Results 1 to 3 of 3
Thread: X850CF on a Thermaltake Tidewater.
    May 2004
    Single X850CF on a Thermaltake Tidewater.
    Not to Xtreme but the tide water is a Hell of alot Quiter than the stock cooling.
    47C Max, Via A thermal probe.
    http://service.futuremark.com/compare?3dm05=1606813
    Asrock Extreme3 Gen3
    Intel 2500K @5.0 1.52V
    Thermaltake Frio
    4-4GB Kinston HyperX 1600's
    1-256Gb Crucial M4 SSD
    Xion 1000W (Made by Superflower)
    2-Evga GTX570 in SLI
    Antec DF-30
    Windows 7 pro 64 bit
    Just a regular guy, Not Xtreme!!
    If I sound STUPID!! it is because I am.
    Not everyone can be a Genius!!
    Live Long And Overclock
    Sep 2004
    I've seen higher clocks on air on an x850...
    Btw your title is misleading...i believe you're talking about the CF card, not two x850's in CF...
    Perkam
    May 2004
    475 on the core is the Max I can Get. 482 just seems to crash. I have been trieing to come up with a Solution so I can use 2 tide waters 2 cards. My case is to small to fit both. not that the Tidewaters are super great, but they do work.
    Yes I bet there are Better clocks on Air, the Point was this is pretty much silent.
    I changed the Title.
    You just recieved this board, test and see if you get any posting Issues with 2 cards installed over a Single, if you would Please.
    Thermaltake Frio
    Antec DF-30
