Memmory is rated by samsung @ 2VOriginally Posted by KoukiFC3S
1.8 is undervolting it.
thanks, I brought it back up
I swear I read a review that said that it was run at 1.8v, even tho it was rated for 2.
X2 2.7GHz - 2GB Patriot EP - Abit AN8 SLI
yes sir......it does hereOriginally Posted by eva2000
The whole world's hip and thats not cool !
Rip Van Hippy
Doesn't expecting the unexpected make the unexpected the expected ?
Light travels faster than sound. This is why some people appear bright until you hear them speak
You did. That is correct!
ATITool does not work with the 3D Detection for me. Does anyone else have this problem at all?
And also ATITool reads voltage incorrect slighty... it is off by 0.025 according to RivaTuner.
Stock voltage on core is v1.300 not v1.375.
it will still show up as 600/700 stock (2d clocks) but when you move the sliders to oc it will switch to 3d, but still be showen as 2dOriginally Posted by ugp
Rip Van Hippy
ATI Tool reads the voltage from the card. If it says 2V then the card is running at 2V by default.
So when I set clock speeds it isn't setting it right then...? It sets it when I enter 3D Interfaces correct?Originally Posted by SIOUX
The 2d clocks turn to 3d when entering 3d yesOriginally Posted by ugp
Rip Van Hippy
Oh ok, Thanks. I will have to play with it alittle bit.
Do you guys still get the same overclocks using ATITool Vs. Overclocker?
Just wondering which to use when I get the card under its WaterBlock.
well..thats the strange thing here. i sudenly need a little xtra volt just to run 700/800, but my max OC is still the same 823/1000 hehe..
Rip Van Hippy
for ati tool beta 11 you mean vs beta 10 ?Originally Posted by SIOUX
I mean ati tool beta 11 and 3d clocks. beta 10 i used 2d clocks
Rip Van Hippy
Wait, lemme get this straight... so ATI purposefully undervolts the RAM? For what purpose?
oh man
With ATI-tool 25.11 it's the 2D clock you up, but it's automatically in use when you open the ATI-Tool, look on message appears when the soft launch.
SIOUX i'm coming for you http://www.xtremesystems.org/forums/...8&postcount=28
Why not to use ATi Tool for setting clocks? Why use ATi Tool only for voltage? Does "overclocker" tool do something differently to clocks?
Intel Core i7 920 @ 3.8GHz (183x21)
Gigabyte EX58-DS4 BIOS F5
3GB PATRIOT PC3-10666 DDR3
Sapphire Radeon HD4870 512MB BLACK
2x500GB SEAGATE SATA-II 7200.11
OCZ GameXstream 750W PSU
Antec Three Hundred Chassis
still X1800 Oc tool is better for me
i.e. looping ATI Tool beta 11 'show 3d' stress test.
oc'ing using ATI Tool beta 11 max = 762mhz at 1.45v and locks up higher
but using good old method of X1800 Overclocking tool for clocking max i get so far is:
GPU
783mhz at 1.5v
789mhz at 1.525v
796mhz at 1.55v (gpu idle = 46-47C and gpu load = 51-52C)
When I type in clocks in overclocking tool, it doesn't change. In fact, it drops to 480mhz...
you disabled ati services ?
Yup... services disabled... When I first time ran overclocker, I could change clocks, but past a certain number and the clocks wouldn't actually change... Second time I try overclocker, nothing changes right... ATi Tool 025b11 works good for me though.
I gongratulate you,for your working and benching about x1800xt....
It may runaway my eyes,,,sorry...how much did you give vddc and vddq??
Pc power&cooling 850w,meke's birkat cooling single stage(-40),chilly1 ln2/dice container.
Ebemin OC Team
Originally Posted by CanDostum
Me or Eva ???
Rip Van Hippy
youOriginally Posted by SIOUX
Ebemin OC Team
