+ Reply to Thread
Results 1 to 22 of 22
Thread: a64 3000+ @ 3222 mhz
    Xtreme Member Xtasy's Avatar
    Jun 2005
    Luxembourg
    0
    a64 3000+ @ 3333 mhz and 25,xx sec super pi
    Hi,
    i tried to oc my 3000+ a little bit an the results are 3222 mhz ^^. but theres one problem left, an thats my ram frquenzy. i use bh5 and cpu-z shows me that they are running @ 358 mhz @ moment the trc is @ 7 so iv got 0,2 secs of more speed in super pi
    i use a dfi sli as mainboard and the nventiv mach 2 gt
    *Edit*
    so i did some ocing again ^^ but i think it isnt the maximum speed
    Older PIXX
    http://www.forumdeluxx.de/gallery/da...56Super_Pi.JPG
    http://www.forumdeluxx.de/gallery/da.../20356pi11.JPG
    Xtremely Bad Overclocker SoF's Avatar
    Jan 2005
    East Blue
    23
    hehe saw the 26s already yesterday - nice clocks and I'm beaten by 0.2s
    seems compressorcooling.com rocking the house atm *gg*
    I'll get you I promise
    Greetz SoF
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Jun 2005
    Luxembourg
    0
    thats correct c3 is tacking the lead :p well play with your ram clocks 2 tweak a little bit
    Jan 2005
    East Blue
    23
    all done already it's totally maxed out...they're just Hynix D5 not the best for going on SuperPi...wish I would have kept my BH5
    Anyway I have one joker I will present on sunday I guess
    Jun 2005
    Luxembourg
    0
    ohh hopefully i´ll find the time 2 tweak my ram a liitle bit so the party can start ^^
    Xtreme Member Leverpospade's Avatar
    Apr 2005
    Denmark
    0
    How fast are thoes ram running in real life then
    And what are the stepping, another one of thoes wild 0517
    Btw, nice overclocking, what are the temps (evapor and in windows)?
    X2 3800+ Manchester E4 LDBHE 0601 UPMW "N" @ 2950 MHz @ 1,408 V @ 24/7
    Vapochill SE
    DFI NF4 ultra -d
    X2 3800 + @ 3617 MHz
    Jun 2005
    Luxembourg
    0
    hi, the ram is running @ 250 mhz. ill tell you the temps later
    Jan 2005
    East Blue
    23
    hey xtasy will you rip off the HS?
    i think i will rip it of and will mod it, apply new paste, and put it onto cpu again.
    i will not run without hs because my last experiences with the 3500+ nc...... ^^
    greetz SoF
    Jun 2005
    Luxembourg
    0
    when i´m surfing in the inet ive -61 on the eva and the cpu´s @ -26
    when im testing with prime 95 the eva´s @ -57 and the cpu´s @ -4 but i think that the cpu temperature will be -1 degree after one hour. the fans of the mach 2 gt are running in turbo mode.
    @ SOF
    no no i´ll dont thouch the hs ^^. my mach 2 gt is modded 4 cpus without hs but i think ill damage one of those bugs. in a few days ill recieve an new 3000+ which may clock with 3,3 ghz. hopefully i find a person with a nice x2 4400+ which wants to be heavily oced ^^, to change my 2 3000+ against his x2
    Jan 2005
    East Blue
    23
    hehe I don't now anyone wanting two 3000+ for his X2 :P
    I think it will help me getting Prime and OCCT stable @3150MHZ as well.
    Temps with Pi are not going down so far when looking on my OCCT/MBM5 temps.
    Can you test the difference between Pi32m and OCCT test stability?
    Here it is almost 150MHZ and I don't want to believe this.
    If only prime would stop I wouldn't care about but because OCCT is crashing as well AND I had one 3Dmark 03 error @3100MHZ (program aborted) I'm not that sure if the CPU is ready to handle these settings all day.
    Regards
    SoF
    Xtreme X.I.P. boblemagnifique's Avatar
    Jun 2004
    France
    0
    Nice o/c
    OCM Member / IXTREMTEK Admin !!
    DDR1 2*256 BH5 Adata @324.7Mhz 1.5/2/2/5 1T at 4v @318.6Mhz Benchs
    DDR2 1*512 Kingston Pc8500 @702Mhz 5/5/5/18 at 2.42v réel
    DDR2 2*1024 Cell Shock Pc8000c4 @534Mhz 3/3/3/8 at 3.5v réel
    Cooling : XP90C , Big Typhoon , waterchiller R507 , LN2 ....
    Jun 2005
    Luxembourg
    0
    i knwo ^^. otherwise ill sell the cpus and buy me a good x2 you knwo my last x2 was prime stable @ 3018 mhz and that inrcedible thing rockz ^^. i use win 2k3 entreprise edition and the system ist enourmous fast
    Edit
    ive reached the 26,00 in super pi , when i reach 25,xx ill post new pixx
    Xtreme Legend dinos22's Avatar
    Mar 2005
    Australia
    36
    awesome clocks mate
    that cpuz and a64 tweaker shot is a bug....just close and start up CPUz again...it will show correct values...and then the A64Tweaker will also do the same....might as well stick MBM5 in the shot too
    Team.AU
    Got tube?
    GIGABYTE Australia
    Jun 2005
    Luxembourg
    0
    ill do a suicide shot. what do you think can i give this litte monster as max vcore? 1,8 ?
    Apr 2005
    Germany
    0
    as i already said on c³ ... nice oc.
    but im sure my 0519 mpmw will beat yours, if it finally arrives after around 2 weeks of shipping -.-"
    never the less... nice clocks m8
    raiden
    Jun 2005
    Luxembourg
    0
    raiden good luck, may the better cpu win :p
    Xtreme Member Welz's Avatar
    Sep 2005
    Temecula CA
    0
    sick overclock!
  18. #18
    Jun 2005
    Luxembourg
    0
    So, i did some more ocing ^^
  19. #19
    Xtreme Member A Scream's Avatar
    May 2005
    Atlanta
    0
    Very nice! You beat my FX55 lol.
    DFI LanParty NF4 SLI-DR, Opty 170, Corsair 1GB XMS Pro PC3200 Oc'ed DDR610, 2x BFG 7800 GTX PCI-E, OCZ 580W Power Stream, Samsung 240GB (2x 120) Hard Drives, Black Armor, Home made monitor
  20. #20
    Jun 2005
    Luxembourg
    0
    what are your clocks?
    Edit
    ive reached 26,00 in super pi . ive i reach 25,xx ill post new pix
    EDIT
  21. #21
    Jun 2005
    Luxembourg
    0
    SoF you gona beat me? :p
    I love Extreme Overclocking
  22. #22
    Jan 2005
    East Blue
    23
    not without a new board - sweet results xtasy!
    I know you worked a long time for this getting an A64 sys running as it should - so congratulations - for the moment I lost the race...
    For me it seems my venice is too cold now - can't fire it up over 3250MHZ anymore what was possible with HS attached...who cares I had enough...will go back to case-mod stuph this is better for my nerves
    too much work at the moment (have some international customers getting problems with our new screening software and there is a high risk loosing much (>150k) money for our dealers if I can't get these problems solved) therefore I will have few time the next week. But who knows....when receiving some money for the work I'm currently doing, maybe I will continue in some weeks, but for now it is over for me
    Greetz SoF
+ Reply to Thread
