as the title says, looking for a program that will allow me to adjust the Vcore and/or multi from within windows on DFI NF4 and Opteron DC/X2
Any suggestions ?
Any suggestions ?
24/7 Work & Play Rig
Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
just curious what you need the program for? Just tired of booting and rebooting the rig to try new settings?Originally Posted by Major
ABIT IP35 PRO
Intel Q6600 GO L737B @ 3.6ghz
G. Skill DDR2 1000 - 4 gigs
150 gig Raptor (OS)
300 gig Seagate (Storage) 500 gig Freeagent (storage)
EVGA 8800 Ultra
Ultra X3 1000 Watt
X-fi Fatal1ty FPS
Watercooled: D-Tek Fuzion MCP655 Micro Res PA 120.3
EX 8800 Full Cover Block
Dell Ultra Sharp 24" LCD
Originally Posted by demonbane23
Pretty much !!
with single core you can use Clockgen, but havn't found anything that works with dual core yet.
I havent found anything either, but it would be really convienent it does get tiring to keep rebooting, when tweaking,,, hmm ill keep an eye on this thread as well,,,,Originally Posted by Major
ABIT IP35 PRO
150 gig Raptor (OS)
EVGA 8800 Ultra
Ultra X3 1000 Watt
X-fi Fatal1ty FPS
Well I was reading a thread here on XS earlier today at work that peeps were talking about a program that would work, but I can't find it now.![]()
try CrystalCPUID?
Intel Core i7-2600K ES (D1) @ 5.0GHz - 1.38v | ASUS Maximus IV Extreme ES
4GB (2x2GB) Corsair DDR3-2133, 8-10-8-27 - 1.65v
ASUS 480GTX SLI | Dell 2404FWP 24" flat-panel widescreen LCD
Onboard Realtek sound | Logitech Z-5500 5.1 digital surround speakers
2x WD 74GB Raptor HDDs (RAID 0) | Plextor PA-755A DVD-/+RW
Corsair HX1000W PSU | Custom watercooled Lian-Li PC-G70B
LOL
FCG you are the man !! I've had that program for some time on my rig and never even knew that you could change the multi with it ! lol
Thanks !
seems like a pretty cool program although it sees my vcore as 1.35 hmm,,, and it lets you see all multi,,, if only they worked,,,Originally Posted by Major
thanks FCG as well
ABIT IP35 PRO
150 gig Raptor (OS)
EVGA 8800 Ultra
Ultra X3 1000 Watt
X-fi Fatal1ty FPS
Ok well I'm still open to Vcore change suggestions ?![]()
i can use NTune to change my vcore, mem voltage and chipset voltage from windows.
eVGA X58 Calssified E761 | i7 920 @ 4.0GHz | 6GB Corsair 1600 | 2 x 60GB OCZ Agility 3 RAID0 | 2 x Radeon 5870
SuperMicro X7DWA-N | 2 x Xeon X5470 @ 3.66GHz | 16GB FB-Dimm 800 | 8 x Samsung F3EG 2TB RAID6 | Radeon 5870
MINER | 2 x Radeon 5830
BTC Mining Calculator: 1,800 M/hashes per second
Thats with X2 and DFI NF4 ?Originally Posted by KaptainBlaZzed
I'll give it a try![]()
On DFI Street they warn that NTUNE Kills the motherboard/cpu/ram.Originally Posted by Major
it is with a DFI NF3 and an X2
They must have removed the Voltage options from the latest NTune version. I can't find them atleast ! lolOriginally Posted by derektm
I've seen some apps that Change the Vcore but None that change the Multi
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
CrystalCPUID that FCG suggested will change the multi, works fineOriginally Posted by nn_step
just doesn't change the Vcore. It may work if I had the Vcore settings at default in bios but I'm using 113% x 1.50v
google for a program called GCPUID and you will find what you seek![]()
Intel i7 3770K 4.4Ghz
Asus P8Z77-V Pro
XFX HD 6950 --> 6970 Flashed
8GB Gskill DDR3-2133
Sound Blaster Z
Corsair AX850
2X Crucial C300 RAID0
Ok I'm off to find GCPUID !! lol
Ok, GCPUID does the same thing as CrystalCPUID, it will change the multi but not Vcore. The options are there in both programs but with the DC and X2 if you use special vid settings then the options do nothing to Vcore.
hrm, ive used it with my old X2 before... I think...
Asus P8Z77-V Pro
Sound Blaster Z
Corsair AX850
Imo it would be better to not be able to change all that in windows, just think the damage that somestimes happens to the OS from upping FSB in windows, I wouldn't change vcore in windows if I could - best left for BIOS whilst your system isn't running the OS
Q9650@4288 10.6sec 1m superpi water ||Asus P5Q Deluxe||4Gb Ballistix Tracer red||4870X2||Corsair1Kw
I'm not trying to be a smart A but if changing vcore from windows is an issue AMD and Intel will need to rethink PowerNow/CnQ and Speedstep.Originally Posted by Morgoth
3770K @ 4.8Ghz 1.42V | GSkill 2x4GB @ 1066Mhz | Asrock Extreme4
2600K @ 4.5Ghz 1.38V | GSkill 2x4GB @ 933Mhz CAS 9-10-9 1.5v | Asrock Z68M/USB
1090T @ 3.8 Ghz 1.42V | Crucial 4x2GB 666 CAS 8 | Asus M4A79XTD EVO
Q6600 @ 3.66Ghz(8x458) 1.35V | GSkill 2x2GB @ 550Mhz 5:5:3:13 2.1V | Asus Maximus Formula(Rampage 0401) |
Yeah Cool N Quiet does just that....while you're in windows doing tasks or idling.No damage. I think Major just wants some ease of use.
YUP
I know, I guess I was off topic with my comment. Just saying I personally don't think there is a problem changing Vcore in windows, and was using Cnq, etc as an example.
Major what version of Crystal are you using? Beta 5? 4.6 or something was the last official release but it's a bit old. I have used Crystal for probably 2 or 3 years, the author seems on top of everything. I am a bit suprised the bugs aren't worked out as of yet. Don't have DC so I don't know but I would be suprised.
Perhaps a dumb question: doesn´t RMClock do the job?
No experience with X2s, just an idea...
Greetz, Flox
"Physics is like sex: sure, it may give some practical results, but that's
not why we do it." -- Richard Feynman.
"A Celeron is not so much a processor, it is more a collection of shorting links to allow the motherboard to work." - read on xtremesystems.org
