I have never seen D2OL do this before and it's driving me crazy.
I want my memory back!
I take that back.. just checked my main rig...
Could this have anything to do with the rediculously large buffering these things are doing? (both of their resultQueue.dat files are over 16 MB)
Found one that it's actually working right on....
All three of these are WinXP SP2
First system has 512 MB of RAM
Second one has 1 GB of RAM
and this one only has 256 MB... it only has a little over 100 cands completed, too.
Weird... My 2 clients are using 45,240K and 48,972K with ~600ish buffered on each. 2GB ram.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
d2ol.exe is using 38k
dockwin is using 54k
573 buffered
System:
2600K / 8GB Corsair Vengeance PC15000
Asus Sabertooth P67 / MSI Twin Frozr II 6950 Crossfire
corsair 1000hx / Corsair 800D obsidian
Crucial M4 128GB SSD / Windows 7 Pro
Cooling:
Koolance 360 rev 1.1 CPU block / MCR320 QP rad
OCZ hydropulse 800 pump w/ EK-DCP 4.0 res
Primochill LRT Black tubing 3/8" ID x 5/8" OD
im just over 550k for both on here, 275 k for each d2ol
Mine are all between 40-45m (DC AMD) and ~600 on each
/Edit went to check indabsmt (recently reactivated) ~ 65 cands / 20m
Just restarted on Mikeepc, mem usage is now 12m & 32m
Heading back to 40mb oh well
Want to see if any correlation between processor and mem used?
Ok.. here's the breakdown.
Sempron s754 w/ 512MB - 3084 buffered - D2OL.exe using 133MB of RAM
A64 s939 w/ 1GB - 3385 buffered - D2OL.exe using 131MB of RAM
AXP w/ 1GB - 1875 buffered - D2OL.exe using 77MB of RAM
AXP w/ 256MB - 144 buffered - D2OL.exe using 20MB of RAM
This is startin to make me mad.... the system that only has 512MB is not a dedicated cruncher and doesn't have 130MB to give up...
A64 w/ 500 buffered - 90mb
A wolf in wolves clothing.
Hmmm, around 522 bufferend on this rig and
Ok! Problem fixed! It was the rediculously large resultQueue.dat files that were making D2OL.exe use so much memory.
I cut them out of the d2ol/res folder and restarted D2OL and now D2OL.exe is using just 19 MB on each of the machines that were using 130 MB before!
Worked on all 3 systems that were starting to use gigantic chunks of memory!
51megs
and 50 megs respectively..who wants to guess how many cands???
11mb with 558 cands
All along the watchtower the watchmen watch the eternal return.
Vapor> Where'd ya get that OS X theme? Looks great!
you'll find it on any good theme page......nothing special....Originally Posted by afireinside
google for uxtheme.dll patcher if you haven't it already....
anyway this is something I was remarking in our software company as well. but it was like: the more ram a machine had the slower it went because the code wasn't able to handle all this ram and procuced 256-512MB garbage...
I really think it is bad mem handling because I don't think it really needs such big amount of ram for being fast enough....
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
I use WindowBlinds, the theme is called Tiger or something....there's 12 subsets to it, 6 aqua, 6 graphite, within each of those six there's three left buttons and three right buttons, one for brushed (mine), one for platinum (mine but flat metal, not brushed), regular (replaces the windows - [] X bar with a Tiger-ish one, but leaves the rest of it more windows like).Originally Posted by afireinside
Anyway, don't mind the high RAM usage on mine....rufus.exe (bittorrent client) has a RAM leak where it uses RAM proportional to the B/W it's using (and double what it says).....it was going very fast when I took that shot
Someone else buffer up 3300 candidates into 1 resultQueue.dat file and see if their D2OL.exe eats 130 MB.
Seeing as I have over 1200 right now and it's the same size as when I have 0, I'd think it'd make no difference
Well that was the problem....
Both systems are using 20MB now after I moved their 3000+ candidate resultQueue.dat.... so obviously it did make a difference.
Same system... just swapped around some resultQueue.dat files and took screen shots...
Now tell me again it don't make a difference.
CS Source y0.. i see that lil icon.
hmm thats weird.. i have 1600 eating up ~ 125 megs.
I am using 55 Mb on each dockwin.exe plus 35Mb on each d2ol x3
I have 1.5 Gb ram so no shortage, but takes forever for them to load up when i reboot.
FX-8320
Asus M5A97 r2.0
8 Gb Gskill
Radeon 7870 Tahiti LE
Corsair 750 watt
Doesn't make a difference with my system, that's for sure.Originally Posted by shmaa
This is really strange! And very new! The whole time we have been running this project and we can still learn something new!
I'll check one of my rigs at home that has 600+ ready on one node and see what it's using.
Question... are you running D2OL Daddy shmaa?
