+ Reply to Thread
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 25 of 76
Thread: X1800XTPE/OC Info and Updates thread
    Xtreme Member bakalu's Avatar
    Nov 2005
    Ho Chi Minh City, Viet Nam
    0
    ASUS EAX1800XT TOP/2DHTV/512M, DF core/mem 670/800, 3DMark05 9695
    http://www.hartware.de/press_3940.html
    XS_THE_MACHINE krille's Avatar
    Dec 2004
    Sweden
    0
    Quote Originally Posted by bakalu
    Highly unlikely, or very, very biased.
    9695/8760 = 1,1067351598173515981735159817352
    That is more than 10% improvement (almost 11%)!
    Not even if you multiply core oc by memory oc you get more than 8%!
    In fact you only get
    650/625 * 1650/1600 ~ +1,074667
    Unless it's their external PSU ofc.
    Or, second possibility (most probable, since I just noticed the "Hardware Specification" table ): Original X-bit labs reports were wrong: The real specs of this ASUS card are 670/1600, which would make a whole more lot of sense.
    (670/625=1,072) * (1600/1500~1,0667) ~ 1,1434667 ~ +14.3%
    And of course, it doesn't scale like core oc * mem oc, so 10% is very plausible to be a more correct number.
    Also the external PSU is only 80W + 75W through PCI-e = 155W power consumption of the card? That's not very much at all. In fact, I'm not confident it's enough power for any good OC combined with a vcore raise.
    edit: Yes, and please, keep all the thread crapping and flame baiting out of here, this is also goes for those who may be right in a factual matter but are displaying an immature attitude towards others and their contributions to the discussion (may they in turn be right, wrong, flaming themselves or neither - doesn't matter). Thank you for your understanding and cooperation!
    Quote Originally Posted by Shintai View Post
    I have a feeling that in 5 years. WD, Seagate etc will be some unknown names.
    (Posted by Shintai, 08-18-2008)
    Xtreme Mentor onethreehill's Avatar
    Jul 2004
    20
    X1800 XT @ 700MHz core and 1600MHz memory on the way
    Currently, the standard clock settings for the Radeon X1800 XT are 625MHz for core and 750MHz (1500MHz data rate) for memory. Because ATI is experience good yields on the Radeon X1800 XT core, it is allowing boards to be overclocked to 700MHz core and 800MHz memory (1600MHz data rate). In the document, ATI also indicates that standard clock settings are often set at conservative speeds to produce the highest output yield possible.
    http://www.anandtech.com/video/showdoc.aspx?i=2619
    Memory Addict eva2000's Avatar
    Aug 2002
    Brisbane, Australia
    0
    Good yields hehe... where's the stock/availability though ???
    Stop...Ban-Hammer Time! DilTech's Avatar
    May 2005
    5
    The 700mhz/1600mhz is the XTPE, for those who didn't know. Looks like ASUS's 650/1500 is just their overclocked model.
    Xtreme Enthusiast sxs112's Avatar
    Mar 2004
    Taiwan
    0
    Asus EAX1800XT TOP with 700 MHz chip clock (update)
    670/800 EAX1800XT Change 700/800
    The EAX1800XT TOP should be available starting from at the end of November for 529 euro in the trade. Contained in the scope of supply the plays joint are operation, Snowblind and King Kong (DVD).
    Live Long And Overclock perkam's Avatar
    Sep 2004
    0
    Thanks SXS For the update and the pics
    This just became the unofficial X1800XTPE thread....no talk of the XT here, or what compares with what, or XT's issues etc. Thx.
    Once reviews start comin in, a seperate thread will be made for that too. Otherwise all XTPE discussion goes here
    Perkam
    Jul 2005
    0
    Looks like ATI is back after a little GTX scare. If they are indeed launching the R580 in Jan/Feb they are back on top without question.
    Intel i7-3770S l Thermalright Venomous X l Asus Sabertooth Z77 l 8GB G.SKILL Sniper Low Voltage l ??? l Samsung 830 256GB l Areca ARC-1200 l WD Caviar GreenPower 1TB (RAID1) l Pioneer BDR-207DBK l Creative X-Fi Titanium HD l Kingwin Stryker l Antec SOLO II l HP LP2475w
    Xtreme Enthusiast 5-Clicks's Avatar
    Apr 2005
    Atlanta, GA
    0
    doesn't Newegg ship to Canada? I remember them saying that by October they'll have a warehouse in Canada and will be shipping there. IIRC, they also said that they'll eventually ship worldwide. I might be wrong about that last part though.
    And I would say that the X1800XT's are pretty fairly available compared to their other launches. I remember the X800XT PE that wasn't available anywhere for longer than 10 minutes and even then they were $630 USD for about 6+ months.
    For an X1800XT PE to hit 700/800, it seems that ATI will only have to bump up the volts by about .3v-.5v and they'll get more frequently hitting PE core and mem, am I correct?
    Intel C2D E6600 (L630B015)
    TT BigTyphoon || Zalman VF900 Fatal1ty
    Abit QuadGT
    2GB Corsair Dominator PC2-8500
    HIS X1900XT --> XTX
    Creative X-Fi Elite Pro
    OCZ GameXStream 700w
    Feedback:
    HEAT --- eBAY
    Sep 2004
    0
    Quote Originally Posted by 5-Clicks
    If we assumed that they are binned differently, then 700/800 isnt a problem...but I was expecting 725/850
    Perkam
    Xtreme Addict ugp's Avatar
    Aug 2004
    Inverness, Florida
    0
    Very strange looking card...I think ASUS could have did a better job on the Heatsink/Fan design...I want to see what HIS and Saphire so with theres.
