ok today i decided to give my expert mb another try and see if i could get it to allow me to change the voltages without going blk and causing me to have to clear the c-mos. well it seems the only way i can get it the voltage to change is to pull one stick of mem out then make the voltage change then once back into windows i would have to shut downt the system and add the second stick of memory. the wierd part is that i was stuck at auto anything else or any other combo of settings to the voltages was a no go. i even tried that new 12-7 death fix bios wich didnt help either, seems for now all i can do is what i mentioned above. oh and yes i have tried both yellow and orange slots nothing helps....
thx perc,
