Results 1 to 15 of 15
Thread: opteron 146@3451 3dmark and superpi
    May 2005
    earth......among the the others
    hey guys
    i was able to gather some hardware and i was on a sunday bench
    opteron 146
    dfi ultra-d
    2x256 twinmos bh6
    and
    2x512 ocz pc 4800 EL PL
    enermax 600
    7800 gtx 256
    and for some action
    i was able to bench at 3451mhz....
    but to take to most out of my mems i lowered the htt and raised the memory
    we also did some 2k5
    and then for the suicide shot
    it was a fine sunday......indeed
    thns for your time guys
    STEELBALLZZ - N3RO - MARTAKIS
    ZÉ DO BENCH TEAM
    add a volt or two.....
    Da Goose
    Oct 2005
    Chicago
    1.8v geez...Does it still work?
    i7-860 Farm with nVidia GPU's
    May 2005
    Quote Originally Posted by DAK1640
    sometimes i feel i am not in the right place to show this.....
    with all the 3d action....u talk avout vcore
    yes it still works
    ZÉ DO BENCH TEAM
    Dec 2005
    I have the same CPU Cant get it stable at 3GHz, what do i do wrong?
    my specs:
    Opteron 146 Caybe 0543FPMW
    Asus A8N-Sli Deluxe
    2 x Kingston PC3500 HyperX
    Runing:
    FSB 300
    HT 3x
    Vcore 1.525
    Ram Auto.
    how much would you advice me to run my Ram?
    Dec 2005
    By the way BEAUTIFUL OC :P
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Quote Originally Posted by Immanuel
    my specs:
    Asus A8N-Sli Deluxe
    Runing:
    FSB 300
    HT 3x
    Vcore 1.525
    Ram Auto.
    Post your detailed settings, then we can solve it (maybe), but I dont know about the 0543 Opty doing 3G on air, anyhow, go for 1.6Vcore and raise the voltage of your mobo (from 1.5 to 1.6 or 1.65 and also LDT V). Try to keep your ram low at the start, just to be sure it aint holding you back and most important - always keep your Opty cool, it is very temp-sensitive
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
    Xtreme X.I.P.
    Dec 2003
    @steelbalz,
    Very nice, man What stepping and week code is it? What cooling? Does it need this much vcore to get you there or you are just "warming it up" this way?
    EDIT: nvm the cooling, I see now it's Prommy
    Mar 2005
    Netherlands
    Nice oc , what can it do @ air?
    May 2005
    on air it does 3000 at 1,49 v.....occt S&M prime stable
    the vcore is needed...the sucka likes it....after 12 hours of bench at this high vcore i had like -8ºc in bios
    the stepping and week....well i wrote it down somewhere....cant remember where
    ZÉ DO BENCH TEAM
    Xtreme X.I.P.
    Aug 2004
    Chile
    thats a lot of volts for 34XX i might try something like these on my next benching session i only used up to 1.65V
    nice scores by the way
    May 2005
    @metro-cl
    i wish my ocz pc 4800 elite did what yours did...mine hit a wall at 285....
    thnxs guys
    ZÉ DO BENCH TEAM
    Apr 2005
    Calgary, AB
    GJ steelballzz
    MB Reviewer for HWC
    Team OCX Bench Team
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    I wish I had a Prommy or Vapo myself
    then I could maybe score like you guys, great results
    could you do a SPi 32m run? time?
    with does clocks you should score pretty high,
    cuz I got only 3GHz and 1.5V on AIR and SPi 32M 25m 18s
    Bios my arss.....
    Hipro5
    Nov 2005
    Wow that's awesome. I'm still working on mine, just finished primestable for over 8 hours @ 2.835gHz 1.39volts(i put in 1.425 in the bios settings), I'm on a 9X multiplier in order to get something better out of my ram.
    My temps look decent too, under load it seems to stay at 39*-40*C, I'm on air cooling.
    Ironically though, I can't get much higher than my current setting, whenever I'm at 2.9ghz +/- territory the computer starts rebooting, even though my temps look fine, should I up the LDT's and chipset? (currently LDT= 1.3v chipset= 1.6v, vcore=1.425..in ITE it doesn't seem to go too much higher)
    -Cpu:Opteron 170 LCBQE 0722RPBW(2.87ghz @ 1.300v)
    (retired)Opteron 146 (939) CAB2E 0540
    -Heatsink: Thermalright XP-90
    -Fan:120mm Yate Loon 1650 RPM @ 12V, 70.5 CFM, 33dB
    -Motherboard: DFI Lanparty nF4 UT Ultra-D
    -Ram: Mushkin High Performance blue, 2gigs(2X1gig kit) PC3200 991434
    -Hard drive: Seagate 400GB Barracuda SATA HD 7200.10(AS noisey model)
    -Video card: evga 6800GS @520/1170
    -Case: P180
    -PSU:Enermax 535Watt EG565P-VE FMA (24P)
    I am Xtreme
    Aug 2003
    I've run 2.05v and it still works.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
