+ Reply to Thread
Results 1 to 6 of 6
Thread: X2 3800 temps
    Dec 2005
    0
    X2 3800 temps
    Just built my first system, the specs are below. I'm using the stock heatsink and fan. Question I have is that it's temp at idle is about 32C and loaded (playing COD2 or Far Cry etc) it's running at 49-50C. Is that normal? Think I need to add an aftermarket hs?
    Athlon 64 X2 3800+
    ASUS A8N-SLI PREMIUM NF4
    XFX|7800GT 256M PVT70GUDF7
    THERMALTAKE Tsunamai VA3000BWA case
    Dell 2005FPW LCD
    2x 1GB of Corsair Value Select RAM
    Seasonic S12-500 PSU
    NEC ND-3550A DVD burner
    DVD-ROM ASUS | DVD-E616A
    Mitsumi floppy/card reader combo
    HD 250G|WD 7200 SATA2 16MB WD2500KS
    Banned
    Sep 2005
    East Coast USA
    0
    yes the load temp is normal, your idle temp is actually pretty low.
    Dec 2005
    0
    What temp loaded should I start worrying about on this dual core?
    Xtreme Member manomanx2's Avatar
    Nov 2005
    0
    More timid people would worry at around 55, but I suppose maaybe 60 would be fine. AMD rates their CPU's to go up to 60-65, so yep.
    DFI Lanparty NF4 Ultra-D - R. AD0
    AMD Opteron 165 0610DPMW *904* - 2700Mhz @ 1.275
    Scythe Ninja w/ Yate Loon @ 30 idle / 40 load
    G.SKILL 2GB HZ PC4000
    XFX 7900GT @ 555/900
    OCZ Powerstream 520w
    Western Digital Caviar SE16 WD2500KS 250GB
    NEC ND-3550A
    Lian Li PC-7B Plus II
    Dell 2007WFP
    Nov 2005
    0
    the stock heatsink with the x2 3800 is why the temps are so high.
    -dan
    25 to life - Eminem chew*'s Avatar
    Jan 2005
    Hell on Earth
    0
    yeah i have 2 that were running 49-50C load but i nipped that in the bud real quick. gotta love 19C on water under load.
    heatware chew*
    For every beginning there must be an end
    Will be around to help with AMD specific hardware till shortly after BD launches, after that I'm Ghost
+ Reply to Thread
