+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
Thread: A64 3200+ ClawHammer
    Oct 2005
    0
    hello to all! here what for hour they are successful to obtain from my CPU
    temp CPU: 25°C!
    Xtreme Member UTF Nightmare's Avatar
    Sep 2005
    The Netherlands
    0
    You must get more out it with that temp. Maybe more Vcore if it's possible ?
    What is the FSB? Cant't see it
    What kind of cooler you use?
    Epox 9NPA+ Ultra - Opteron 146 0530 APMW
    Infineon BH-6 2x256mb - Tagan 480W-U22
    Gainward 6600GT Vmodded - Kingston HyperX BH-5 2x256mb
    Infineon BH-6 280MHz 2-2-2-5 @ 3,77V - 3602MHz - PhCh mem Project
    Oct 2005
    0
    the computer was on the balcony! and the vCore is to 1,8 V
    Sep 2005
    The Netherlands
    0
    And you can't get more then 2586MHz?
    That's not really impressive
    Admin Gautam's Avatar
    Dec 2003
    Hillsboro, OR
    0
    Depending on the date of the proc it could be pretty nice. I hit 33.9 or so at 253x10...highest mine could go on cold air. Of course back when I had that proc, I matched what plenty had on phase...times change and so do the clocks.
    You should probably look into getting some better RAM.
    Oct 2005
    0
    I would have to try! as soon as the cold returns
    Oct 2005
    0
    Quote Originally Posted by Gautam
    between much time I would not have to change ram
    Jan 2005
    Bulgaria:Maina Town(Plovdiv)
    0
    Here is one from me
    2540 on 1.6V
    and one sucide shot 2700 mhz on 1.7
    The stepping of mine is CAA2C(I think everyone know about this stepping)
    Dec 2003
    Hillsboro, OR
    0
    I sure do.
    Jul 2004
    0
    try doing that with a CO revision
    FX8350 --Sabertooth990fx --XFX 5870 --8gb GSkill --Scyth Infiniti --2x120GB Vertex4 RAID0
    Oct 2005
    0
    I sure do.
    freq ram?
    Dec 2003
    Hillsboro, OR
    0
    255MHz 3-2-2-1.5.
    @madman: I've never owned a C0, but had a very early CG back from when most still had C0's, which is what I was talking about earlier.
    Ancient nForce3 150 board (remember those)? Good times...probably could've done 2.6+ in the DFI.
    Week on this puppy is 0405, nearly two years old. The C0's sometimes ended up below this on single stage.
    I am Xtreme Zeus's Avatar
    Feb 2003
    Netherlands
    7
    (remember those)
    I do.
    Ancient C0 revision (one of the very first S754ClawHammers) and an ancient Shuttle AN50R.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Dec 2003
    Hillsboro, OR
    0
    Very nice. Must have been quite a lucky one. Most didn't seem to hit 2.4 on air regardless...remember quite a few maxing out below 2.7 on phase. Nicely volted too, I like that.
    Registered User TurkeyFace's Avatar
    Oct 2005
    In front of the computer
    0
    Quote Originally Posted by Backbone
    Here is one from me
    2540 on 1.6V
    how did you raise the multi to 13x with that +3000?
    Dec 2003
    Hillsboro, OR
    0
    I don't see any one using a 13x multi...
    Btw, backbone, I'd say something is up with your score...should be quite a bit faster.
    Oct 2005
    0
    look at the top picture that I quoted...it doesnt look like 9 to me...if it isn't a 13 then it looks like a 10 on the CPU Z screen shot
  18. #18
    Dec 2003
    Hillsboro, OR
    0
    Double click the picture to expand it to full-size, heh. It's 10x253.9 in the first one and 9x300 in the second.
  19. #19
    Oct 2005
    0
    omg...I'm so stupid...CLAWHAMMER...not winchester...I'm stupid
  20. #20
    Jan 2005
    0
    I use a memory devider becouse my memory hate Clawhammers's mem.controlers.
    This stepping is for FX - but I can't change multi
  21. #21
    Sep 2005
    0
    My 3400 co would do only 2420 on air.
    Gigabutt X58 OC F3 Bios
    Xeon 5680 200x21@1.34V.Vtt 1.295V.
    3x4 gigs Samsung 2Ghz 10,11,10,31@1.5V.
    3xSapphire 5870
    PCPC 950watt
  22. #22
    Oct 2005
    0
    new result!
  23. #23
    Xtreme Guru i found nemo's Avatar
    Jan 2005
    waukegan
    0
    Quote Originally Posted by UTF Nightmare
    dude, don't be such a jerk, these chips don't o/c like the new venices and fx's i think it's pretty decent o/c but the pi time is off a bit try to tighten your timings a little
    Quote Originally Posted by ToTTenTranz View Post
    "ATI/nVidia drivers suckz0rs!!! I had two gazillion driver BUGZZ per second with ATI/nVidia cards and when I changed to nVidia/ATI everything got PEEERFECT! Zero BUGZ! And performance went up 2000%, the weather got better, my car suddenly has 200hp more than before and my girlfriend likes my sexual performance again!!!"
  24. #24
    Jan 2005
    waukegan
    0
    it was a 10* multi cuz the 512 cache, lower cache, amd raises the multi to compensate
  25. #25
    Feb 2003
    Netherlands
    7
    Quote Originally Posted by i found nemo
    He probably never have had one, the ones who do know how hard 2,5GHz+ was to get with these.
    Saying it's not impressive is a bit harsh, unless you've owned one up to 2.6GHz or higher on air or water.
    Spi time is bad because of RAM speed/ timings.
+ Reply to Thread