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    1TB HDD + 2TB Ext + 1TB Ext
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    2GB+1GB G.Skill DDR2
    320GB HDD
    ATI HD 2600 Pro 256MB
    16GB iPhone 3GS
    GamerTag: ugp
    GamerTag: SadisticPuppets
    Xtreme Addict onewingedangel's Avatar
    Apr 2005
    Wales, UK
    0
    Well the card has a huge lump of copper on it, but all the heat removed is dumped back into the case, so the case temp is higher, and so its more difficult to remove the heat from the heatsink. Not the best design decision really. Cant artic cooling nv silencers be fitted to this card? Expect HIS to release a x1800xtpe with arctic silencer soon enough... and we may even see some cards with the 7800gtx512mb's cooler.
    Would like to see some new heatsink designs though. And with crossfire and SLi now so popular why not have cards that have heatsinks you can place standard fans on the push the air out of the rear of the case, so for example you put an 80mm fan on it if its a single card, or put a 92 or 120mm fan to cool 2 cards in sli or crossfire. Having a 120mm panaflo at 7v cooling 2 graphics cards would quieten an air cooled computer down no end.
    Aug 2004
    Inverness, Florida
    0
    Yeah that is an issue I have now with SLI. The heat is so much and with the Chipset being there it takes the hot air and pulls it in and causes the chipset to be hotter.
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    320GB HDD
    16GB iPhone 3GS
    GamerTag: ugp
    Xtreme Member SDX's Avatar
    Feb 2005
    Iowa City
    0
    If ATI was smart they would put the 1.1ns GDDR3 on the PE
    and stock clocks of
    700-725/850-900
    AMD 6400+ BE
    DFI Lanparty UT 790FX-M2R
    2gb Crucial Ballistix DDR2 800
    ATI Radeon X1900XT 512mb
    PCP&C 750W
    Water cooled:
    Swiftech Storm CPU
    Maze 4 GPU
    MCP655
    Modded Heater Core
    Sep 2004
    0
    Quote Originally Posted by LOE
    Thats a very good question
    If ati launch 580 in january that means killing x1800xt sales, cause with this tempo it still might be unavailable at this point.
    If ati want their phantom edition to do what it should (beat 512 GTX with a few FPS to claim they have the fastest card (even thou it's nowhere to be found))... it will need more juice, this clospeed wont get it anywhere near the GTX 512. 700/800 might help it with 3dm 2005 but in games it will need more...
    Let's stay on topic here No mention of the XT unless its in relation to the PE, thx
    But yes you're right, even I'm not too satisfied with the clocks and most will not buy them knowing what we know: that 700/800 isn't too hard on the XT for ~$100 less...
    I'm looking forward to the cooling solution the HIS will have
    Perkam
    Apr 2005
    Wales, UK
    0
    You have to consider that the r580 will be out in a few months, so you want to be able to leave enough room for it to have a performance boost over r520. and one way is to limit the clocks of the PE so that when the r580 at say 750mhz comes out it shows marked improvement over the r520, even if situations where the additional pixel shaders etc. aren't used. Same goes for the ram. Using 1.4ns ram at 1600mhz leaves room for 1.1ns ram to be used at 1800mhz on the r580 cards.
    May 2005
    5
    Quote Originally Posted by onewingedangel
    You mean using 1.26ns ram leaves room for 1.1ns?
  18. #18
    Apr 2005
    Wales, UK
    0
    yeah, 1.4ns is 1430mhz isnt it. My mistake.
  19. #19
    Sep 2004
    0
    I believe ATI execs have said multiple times that 2006 will be the year for GDDR4
    Perkam
  20. #20
    Aug 2004
    Inverness, Florida
    0
    I wonder how DDR4 will overclock...
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    320GB HDD
    16GB iPhone 3GS
    GamerTag: ugp
  21. #21
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    i wonder what ati does with the chips that dont have all the 4 quads working?
    or maybe there are barely any with damaged quads because they been improving the vpu for a looong time trying to fix the problem wich turned out to be something else?
    but still, there must be some with only 3 quads working, where do those chips go?
  22. #22
    Sep 2004
    0
    Quote Originally Posted by ugp
    Well, as far as we know today, Samsung will start mass producing 0.8ns GDDR4 chips in 06 which is 2500Mhz stock.
    Perkam
  23. #23
    Aug 2004
    Inverness, Florida
    0
    Quote Originally Posted by perkam
    Perkam
    OH MY!!!
    27" iMac
    3.06GHz Core 2 Duo
    8GB DDR3
    ATI HD 4670 256MB
    20" iMac
    2.4GHz Core 2 Duo
    320GB HDD
    16GB iPhone 3GS
    GamerTag: ugp
  24. #24
    Sep 2004
    0
    X1800PRO...to go against Nvidia's 7800GS ...
    I'm eager to see what other companies have to offer cooler wise...this one looks uglier by the second.
    Perkam
  25. #25
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    2
    saaya as perk just said they will release lower end x1800's at a later time. They probably just dont have enough borked ones (much less working ones) to release the x1800pro in numbers.
+ Reply to Thread
