Permatex® the Right Stuff® Gasket Maker
http://www.permatex.com/products/pro...&item_no=33694
snippet
Says that it's sensor safe, which I hope means that it's safe to use on electronics/pcb and it's available in a aerosol can.Originally Posted by Permatex description
I was thinking of using this as the first layer of insulation (instead of pcb laquer spray or nail varnish) for the mobo and video card and putting seal string / neoproprene tape on top of that.
Basically:
1. Nail Varnish the hard to spray spots
2. tape up the stuff that gets hot and any open sockets
3. Spray the back of the mobo and spray the 2-3in surrounding the CPU socket and AGP/PCI-e socket
4. Seal string on top of that (mostly around the CPU socket for the backside)
5. Foam tape on top of that (mostly around the CPU socket for the backside)
-60c to 232c temp range and should be pliable/vibration and non conductive due to being elastomeric rubber. And should be easy to apply with the spray on application, or at least easier than the liquid electrical tape. 10$ for the little can and 14$ for the bigger 7.5oz can
Thoughts?
