Results 1 to 6 of 6
Thread: Ultra X-Connect - blown up - help needed
    Jul 2005
    Lightbulb Ultra X-Connect - blown up - help needed
    I have bought this crappy PSU and it blew up.
    After inspecting it i noticed that one resistor (R105) which was really messed up:
    I removed it and there are soldering holes:
    When I measure it using multimeter it gives me 67Ohms. I doubt if it is correct value.
    Could somebody provide info about it's resistance for me?
    You could measure it or read from color code.
    Could you give me some advise how to repair it?
    Nov 2003
    buy a pcp&c or ocz
    3770k @ 5ghz 1.35v linx stable
    Asus Maximus V Extreme
    8gb Samsung Green @ 2600mhz 11-11-11-31
    EVGA GTX 680
    Corsair AX850
    XSPC Watercooling
    Xtreme Vmod mod
    Aug 2004
    Cornwall/Newcastle uni, UK
    I would guess that the resistor is still ok. When resistors die, they usually turn black and go open circuit (infinite resistance). I can't see what colour the bands are on the resistor. Could you get a better picture or just write what colour each band is?
    Edit: It looks like the resistor was from the high voltage side of the PSU, so be careful if you try to replace it
    Jul 2005
    color code is too damaged to be read
    Nov 2003
    that psu is not worth fixing.
    EVGA GTX 680
    Corsair AX850
    XSPC Watercooling
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Yep, that psu is known for insane # of failures.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
