+ Reply to Thread
Results 1 to 6 of 6
Thread: Chipset and mosfet cooling on DFI ultra D
    Xtreme Member -=DouglasteR=-'s Avatar
    Jan 2004
    Brasilia - Brasil
    0
    Exclamation Chipset and mosfet cooling on DFI ultra D
    Hi folks, my chipset is a bit ( 60º ) hot ( i live in Brazil ) and because of the size of the 7800gtx, im out of ideas to increase cooling performance on my chipset ! there any ideas !:? Any cooler made for these especifications !?
    Thanks for the help
    How to be Xtreme with so little money ?
    2600k@5ghz 16GB 1600 Gskill 8GBRLX GTX 480 SLi Corsair 1200w
    Lsi 9260-8i + 8 1tb Samsung HD103sj on RAID0 (yes im crazy and i have good airflow for those)
    Xtreme Member Zenjirou's Avatar
    Sep 2005
    Long Beach, CA
    0
    A simple solution is to remove it, and put Artic Silver 5. I think this will reduce temps somewhat.
    Also MAXX once cut a AMD Stock Heatsink to fit on it. And it worked very effectivelyl from what I remember.
    Or can buy Aftermark Cooler
    ------------------Pushing the delta between idle and load, to the limit------------------
    KoyoThread
    7900GT 705/2040, DFI Ultra D AE0, Opty 146 3.10 Ghz, MP01 +MP05 . CPU: 19/21 GPU:24/28 Fan/Shround in progress..
    Xtreme Member ArcticOC's Avatar
    Apr 2005
    Norway, approx. 1367Miles from the Northpole
    0
    Here`s what I did.. kinda extreme, but should meet your spes
    http://www.dfi-street.com/forum/show...&page=14&pp=15
    ArcticOC aka. GXP345@dfi-street
    Live to Mod.. Mod to Live!
    Xtreme Addict Andrew LB's Avatar
    May 2003
    Peoples Republic of Kalifornia
    6
    http://www.xtremesystems.org/forums/...ad.php?t=85920
    Scroll down and see the great chipset cooling solution I made to get the northbridge SUPER cool. I removed the stock cooler, and with a dremel moto-tool, ground down various sections of the Vantec Iceberq 4 GPU cooler and made new mounting holes.
    I'm running dual Prime 95 right now at 2.6ghz on my 3800+ X2 and while my core with my Thermalright 948u isn't exactly the best CPU cooler... i'm still maxing out my loat depts at 47'c and my chipset temperature is a chilly 27'c. My chipset runs roughly 8-9'c cooler with this monster compared to the total POS cooler made by Asus.
    At idle my CPU sits around 33-34'c and the chipset runs around 26'v.
    "When you see that trading is done,
    not by consent, but by compulsion -
    When you see that in order to produce,
    you need permission from men who produce nothing -
    When you see that money is flowing to those who deal,
    not in goods, but in favors -
    When you see that men get richer by graft and pull than by hard work,
    and your laws don't protect you against them, but protect them against you -
    When you see corruption being rewarded and honesty becoming self-sacrifice -
    You may know your society is doomed."
    Atlas Shrugged
    Ayn Rand
    Nov 2005
    0
    how do u messure the chipset temperature?
    May 2003
    6
    Quote Originally Posted by Kalero
    My buddies thermal probe which i inserted underneath it so it made contact with the chipset core. I should have taken photos.
    Btw... i made a typo in my earlier post. when idle, the chipset was 33'c (before) while idle and under full load (dual prime 95 with SuperPi) the chipset never broke 32'c and is currently idling at 27'c.
    Atlas Shrugged
    Ayn Rand
+ Reply to Thread
