Nice
Nice
Abit AN8 SLi Fatal1ty nForce4 SLi Bios 20 TicTac Mod
Athlon 64 X2 4400+ Toledo(Currently 2600 MHz)
EVGA GeForce 7900 GTO 512MB
Thermaltake Big Typhoon
Patriot CAS 2 DDR400 2GB Memory
Maxtor SATA 2x 80G Striping(Don't Buy This)
NEC ND3550A 16x RW Dual Layer
Enermax Liberty 500W ELT500AWT
Razer Barracuda AC-1 Gaming 7.1 Soundcard + Headset
r9800pro @ xt bios
sink is only epoxied to the core btw, no screws, nuts, bolts, tiewraps or what so ever and it ran fine for years (still is). pretty tough cards
24/7 setup:|e6600 27B @ 4.1ghz|Commando|8800GTS 640mb @ 600/1000|OZC pc8000 plat. @ 455 4-4-4 2.1v|Frostmachine by Jort|'05 '06 (old amd scores)
FullSpecs
those coolermaster HS'es pwn... what core temps u get?Originally Posted by dinges
LOL anyone tried a zalman 7700Cu on a 6600gt agp? i think it might fit
Maybe if you cut it a little.
Just a quick question - what's the prefered glue on these forums? Just a standard epoxy? or some sort of special mix?
When i had to glue on my RAMsinks (i sorta stuffed up and the thermal tape (although it was extremely thick) wouldn't stick any more) i made a special concoction of superglue and AS5 - works pretty well. I have 2 extremely cool VRAM modules, and the rest at regular temps. :P
~ AMD 3200+ @ 2.71Ghz w/1.55V ~ Kingston HyperX DDR460 2.5-3-3-7 ~
~ Asus A8N-SLI Premium ~ MSI 7800GT w/VF700Cu @ 470/1200 ~
This problem was gone with the Northwood C or even B, but good thing mentioning it.Originally Posted by NickS
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
thats my FX 5600 CardSetup:
AMD Athlon XP 2200+ @ 2.01Ghz (stock: 1.8Ghz)
ASUS A7V8X-X VIA KT400 Chipset (Single Channel DDR)
PNY DDR400 @ 2-3-3-6 1T Bank Interleave
Maxtor 40GB 7200rpm 8MB
ASUS GeForce FX 5600 128MB DDR @ 380/671 (stock: 325/550)
Cooling:
CPU: ThermalTake Venus 12
Video: Stock HSF w/ AS5, BFG Memory Sinks
No volt mods!
11024 in 3DMark01se
My first run w/o tweaks/overclocking was a 7763.
Pictures:
My old Ti 4600AMD Athlon XP 2400+
ASUS A7V8X-X
Cheap PNY 512MB DDR Memory
40GB Western Digital 7200rpm
Windows 2000 SP4
i could of went higher but in this board the multi is locked and the voltage maxes at 1.85v. when i get my new system i am gonna throw it in my nforce 2 which we all know will unlock the multi and allow upto 2.1v so i should be able to get more out of this system. also after a 5 hour prime run it didnt hit over 48C on air, my room temp is around 25C. so heres the pic.
gotta love the days of old school clocking, too bad i sold both those cards
Desktop
AMD Phenom II X2 550 (Quad Unlocked @ 3.4Ghz / 2200Mhz NB)
Gigabyte GA-MA790X-UD4P (F9 Bios)
8GB (4x2GB) @ DDR2-800
ASUS GeForce GTX 560 Ti DirectCUII (920/1840/2200)
Corsair Force GT 120GB
LSI MegaRAID 8408E (3x750 R5)
Windows 7 x64 SP1
Cisco E2000 with DD-WRT kernel 2.6
That looks like a great idea. I'm gonna try it on my fx 5200. It's a POS anyways.
View Part II of my 1337 modded case here:Originally Posted by @_dud
http://www.xtremesystems.org/forums/...ad.php?t=96320
Intel E6300 1.86ghz @ 3.6ghz w/ Zalman CNPS 9500
Gigabyte IP35 DS3
Crucial Ballistix Tracer 4gb
XFX 256mb 7600GS
Seasonic S12
1.5tb hdd space
Hey my mem chips are like 2mm lower than my core chip. were yours?
What should I do so that my cpu heatsink can cover them both. I was thinking about taking it to school and using the milling machine, but I'd rather do it at home. I have alot of tools here, (my dad, uncle, and grandpa are/were mechanics) Any ideas?
Well... You can try something like this:
Gigabyte IP35 DS3
XFX 256mb 7600GS
Seasonic S12
1.5tb hdd space
@comrad thanks I was planning to do that, but what kind of tools? I was thinking of using a really large circular bit, and just "dig" a whole for the core chip, but i was wondering if someone had a better idea.
Well I think I would get one of those circular table saws and cut the heatsink with that, if that wont work try a hand held saw with the blade that is like... a rock-ish material. And then sand it down with a sand belt machine.
(I dont know the names of any of the tools I use because I am Russian and I only know the russian names of them)
Gigabyte IP35 DS3
XFX 256mb 7600GS
Seasonic S12
1.5tb hdd space
They fit on a 7800GT but you have to cut some of the fins that would interfere with the motherboard :POriginally Posted by oohms
I should watercool my MX440SE PCI
Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
You have a MX440SE too!! wow and i'm using mine in my phase cooled beast [good card is dead
looks really clean
anyone want to see a 1337 mod?
how about a Arctic Cooling Freezer7 heatsink on a GPU?
it's a PCX5750... it ran stock 425/500... i cranked it up with vmods to 649/749mhz and took #1 on orb at the time...
these cards normally do around 10k at stock clocks...
now i got an all copper 2U 3.4ghz Xeon heatsink on my X800GTO2 (the ones that are really X850's...) and a vmod... it clocks good... im waiting for new CPU... then a new PSU to take it to it's max... so far i got 26.6K in 01... with a 3.8ghz 805... now im getting a 631 that will probably see 5ghz
keep it up Comrad...
eventually you'll go real crazy
I5 760 P55A-UD3
8GB Corsair
120SSD - 6TB storage
Gigabyte GTS-450
I5 2450M Acer Laptop HM65
8GB A-Data
120GB SSD - 500GB in optical drive
Intel HD GT2+ 3GB shared
I have remembered to when toward also these things.
Pd. CrazyXP1700 has it difficult to put the things in the pci that beast xD
Greetings luf1c3r
oh i had no problems getting things into the PCI slots...
all the fins in the heatsink were gonna fit in just fine...
i ended up putting a strip of neoprene down over the PCI slots to keep the fins from going in LOL!
i think thats the most Xtreme i've gone just yet...
the 2U heatsink works out fine with most ASUS boards, i have clearance for another GPU (for SLI or Crossfire) with a another 2U cooler... and theres just enough room in there i can still install my WIFI TV in the bottom PCIe slot...
but my X800 at 600mhz on the core barely breaks 43C if i recall correctly...
it's been siting on my desk for FAR TOO LONG
im ready to get my recently aquired 631! should have some good results by monday or tuesday hopefully...
I5 760 P55A-UD3
8GB Corsair
Gigabyte GTS-450
8GB A-Data
where's the vmod?!
Originally Posted by dmn_link (Gamespot)
Heh, I did put Alpha PEP66T on 16Mb TNT1 AGP card, long time ago, it was really fun.
Toughest part was removing old glued heartsink, but coldspray did do its work
