Hey people
im looking to remove my IHS (3500 newcastle, yeh i got it ages ago lol)
im using Koolance watercooling at the moment an was wondering how the loss of height on the CPU might affect how the block makes contact.
now i know there are the 2 tension screws, 1 for older socket A XP CPUs and another one for intel an A64 CPUs, im assuming that the XP screw is used because they dont have the IHS on, and visa versa.
thing im wondering is if by removing the IHS would it be best to use the XP screw due to the possilbe fragility of the core, or should i keep the A64 screw in due to the lack of height in the CPU?
im leaning towards using the XP screw as the screws are based on tension over height, however some more opinions or previous exp. or knowledge would be great
thanks in advance,
