With mods, 250+Originally Posted by ZX7891
The Asus just like the DFI, prefer high vdd. NF7 can vary between 1.6-1.9 for max results.
i5 3570k | Asrock Z77 e4 | F3-2666CL11D-8GTXD | GTX660Ti | HX650 | 2xU2312HM
Thats fair enough. But, lets notforget your CPU is one of the best ever. Perhaps it behaves differently then the two i had?Originally Posted by Lastviking
most An7 boards stop at 224 fsb I went through 5 before i got one that would hit above it.
thought id try a superpi with my xp-m, aswell.....
The time of Lastviking is very slowOriginally Posted by Revv23
with 260fsb...and nf7-s no mod.
nice run there mate
whats the max fsb you can run ???
How is the IQYHA 0407 VPMW compare? I own one right now, I'm going to try some highFSB when my DDR booster comes in the post.Originally Posted by masterchorch
Masterchorch, any opinions on BIOS's besides the Mantarays? also, a 1t BIOS like the PR3ACH3R I use should be fine with BH5 right?
I found that when using the mantarays, too often I'd try to get into the BIOS and I'd end up with a black screen with a blue bar along the bottom, I got sick of it.
My time with my IQYHA 0407 VPMW XP-M 2500+ without DDR booster
Anyone know what I should expect from an 0407 VPMW type of IQYHA?
[img]
Q9650@4288 10.6sec 1m superpi water ||Asus P5Q Deluxe||4Gb Ballistix Tracer red||4870X2||Corsair1Kw
Here's what I found hunting around the net on these:
IQYHA 0407 VPMW
(Air, peaboy) (Volcano 7+)
* 1992 MHz at 1.5 volts
IQYHA 0407 VPMW
(THunDA)
* 2530 MHz at 1.725 volts. Idle 35C
* 2310 MHz at 1.55 volts
IQYHA 0407 VPMW
(FatesWarning)
* 2508 MHz at 1.8 volts
IQYHA 0407 VPMW
(Air, Hughhefnar) (Thermalright SP-97, 92mm Tornado)
2531 MHz @ 1.8 volts
2600 MHz @ 1.9 volts
2725 Mhz, 46.5C load
IQYHA 0407 VPMW
(Water, mata2974)
(Koolance system, Swiftech MCW 5002, Mag5, two heatercores)
2802 MHz at 2.05 volts
IQYHA 0407 VPMW
(Air, thegame) (SP-97, 80mm Vantec Tornado)
2640 MHz
IQYHA 0407 VPMW
(Water, madsam) (DTEK TC-4, Chevvy core, Eheim 1250)
* 2750 MHz at 2.05 volts
IQYHA 0407 VPMW
(Air, Tazman2) (SLK 900A, 92mm Tornado)
2600 Mhz at 1.85 volts
IQYHA 0407 VPMW
(Air, fishtanke) (thermalright SP-97, 92mm Panaflo H1A)
* 2675 MHz at 1.9 volts
* 2714 MHz at 1.95 volts
Originally Posted by Morgoth
The 0407 VPMW doesnt seem that good. Some results are below average, some are average. If you can get 2600 1.8-1.82v stable, then you have a good cpu. If you need 1.85v, it's average. 1.9v for 2600 is kind of bad for a mobile.
Originally Posted by OCPerformance
Wow...very nice score...1gb@260mhz...
My biggest fsb is 274mhz with a nf7-s no mod...
finaly my third lanparty arrived - and it brought what i was searching for...
FSB 270 // 2-2-2-11 1T
ln2 is ordert, lets see what's gonna happen then...
bloody hell thats nice mateOriginally Posted by masterchorch
i cannot get hold of ln2 here yet
good to see the xp wars continue
nice clocks
still got an 2600 xp-m here and just bought me an nf7-s on ebay
i will slap some phase change on it as soon as its arrives
lets keep socket A alive
dfi rdx 200 -- 4000+ -- x1900xt -- 2gb g-skill pc4000
God 2.2v ,,,,,,crazy~!
CPU PII 940 oc to 3.85G
MB ASUS M4A79 DLX
VGA ZOTAC 295
RAM Mushkin REDLINE 4096M
LCD EIZO 24 LED
HD WD 320G 640G ST 500G
DVD-RW PIONEER 218 115
SOUND CARD A2ZS with cambridge soundworks 4.1
MOUSE MX300 MX1000 WITH ICEMAT2
POWER CORSAIR TX850W
I replaced my beloved XP(M) with my current rig and there is no contest. (A64 kills it) But...........
2600+mhz and 243fsb for an idiot like me ain't bad, (AN-7, 2600XP-M and and 2X256 Twinmos BH-5 on an unmodded board) I still love it!
DFI CFX3200
Opty 180 at 2730
XP-90C W/92mm Tornado
2X1024 G.Skill HX
Silverstone 520
Powercolor X1900XTX
I know i can flash my DFI Lanpart Rev.A with the Rev.B Bios, losing both RAID and S-ATA functions (correct me if I'm wrong), but will also those Rev.B modded BIOSes work on my Rev.A? My max un-modded FSB is 266MHz, but my ty Corsair VS is holding me back, and nf2 definitely HATES mem divider...
And also I definitely need badly a Shim, because the weight of the cooler already started cracking a corner of the die >(
Only BH-5/6 and UTT will get good results on nf2??
PC 1 • PC 2
[Intel Q9450 @ 3.733GHz] • [Intel E8400 @ 4GHz]
[XFX nForce 780i 3 Way SLI] • [ASUS P5K Premium Wifi Black Pearl]
[2x2GB G.Skill F2-8000CL5-2GBPQ] • [2x2GB Crucial Ballistix Tracer]
[Visiontek HD4870 512MB] • [MSI 8800GT 512MB]
[LG 2243W 21.5" FullHD LCD] • [Samsung T220 22" LCD]
[Solytech 600W] • [SevenTeam V-Force 750W]
