Hi,
Got my RDX200 all setup and its been trouble free so far. Got my opteron running 2800 no problem. However, I have been trying to take my RAM settings off AUTO settings but am not have any luck.
I know the RAM is good for 240 at 11,2,2,2 at 3.3 volts as I ran this on my Nforce 2 fine, however I just can't get it error free at any speed over 200. The settings I am using are:
command per clock AUTO
CAS Latency 2
TRAS 5
TRP 2
TRCD 2
TRRD 2
TRC 8
TRFC 24
TRWT 1
TWCL 1
TREF 3120
TWTR 1
TWR 2
Read preamble 5.5ns
Async latency 7
R/W Queue bypass 8
Dynamic counter Enabled
Idle Cycle Limit 256
Bypass Max 7
DRAM Drive strength normal
DQS skew value 0
VDIMM 3.3
DRAM bank interleaving enabled
32 byte granularity AUTO (what is this? just left it as auto)
With all settings on AUTO, the ram is error free up to 260 mhz, but as soon as I adjust the timings it errors. Can someone reccomend some settings that will get my RAM stable? My stable auto settings are as follows according to A64 tweaker:
The auto timings at 255 1:1 are:
cas Latency 2.5
trc 11
trfc 24
trcd 3
trrd 2
tras 8
trp 3
twr 3
twtr 2
trtw 4
tref 200mhz 3.9us
read write queue bypass 8x
controller mode 128
ecc mode disabled
2t timing disabled
bypass max 4x
max async latency 7
read preamble 5.0ns
idle cycle limit 16 clks
dynamic idle cycle counter enable
Anyone know what might be making my RAM unstable?
thanks
