For any V-mod i do, I normally solder two wires from a 3-pin fan header to the mod points on the pcb and then plug a pot into the fan header.
Insted of soldering the wires to the pcb, can they be attached in another way?
ie can you position the wire on the contact point and use silicone sealent - bluetack or seal string(used with prometeia cooling).
this would allow very easy removal of the mod.
