Fans and pump dont have to be on compy PSU.Originally Posted by Helheim
Yes it is, if your video card is not overvolted or overclocked.Also, is it safe to just turn the TEC off when you're not doing any extreme overclocking/running under load (when you're not there, basically)?
Due to the heat dump and power consumption of my peltiered setup, I ran my video card at stock speeds with the peltier turned off, but with the peltiered waterblock installed, for about a month of the summer. I saw load temperatures around 39 degrees celcius - not dangerous at all, and way better than stock aircooled numbers to boot
Thats not right somehow... Tec's are insulators when not on...
If you have a cooling question or concern feel free to contact me.
This is correct. TECs when not powered conduct no heat and actually insulate. Although some folks might have examples of how they ran things without powering the TEC, make no mistake, the waterblock wasn't providing any significant cooling.Originally Posted by n00b 0f l337
Moral...always power your TEC for cooling.
And, always uses relays along with monitors (flowrates, temps, etc)
9900k @ 5.1Ghz
Asus Maximus Hero XI
32GB (8 x 4) Gskill @4000
Strix 2080 Ti OC
OS & Apps: Samsung 970 Pro 512GB
Games: Samsung 970 Pro 1TB
Storage: Crucial M500 2TB
Seasonic Platinum 1000W
Phanteks Evolv X
With a coldplate you can get away with the TEC off on a GPU as long as your just in the desktop.
BUT you risk overheating the card if you play a game and forget to turn the TEC on, or possibly even playing a vedeo/dvd might cause you problems.
Again, an unnecicary risk IMO.
Hmm, peculiar. I am aware that TECs act as insulators when not powered, but I was not aware that they were "perfect" insulators.
As I said, I ran my X700 Pro without issue at stock speeds and voltages, for gaming, web browsing, and watching movies, and my load temperatures averaged around 39 degrees celcius throughout (as measured at the direct rear of the GPU core, on the reverse side of the PCB) with the TEC powered off. The card overclocked just as minty after this treatment as she did before it... I fully intend to run my next card in this manner as well, if the heat dump and electrical consumption becomes an issue again.
I also intend to not be a careless fool twice, and use a relay every single time I bench this time around... :bannana:
They are not perfect insulators by a long way.
But they are not very good conductors thats for sure... but like I said .. with a cold plate to spread the heat you will be ok as long as your not putting too much wattage out.
I agree with Holst you can probably get away with it on your x700 felinusz but on something like a x8x0 series or a 6800/7800 or a CPU other than maybe a socket a mobile I wouldn't risk it that just to much heat to risk not being able to dissipate fast enough.
I would never risk it on a CPU.
A CPU can go to high load under normall windows applications.
Where as you wont load a GPU unless you play a game.
yes yes, i know. I meant off the same seperate power supply. Trust me, I know plenty about peltier powersupply requirements... *shudders*Originally Posted by Helheim
Yea, but with a relay wouldnt the TEC never be shut off as long as the system is running?
I may even leave my system on for days at a time, will that be a bad thing with a TEC?
TECs dont sound to scary the way Marci said lol.
Originally Posted by freecableguyCheck out my forum: http://www.anarchyst-it.comOriginally Posted by Xeon th MG Pony
well, basically what i'm saying is have the cooling powered completely seperately from the computer and all from the same spot, so that no one component of the cooling can be on without the others being on.
as for leaving system for days at a time... could be scary and fire-causing.
if youve worked out your system it shouldnt be a problem
as long as your cooling is up to par no problem ... you can run tec system endlessly.. given all other factors are taken care of as well condensation etc...
AMD Sempron 3000+ socket754 @ 2.4 ghz with peltier chilled watercooling.
Once I had my BIOS temp shutdowns set, and my TEC PSU relay in place, I ran my TEC system 24/7. I tested it by simulating pump failure, and other cooling system failures, and it worked great. As long as the TEC PSU is relayed to the rest of the system so that it cannot be powered on with the pump or anything else off, your safe.
9900k @ 5.1Ghz
Strix 2080 Ti OC
Phanteks Evolv X
we need to start a page that is nothing but pic's of where people did something wrong with there Tec and had a melt down like the one showed in this thread!!!!
yesOriginally Posted by littleowl
"Monolith" - [ Xeon W3540 (4.22) - Rampage 2 Extreme - 12 GB Ripjaws 1600 - GTX 570 - 120 GB OCZ Vertex - Antec TruePower 750W - Corsair 700D - Apogee XT CPU Block - XSPC 360 Rad ]
Old Box - [ E4600 2.4 @ 3.7ghz (11x335) - P5W-DH - 4gb Gskill @ 893mhz - Radeon 3850 ]
it would need a sticky!!!!!! I am working on my first water cooled system and my first tec system!! I am just really scared I will mess something up and fry it all!!!!!!!!
Msg me on AIM littleowl if you want any help or advice.
AIM - HWA NoL
I will n00b 0f l337 I have everything ready I am just waiting on my pump from DD
I did the same thing with an 80w tec and it seemed to work pretty good. I have a feeling that a lot of the heat gets turned into electricity is grounded off. My temps were around the same as I got with just water so the tec was almost transparent. IMO tec as insulator could well be a myth but I'll wait until I get a functional setup to test.Originally Posted by felinusz
Its not an insulator, but a non powered TEC is a very very poor thermal conductor. Try running a non powered TEC on a GPU that throws some real heat and you'll find out quickly that little heat makes it way to the waterblock.Originally Posted by gbomb944
9900k @ 5.1Ghz
Strix 2080 Ti OC
Phanteks Evolv X
Whats the diff between a poor thermal conductor and an insulator?Originally Posted by mdzcpa
i was gonna get a vapochill and didnt because its to dangerous for me & dont trust myself lol then thought i would try a tec, after reading this thread im gonna stick to WC i think which ive only just got and try not wonder to far yet lol
I7 920 D0 (4.2GHZ HT on) // eVGA Classified // 6GB Corsair dominator 1600mhz // Asus HD5770 x2 // Corsair HX850 /--/
PA120.3 // EK Supreme LT // MCP655 // MM Ufo (soon to be TJ07)
meh i decided tec wont cool enough ^_^ so Im going to start up a chilled liquid project one my w/c system is up and running :-D
especially since there are other way around the tools unlike in phasechange .
