woops posted some of the wrong pics in that last thread. edited now
I wanted to use the cube condenser in this unit, but there isn’t enough room. I needed the smaller condenser as the PC power supply goes in the front section of the case above the controller and you need some clearance room. The drier will run hot at load but temps still be in the -30c’s on my QX6700. The customer will be running yorksfield in time so heatload shouldn’t be an issue.
1/2Hp unit with r410a/r507/r290 blend using the cube condenser, this one will idles close to -50c on the QX6700
Used 13mm Id insulation with 19mm walls.
-43c load with wprime1024 runs with 1.7vcore set in bios. Have to rip out a vapour LS controller from a unit and install it on this unit. The guy getting the unit will be making a 59L 22W 24H case.
