and wtf..... NO o-rings for the barbs??? Im not sure who to contact Swiftech or Sidewinder computers (who I got it from).
This ruins my whole weekend because now I can't run it without it probably leaking. Nice going sidewinder/swiftech...
Are those even the style barb that takes o-rings? If so, you can get them at any auto parts store for like $0.16. If they aren't the o-ring type, teflon tape is all that is needed.
Yes they require orings to seal, like cartman said above, goto an autoparts store with the block and barbs, and find some o-rings that will fit.
杰森
I can picture in my mind a world without hate, a world without violence.
And I can picture us attacking that world, because they'd never expect it.
This block was made for o-rings. Go look at the swiftech diagram http://www.swiftnets.com/products/in...uide_storm.pdf its the second part listed in the picture... the 2 rubber o-rings. Im not using teflon tape on an $80 block that was supposed to ship with all the parts.Originally Posted by cartmanea
Yep, I just double checked on Swiftech's website. Any auto parts store will be able to hook you up. They carry different thicknesses, so go thicker rather than thinner if you are unsure, but 3/32-1/8 should be all that is needed.
Also, on barbs that take o-rings, I usually use teflon tape on the threads anyway...overkill I guess
Don't get too upset over this...its not worth your time or worry in contacting the manufacturer for less than $0.50 worth of parts.
Swiftech needs to send me this FREE: http://swiftnets.com/store/product_d...asp?ProdID=388Originally Posted by cartmanea
I'll go to an auto parts store though. Swiftech I wonder if this is a block someone returned and forgot to put all the parts back in.
Just use some teflon tape and see if it works... Whats the difference?
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
I think I need to teflon tape my storm's barbs... the outlet is leaking and i don't think its from the tubing.
teflon tape wont do it.. it needs the oring.
Well, the difference is, these barbs aren't NPT, so they aren't tapered. In tapered threads, teflon tape fills small gaps until the threads tighten up. On these barbs the threads don't tighten up, the flange does, so an o-ring really is best....but I do both.Originally Posted by afireinside
Good explanation thanks!Originally Posted by cartmanea
Ah ok different kinds of barbs. Thanks for the explanation cartmanea
It'll just be a packaging over-sight.
Email Swiftech and most likely they'll have some O-rings in the mail to you on Monday.
This is what should be in the box (or at least that's what I got)
4 bags of parts
- STORM common hardware (462,478,775,693/694
- STORM AMD 64, Opteron, 754, 939, 940
- STORM AMD Socket 462, ATHLON, Duron, MP, XP
- STORM Intel Xeon Socket 603, 604
O-rings were in the common hardware bag.
Hope that helps.
DFI Lan Party UT Expert (Bios 704-2BT)
AMD 3800+ X2 (CDBHE 0526UPBW)
G.Skill PC4000 HZ's (2x1024) 3-4-4-8
ASUS EAX 1800XT
WD Raptor (74GB), WD SE16 (400GB)
Seasonic S12-600
Plextor 712a
(2) 19 Inch Dell 1900FP LCD's
Coolermaster **STACKER** w/ side window
WATERCOOLED
PowerBook G4 12.1"| 1.5GHz | 80Gb 5400rpm HDD | 1.25Ghz PC2700 | 8x SuperDrive | Office 2K4 | iWork/iLife06
Yep. No O-rings were in the common hardware bag. Was the circle seal sticker on your box broken or cut? Mine was.Originally Posted by Scroatdog
im with you cartmanea, every fitting i have has teflon tape around it.
it takes what 5 sec to wrap the threads in teflon tape for less than $ 3 a roll. to stop water leaking on a $ 150 mobo, 300 in ram, 150 in HD, 400 for CPU, 400+ for dual SLI????? and any thing else you have in your case.
I take the o rings off and use just tape for rads
ALIENS are bringing my next kentsfield based rig in a UFO case!
