Well,
This was my first VMod, it could have gone more smoothly, but I think I did okay, I moved them to the edge of the pcb because they were too hard to access on a computer inside of the case.
Well,
I had the fastest 32M Opteron time for about 1/2 day, and I'm damn proud of it
Wow thats a nice quality job.
Originally Posted by IYP
First Vmod on 7800GTX?
That's sick man..
Yeah, what the hell why not, you only live once right?
He sure got b**lsOriginally Posted by Kasparz
looks like a very clean job.
ASUS P5K Premium 2.00G/A02 - Bios 1101
Q9650 @ 4.0@1.30 - 24/7
Corsair 4 x 2048 8500 C5
ASUS HD 6950 2 GB.
Cooling: PA 120.3 w/ shroud. (CPU / GPU / NB)
Mist 800W
Lian Li PC-A7010
Here's another photo from a different angle, I took out my cards today and spent a little time to coat those exposed trimpot legs with liquid electrical tape, that stuff is awesome! Took the photos first though!
nice job
good job, and nice photos.
Looks very clean bro.
Might want to consider putting something thats non-conductive between those resitor legs and the boards PCB. Hate to see a short-circuit. Cut those resistor legs in half before your next vmod journey.
Hey thanks, I had originally done the mod the way viperjohn showed it with the potentiometer legs soldered directly to the pcb, that's why they are so long.Originally Posted by Black Hat
After taking out the cards yesterday I coated the exposed legs with liquid electrical tape, thanks for the advice!
i find some hot glue works well.Originally Posted by Weee
but wow, first vmods on dual 7800GTX. thats sexy.
but whats important is how have the clocks increased?
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
looks good, great job
i've done the same vgp like wee (thanks ).
without vGPU: 535 MHz + 50 MHz delta
with vGPU @ 1,5V: around 565-570 MHz + 50 MHz delta
both on a modded air cooling
Core i5 750 @ 4.5GHz
Intel DP55KG
2x2GB RipJaws @ 856 MHz 7-7-7-24
8800 GTS 512MB @ 901/1250 (MCW60, 1.48V)
Vapochill LS modded
Viewsonic 28" 16:10
Good Job , Nicely Done
Knowledge is the biggest power.
Rig1 : Pentium Katamai 0.45Ghz|ASUS P2BVT i440B|256MB SD Ram|Nvida Riva TNT 8MB
Sony DDU1621|Polk Audio Speakers|Samsung 40GB|Microsoft Optical Wheel Mouse.
With Great Power Comes Great Responsibility
Rig2:
AMD 64 3000+ [E6] 0545 DPMN @ 2502.9Mhz [278.1 x 9] [SOLD]
AMD 64 3000+ [E3] 0517 DPMW @ 2925.6Mhz [325x9]
DFI NF4 Ultra-D | BIOS:- N4D704-2BT (BigToe Mod)
Twinmos DDR400 2x512 2.5-3-3-7 with 5:6 Divider
Sapphire X800XL 398/498 with Ati Silencer
Creative SB Live! 5.1
Benq DW 1640
Segate 7200.9 160GB SATA
Logitech MX518 Mouse
PowerSafe 500W
ZB 01 Server Cabinet
Why hasn't the Core Frequency increased that much. 550Mhz seems low for a watercooled vModed GTX
That's a really nice vmod job. I especially like the placement of the pots at the edge of the board for tweaking-friendliness.
One of my cards is a really poor clocker, they used a different voltage regulation IC than i've seen on most it was a really early card, the gpu voltage droops under load unlike the other card.Originally Posted by Zenjirou
The good one does about 635 no delta on peltier @ 6C loaded and could probably do better w/ some more tweaking.
